Pict 34 solex jets in a Pict 34 Bocar?
eddie.would.go
eddie.would.go is offline
PostPosted: Wed Aug 26, 2015 9:25 pm    Post subject: Pict 34 solex jets in a Pict 34 Bocar? Reply with quote
I am having an issue with my 1600 DP in my 71 running on the lean side. When I try to richen it up it doesnt seem to run as good. I have read online that the Bocar 34's can be jetted on the lean side. I have an old parts Solex 34 and was wondering if I can steal the jets from it and run them in the Bocar? Will the fit/work?
The throttle shaft is tight in the Bocar carb as well
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Thu Aug 27, 2015 7:05 am    Post subject: Reply with quote
the jets will fit and work.
what makes you think it runs lean?
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
eddie.would.go
PostPosted: Wed Dec 09, 2015 8:38 am    Post subject: Re: Pict 34 solex jets in a Pict 34 Bocar? Reply with quote
I ended up swapping the jets and the bus ran alot better and not as hot. The tail pipe before was so clean you would have thought it had a catalytic converter. The exhaust was crazy hot too
kreemoweet
kreemoweet is offline
PostPosted: Wed Dec 09, 2015 12:16 pm    Post subject: Re: Pict 34 solex jets in a Pict 34 Bocar? Reply with quote
Bocar carbs often have very raggedy machining, with swarf all over the place. A jet could easily have been
partially plugged, creating leanness.
'67 bug: seized by the authorities
