How to replace a cv boot on a 1968,1969-1979 vw bus
vwuguy Premium Member
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Mon Dec 07, 2015 8:37 am    Post subject: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Here is how to replace the cv boot on your bus watch and learn
video by erb smith copyright 2015
In order to get the clip off the end of the axle i use 2 screwdrivers one with a fine tio and one with an extra wide tip.
The wide one i push the clip out with while the fine one i used to hold the clip in place and out. you'll see when you try it..
Do you have any suggestions how to do this better or faster
thanks erb
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
Amskeptic
Amskeptic is offline
PostPosted: Mon Dec 07, 2015 9:40 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Use proper expanding circlip pliers.
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
consvws Premium Member
consvws is offline
PostPosted: Mon Dec 07, 2015 9:57 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
vwuguy wrote:
Here is how I replace the cv boot on my bus
fixed it Razz
Tcash
Tcash is offline
PostPosted: Mon Dec 07, 2015 10:07 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Background music is to high. I can't hear you.
Keep it up
Tcash
Tcash wrote:
Click on links.
How to Remove Stripped CV Bolt Head
CV Joints: Re-pack or Replace?
CV Joint Service (Lobro)
PSA - Nord-Lock your drive shaft (CV) bolts
1970 VW Type2 CV Joint Play
https://www.youtube.com/watch?v=mgwmuZuJ02I
Vanagon CV bolt torque specification 33 ft lbs
CV Joints 101
CV Joint Maintenance
Prt#113 501 229 A and 211 501 229, CV bolt, Socket Head, M8-1.25 x 47, 12.9 hardness, to 70.
Prt# 893 407 237, CV bolt, 12 point polygon head, M8-1.25 x 48, 12.9 hardness, to 71-79. Will work on 68-91 Buses.
Karl wrote:
YES!
Manual and auto trans axles are 3 different lengths.
...and are NOT interchangable.
Half shaft lengths
manual 476mm (18 3/4in)
auto left 457mm (18 in)
auto right 505mm (19 7/8 in)
Good Luck
Tcash
Hansolo99
Hansolo99 is offline
PostPosted: Mon Dec 07, 2015 11:46 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
I really enjoy your videos, but PLEASE get rid of that dumb music. If I want to hear music I will go on Pandora. I can't hear a damn thing. Sorry!
Also get better lights and edit it. I have learned quite a lot, but have to keep watching over and over and rewind then forward the video.
Other then that thanks for taking your time to help us that are still learning!!!
OB Bus
OB Bus is offline
PostPosted: Mon Dec 07, 2015 12:46 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
I'd probably learn a lot but please TURN THE DAMN MUSIC DOWN!
Suggestion - watch your videos (or better yet have someone else watch your videos) prior to posting them. Issues like "the music is so loud no one can hear your narrative" should be easy to identify and address.
Thanks for your efforts.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
busdaddy
busdaddy is offline
PostPosted: Mon Dec 07, 2015 1:28 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Yes please, they'll also prove extremely useful when you make the engine rebuild video and want to get the gear off the crank Wink
http://www.princessauto.com/en/detail/14-in-snap-ring-lock-ring-pliers/A-p8006659e
Слава Україні!
Tom Powell
Tom Powell is offline
PostPosted: Mon Dec 07, 2015 2:39 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
There are several special tools that will make the job easier.
Snap ring pliers
http://www.amazon.com/s/?ie=UTF8&keywords=circ...fc6yi_b_p2
Make your choice as to the snap ring pliers.
Snap ring pliers with toothed or dimpled ends are the best for CV Joint snap rings
http://www.amazon.com/Stanley-J250G-9-Inch-Horsesh...lip+pliers
Snap rings are easy to get off, but harder to install. The spring makes this an easier tool to work with.
3/8 drive 6mm hex socket
http://www.amazon.com/TEKTON-1376-Drive-Socket-Cr-...F8+6mm+hex
Long 6mm hex socket makes working around the rubber boot easier.
http://www.amazon.com/XtremepowerUS-Metric-Pro-Gra...socket+set
The set is cheaper than a single from Sears
Here's both.
http://www.amazon.com/SK-Hand-41405-Socket-8-Inch/...F8+6mm+hex
Some CV bolts are triple square.
http://www.amazon.com/Genius-Tools-Triple-Square-B...ple+square
Long triple square
http://www.ebay.com/itm/Powerbuilt-Triple-Square-L...mp;vxp=mtr
Aloha
tp
mpls_ham
mpls_ham is offline
PostPosted: Mon Dec 07, 2015 5:38 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Thanks for that Erb! I commend you for keeping your cool with the new boot install on the shaft. I might have been inclined to sling a couple of profanities in that segment Laughing
1970 Westfalia - Evangeline
1973 Beetle Convertable
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Mon Dec 07, 2015 5:59 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Tom Powell wrote:
Long 6mm triple square
the 12pts are 8mm Wink
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
Tom Powell
PostPosted: Mon Dec 07, 2015 10:15 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
I could be wrong about the size. I changed my post so it refers to sets rather than individual sockets. The sets have both 6mm and 8mm. You can't go wrong.
Aloha
tp
Tcash
Tcash is offline
PostPosted: Mon Dec 07, 2015 10:21 pm    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Tcash wrote:
Hi All
First determine if you have the right tool.
8mm Triple Square
6mm Allen
One of the following you have in your tool box?
Locking Pliers
410 NUTBUSTER® PLIER
PIPE WRENCH
12MM X 12POINT SOCKET HAMMERED OVER BOLT HEAD
BOLT EXTRACTOR
LAST RESORT
ftp2leta wrote:
Cut any stubborn 6mm axle bolt head, on trany side it's easy, a grinder and cutting wheel will do the job, on the wheel side use a high speed air tool with a small cutting wheel.
Remove drive shaft. Ok, to remove the remaining drive axle bolt i mig weld a 13mm nut.
The replacement of drive axle bolt should be part of normal maintenance. It is crucial to deeply clean the bolt head before attempting to remove those, a partially inserted 6mm Allen socket will never be enough.
The TORKS 12 point bolt are way better than the ALLEN one.
They are a pain anyway
If you do not have a welder you can, put double nuts on the bolt. Tighten them against each other. Put a wrench on the inboard nut and unscrew it.
If is broke off flush with the flange. You can try a left hand drill with a reversing drill motor. Good luck these bolts are hard.
Still no go. Weld a nut from the inside circumference to the broken piece and use a wrench to extract it.
Good Luck
Tcash
Manfred58sc
Manfred58sc is offline
PostPosted: Tue Dec 08, 2015 9:22 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
I am the anti-Stipe! Die monster,die. Good instructional video however, thanks for sharing
Fat chick owner/operator
Wildthings
Wildthings is offline
PostPosted: Tue Dec 08, 2015 10:32 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
Duckbill snap ring pliers
I have not watched the video, but if you didn't mention it you should talk about whether to keep the bevelled washer if it is still there or not. Maybe show a copy of the VW service bulletin about discarding the washer.
14Eyes
14Eyes is offline
PostPosted: Fri Jun 21, 2024 11:00 am    Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus Reply with quote
It's worth noting that the video is no longer available
The Story of my 72
