Front door seal- failure!
ledogboy
ledogboy is offline
PostPosted: Sun Oct 04, 2015 12:43 pm    Post subject: Front door seal- failure! Reply with quote
Hey all-
I tried to install new door seals a while back, and I embarrassed to admit that I seem to have failed. The seals are coming off of both front doors at the bottom and on the hinge side. I don't know what my mistake was, but I am guessing that I didn't let the adhesive (3m weatherstrip adhesive) tack up enough, or perhaps I didn't do enough prep?
So I need to give it another go, and I am wondering if I need to clean all of the adhesive off from my last attempt, or do I just go over what is already there? If I need to remove the old stuff, what would I use to get it off?
Thanks for any advice, I'm hoping to get this done ASAP so I don't wreck the seals.
1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice...
pioneer1
pioneer1 is offline
PostPosted: Sun Oct 04, 2015 2:30 pm    Post subject: Reply with quote
I removed the old glue with a product the body shops use to wash a vehicle before a paint job. It's called "General purpose Adhesive remover" from 3m-I'm sure there are other brands
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
kalispell365
kalispell365 is offline
PostPosted: Sun Oct 04, 2015 2:36 pm    Post subject: Reply with quote
Most people use way too much cement, and it will not work. The secret is to use as little as you can possibly apply(think paper thin!) and make sure both surfaces are cleaned well first.
1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
insyncro
Banned
insyncro is offline
PostPosted: Sun Oct 04, 2015 2:42 pm    Post subject: Reply with quote
There are plastics pins for those seals that go between the hinges.
WandS
WandS is offline
PostPosted: Sun Oct 04, 2015 6:18 pm    Post subject: Reply with quote
I had the same failure. Too much adhesive. A good tutorial for this would be great. If you get it wrong, it takes a lot of time to prep it to go again. I need to redo it again
85 Westy Weekender with a Bostig Conversion.
ledogboy
ledogboy is offline
PostPosted: Sun Oct 04, 2015 7:00 pm    Post subject: Reply with quote
Welp, I'm glad I'm not the only one. I think too much adhesive was probably the problem. I also may not have let it tack up enough- patience is not my strong suit. Sigh- it looks like I have a ton of work ahead of me getting adhesive off of the van. Thanks for all the feedback!
Now a full camper
WiboBusMan
WiboBusMan is offline
PostPosted: Sun Oct 04, 2015 7:10 pm    Post subject: Reply with quote
Sounds like surface prep to me. A tedious job, so better to do it once.
Gotta clean off all the old glue. Peel, pick and rub the dry stuff then carefully and thoroughly clean with adhesive remover, on BOTH surfaces (door frame and seal), let dry and use just enough adhesive to do the job, but not so sparingly that it's drying before you get it in place.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Oct 04, 2015 7:43 pm    Post subject: Reply with quote
Use laquer thinner to loosen up the old hard glue-- it'll be a hell of a job getting it outa the door frame.
Once you have it all gone & clean from the seal & door framem apply the glue evenly to both the seal & metal.
Let it tack up good, and then install the seal.
As long as evverthing is cleaned up good the adhesive will hold the seal onto the van.
T.K.
