vwuguy Samba Member
Joined: November 01, 2005 Posts: 1061 Location: southwestern ontario, on and netherlands and bc
Posted: Fri Dec 04, 2015 6:54 pm Post subject: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
In this video i show you how to install your starter on your bus.
please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy |
vwuguy Samba Member
Posted: Fri Dec 04, 2015 8:05 pm Post subject: Re: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
any comments on how to do it faster or better _________________
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13474 Location: West Coast, USA
Posted: Sat Dec 05, 2015 10:28 am Post subject: Re: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
It's hard to tell from a video... But...
You disconnected the battery FIRST, right?
I like to snug the starter bolt, then snug the 17mm engine D-bolt, then tighten them down alternating. Yes it sucks. Yes it also mates the starter perfectly perpendicular to the bellhousing so you get cleaner engagement and better bushing life for the bendix support. I also clean clean clean the starter and bellhousing mating surfaces for the best electrical flow. I consider this as important as having clean grounds and clean positive contacts on the starter. Speaking of, I can't really tell in your video, but it looks like you have some fraying wires in your crimps to the main + post on the starter. Not allowed! That is unfused full battery/alternator current. I also clean those and stack them most important to least important, so the battery cable goes on first, then is followed by smaller and less amp-drawing connections.
I'm sure there are more, but that's what I have at the moment...
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
70Crew Samba Member
Joined: June 12, 2006 Posts: 780 Location: Grand Rapids, MI
Posted: Sun Mar 20, 2016 3:34 pm Post subject: Re: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
asiab3 wrote: |
I also clean clean clean the starter and bellhousing mating surfaces for the best electrical flow. I consider this as important as having clean grounds and clean positive contacts on the starter. |
The factory manual says to "apply VW sealing compound D3 between starter end plate and transmission case." Does anyone know if that sealing compound is still available, and if not, what are you using as a suitable alternative? Also, wouldn't a sealing compound interfere with the electrical flow you mention? _________________ 1970 Crew Cab |
Joined: January 01, 2007 Posts: 17830 Location: sticksville, ct.
Posted: Sun Mar 20, 2016 4:16 pm Post subject: Re: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
don't overthink it. you'll be fine without it. it was a goopy crapy smootz to seal joints and went onto the recess in the bell housing to seal it up.
100% not needed _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52750 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Mar 20, 2016 4:30 pm Post subject: Re: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
A smear of grease will seal it up from moisture and prevent corrosion, much easier to remove later as well  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Brian Samba Moderator
Posted: Sun Mar 20, 2016 4:50 pm Post subject: Re: How to install starter on 1968 ,1969, 1970, 1971 vw bus |
"toss the apron aside"
'I hope he doesn't litterally toss it that would be funn-'
*tosses apron*
'poor apron' _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
