14" rims
Jeff Hurd
Jeff Hurd is offline
PostPosted: Wed Feb 18, 2004 8:18 pm    Post subject: 14" rims Reply with quote
How can I tell if the 14" rims I have are for my 73 thing? Is there a inside depth/outside dept measurement any one can offer for me to check?
Thanks,
Jeff
edgy
edgy is offline
PostPosted: Wed Feb 18, 2004 9:33 pm    Post subject: Reply with quote
I'm not sure of the spec. Suggest you contact Thingsunlimited.net or the Thing Shop. If they can't help, let me know, I'll measure the ones we have. I can only assume that the ones we have are original.
fathing
fathing is offline
PostPosted: Thu Feb 19, 2004 2:05 am    Post subject: Your wheel issue Reply with quote
Hi,
originally the 1973 and newer Things had wheels with the size 5 x 14 inch with an offset of 32.5 mm.
Uh, Oh there we have this metric stuff again. I will try to translate, 32.5 / 25.4 = 1.28” or 1 9/32 “.
Offset is the distance between the imaginary centre line and the mounting surface of your rim.
In the USA the term Rear Spacing (RS) is more common and can be measured from the rim edge (back of wheel) down to the mounting surface. So, how much is an offset of 1.28” in RS? Lets calculate this real quick:
½ Rim width in mm is 5/2 x 25.4 = 63.5, Offset is 32.5 mm, if it is positive offset (wheel goes further in your wheel well) we add this to the 63.5 mm. If it would be negative offset we would subtract this amount.
OK, 63.5 + 32.5 mm = 96 mm
Now we have to add the edge width to that number, which is usually always 12 mm.
Now total RS is 63.5 + 32.5 + 12 = 108 mm or 4 ¼ “
Ok if your wheels are 14 “ dia. 5 “ wide (measured actually almost 6 “ due to the edge width) and has a rear spacing of 4 ¼ “ then it is original. They came with 185 x 15 radial tires.
I hope this is explanatory, maybe someone else has an easier way to explain this.
Best regards
Dominique Laughing
