Need help diagnosing transmission noise in 1969 VW bug
corbin_dunn
corbin_dunn is offline
PostPosted: Tue Oct 13, 2015 12:15 pm    Post subject: Need help diagnosing transmission noise in 1969 VW bug Reply with quote
Hi all! I've got a 1969 VW bug that I converted to electric. I have 40k miles, and then got some transmission noise. I replaced it with a rebuilt one...but it gave me trouble and leaks. The thread on that:
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
So, I put my old transmission in and it makes a bad noise. Here's a video:
https://youtu.be/msc0nDlNWlQ
Any ideas on what that noise is caused by? I did pop the case open on the side of the tranny and look inside. I moved the input shaft a bit and replaced the main seal. I'm wondering if I did something wrong putting it back in.
Any advice on what is wrong with this transmission?
If it needs to be rebuilt...well, I can try that (using the Bentley book), but I'm not sure what to look for to replace (other than cleaning stuff and gaskets)
thanks,
corbin
corbin_dunn
PostPosted: Thu Oct 15, 2015 7:42 pm    Post subject: Reply with quote
Any transmission pros know what this sound could be?
thanks!
corbin
Multi69s
Multi69s is offline
PostPosted: Fri Oct 16, 2015 1:19 pm    Post subject: Reply with quote
Hopefully mcmscott will see this, or you can PM him. When you were changing transmissions, did you look for any wear or rub marks in the bell housing? Almost sounds like the flywheel is slightly rubbing. After reading both of your posts, it really sounds like you have an alignment / installation issue. Have you checked the bearings on the electric motor for wobble and thrust as well?
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
