Abscate Samba Member
Joined: October 05, 2014 Posts: 22681 Location: NYC/Upstate/ROW
Posted: Sun Nov 08, 2015 4:11 am Post subject: Consolidated thread on discontinued Eurovan parts, fixes NLA |
Attemp to start a thread on parts that are no longer available per either listings or members, and the workarounds _________________ .ssS! |
Posted: Sun Nov 08, 2015 4:14 am Post subject: |
Headlight switch with fog lights no longer available
7D0-941-531-01C
Jetta MkII switch apparently identical, however
Quote: |
The direct replacement switch was fairly hard to find as VW stopped making them a while back and supply is a bit shy from used Eurovans. As it turns out it is a direct match with the 93-99 VW JETTA MK3 Headlight Switch (OEM 1HM 941 531P). Plugged right in and fit perfectly in the dash slot! |
vwjoel Samba Member
Joined: April 14, 2006 Posts: 205 Location: Seattle WA
Posted: Thu Nov 19, 2015 11:49 am Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes |
The cast exhaust manifold for the 1993 EV is NLA. I found a new old stock one for $750 but it will probably crack where all the others have. This is how I got mine going:
http://www.thesamba.com/vw/forum/viewtopic.php?t=642624 |
grapedaddy Samba Member
Joined: July 07, 2009 Posts: 107 Location: Abingdon, VA USA
Posted: Thu Aug 05, 2021 4:54 pm Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
This breaks my heart for my 2002 Weekender:
https://www.vwpartsvortex.com/v-2002-volkswagen-eu...-and-pipes
Look at all those NLA items under hoses and pipes. Mine just broke 100,000 miles this week, but it can't last forever. _________________ ----
grapedaddy
1971 Westfalia "Buttercup"
2003 Westfalia "Tourmaline" (sold)
2021 MB Metris Getaway “TheDarkSide” |
Posted: Thu Aug 05, 2021 7:15 pm Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
Hoses are the simplest thing in the world to fab, electronics are a Lot harder _________________ .ssS! |
Posted: Thu Aug 05, 2021 7:39 pm Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
Yes. My ECM was replaced by the dealership about 10 years ago with NOS, and I'm wishing I had kept the old part to have it re-manufactured with new capacitors. My TCM is original and is probably the weekest link. None of the module rebuilders I have checked with for a spare have one in stock. My local dealership support is about to dry up, because they don't have the time to research part substitutes. I may not sleep well tonight. _________________ ----
grapedaddy
50Splitman Samba Member
Posted: Fri Aug 06, 2021 2:00 pm Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
This part cost me a great deal of time troubleshooting hot-start issues with no other symptoms or codes. Part number 022103474A - crankcase breather hose. Had a hairline crack impossible to find.
I've reached out to every distributor I could find, and paid for 2 of them that were listed by distributors on Ebay and Amazon, and both refunded my payment because they had listings but no stock.
I repaired my original as best as possible, but ultimately if I don't find a used one, I'll have to create my own version of this part, saving the special end connectors. |
Whridlsoncestood Samba Member
Joined: November 25, 2020 Posts: 178 Location: Orange, CT
Posted: Fri Mar 22, 2024 5:00 pm Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
50Splitman wrote: |
Did you ever get a workaround or find one? Mine was so brittle
It shattered the second I put my hand near it getting ready to pull my intake manifold. _________________ 2001 EV MV |
orbeamike Samba Member
Posted: Sat Mar 23, 2024 11:12 am Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
The N115 EVAP canister valve (7D0906515) is NLA from VW. A generic replacement Dorman 911-803 Vapor Canister Vent Solenoid is a drop in replacement.
altered7151 Samba Member
Posted: Sat Mar 23, 2024 4:29 pm Post subject: Re: Consolidated thread on discontinued Eurovan parts, fixes NLA |
I broke mine as well and was able to fix it was a large piece of heat shrink tubing. I patched it with some of that self-clinging flex seal type tape, then put a big piece of heat shrink tubing over the majority of the tube and it's been working great.
Whridlsoncestood wrote: |
50Splitman wrote: |
It shattered the second I put my hand near it getting ready to pull my intake manifold. |
