sweetguth Samba Member
Posted: Sun Dec 20, 2015 12:54 pm Post subject: steering column question |
I am building an Manx clone and trying to use a dune buggy steering set up (basic steering wheel and straight shaft). What is the best way to make a "steering column" to support and guide the shaft to the steering box?
I have been playing around with a few ideas but nothing seems solid. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20896 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Dec 20, 2015 1:10 pm Post subject: Re: steering column question |
Generally you will need at least a brace (tube?) that spans tub at dashboard to support a shaft bearing (Do not try to support bearing with dash) .... And probably a mechanical "U" joint on steering box/shaft to eliminate any flex that might be there with rag joint to give rigidity of shaft....
Using a tube and supporting it at firewall and below dash moves bearing up to behind steering wheel (cantilever) to better support shaft than just a bearing at dash board level...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Sun Dec 20, 2015 10:16 pm Post subject: Re: steering column question |
Meyers manx has sold their steering column support frame separately for a while now. In addition to supporting the upper end of the 58-67 column, it ties the hood/dash, windshield frame and body together into a more rigid structure. The botton end of the steering column tube should be supported by the body, ideally where it passes through the VW rubber grommet.
The picture on their webpage shows it upside down. It should fit clones if they're the same size as a Manx. Its also something a person could be fabricate if they believed the MM one might not fit.
http://www.meyersmanx.com/mmstore/store-classicdashframe.shtml
This picture shows one of the older style Meyers Manx dash frames being fitted. The newer ones don't use the middle vertical bars or the top cross bar and have a slotted bracket to provide adjustment to mount the steering column
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Wed Dec 23, 2015 3:48 am Post subject: Re: steering column question |
| Buggy Brian wrote: |
| Berrien also makes a kit. I've never used it, but have heard that it works quite well. |
I've used the Berrien kit and it's useful in that it'll work for different body widths etc. but it's not as secure as the Manx style ones. The column will flex more and it doesn't tie the screen mounts into the framework. |
