79 Ignition Control Unit Wiring
alinghi12
alinghi12 is offline
PostPosted: Mon Sep 28, 2015 4:44 pm    Post subject: 79 Ignition Control Unit Wiring Reply with quote
Hey All,
Just finished rebuilding my 1979 2.0l CA engine and have hooked it all back up. I am having a problem however with the wiring. The PO had the black wire going to terminal 15 on the coil from the Ignition Control Unit however on the wiring diagram it has it going to the double relay? I can't seem to find the connection it shows. Here's a pic for reference.
I am also trying to figure out where this wire from the double relay 88a is suppost to go, it has a connector on it and is spliced in with another wire.
And just for kicks can't for the life of me figure out where the white wire coming out of the fire wall is suppost to go and can't seem to identify it on the wiring diagram.
[/img]
busdaddy
busdaddy is offline
PostPosted: Mon Sep 28, 2015 5:00 pm    Post subject: Reply with quote
Are you sure that loose spliced in wire isn't 88e?, that's where the black wire should connect according to this:
Click on it to make it big.
As for the other single white wire down low, where does the other end go?, could it be for camping equipment or that dealer A/C?
Слава Україні!
alinghi12
PostPosted: Mon Sep 28, 2015 5:09 pm    Post subject: Reply with quote
had to use the flash but it looks like you are correct. looks like 88e is the middle prong.
