Dark Earth Samba Member
Posted: Sat Jan 16, 2016 4:21 pm Post subject: Re: Fuel line that runs through the tunnel |
I bought these line clamps
In 3/8" and 1/2".
I bought a nylon spacer in 3/8"
and 1/2" and drilled them out to 1/4".
_________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Posted: Sat Jan 16, 2016 4:31 pm Post subject: Re: Fuel line that runs through the tunnel |
Before slipping the fuel line over the trimmer line, I slipped the nylon spacers over the line.
Here they are installed front (1/2")
and rear (3/8")
I then clamped the fuel line in front, under the E-brake, to the clutch cable tube (1/2")
Posted: Sat Jan 16, 2016 7:10 pm Post subject: Re: Fuel line that runs through the tunnel |
The clutch cable tube and e-brake cable tube are metric, so I shimmed those sides of the clamps with some metallic tape I had leftover from my home dryer ducting.
I installed the last clamp near the rear torsion tube.
I still have to weld up the hole-saw holes, but I don't have the welder yet.
I won't drive it until I get it welded up.
If I had the original type of middle and rear clamps, this job would have been much easier.
Still, I'm glad it's done. _________________ My Build: '69 Baja - Dark Earth Version
nwnugget Samba Member
Posted: Thu Jun 21, 2018 5:56 am Post subject: Re: Fuel line that runs through the tunnel |
I'm probably stealing all of this. Since no one has commented to the negative I assume this is a Samba approved approach.
Was your body off for this? I've read that makes this much easier.
I really liked the claps with nylon bushings. Do you have links to what/where you got those?
Edit, clamps are in the package... I should be able to find those. Sorry. |
Posted: Thu Jun 21, 2018 7:00 am Post subject: Re: Fuel line that runs through the tunnel |
nwnugget wrote: |
The nylon bushings come from Home Depot and the roll of steel line came from NAPA. The body was on when I did it. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Thu Jun 21, 2018 7:46 am Post subject: Re: Fuel line that runs through the tunnel |
Dark Earth wrote: |
nwnugget wrote: |
The nylon bushings come from Home Depot and the roll of steel line came from NAPA. The body was on when I did it. |
Great thanks! |
FartsMcFarty Samba Member
Joined: August 18, 2017 Posts: 39 Location: Austin, TX
Posted: Sun Dec 01, 2019 10:17 am Post subject: Re: Fuel line that runs through the tunnel |
Nice work, thank you for posting _________________ Current VW projects:
1966 Standard Beetle
1972 Standard Beetle
1969 Type III Fastback
1971 Type II |
Posted: Sun Dec 01, 2019 3:40 pm Post subject: Re: Fuel line that runs through the tunnel |
FartsMcFarty wrote: |
Nice work, thank you for posting |
I'm glad you found it helpful. _________________ My Build: '69 Baja - Dark Earth Version
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Thu Dec 19, 2019 5:01 pm Post subject: Re: Fuel line that runs through the tunnel |
My 1973 Beetle has that "extra metal".
As does my 1969 chassis that I am using for my Deserter Dune Buggy.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Posted: Thu Dec 19, 2019 6:31 pm Post subject: Re: Fuel line that runs through the tunnel |
BIGMIKEY wrote: |
Mike T |
Thanks for the pictures !! It looks more like a factory update since they all look so similar. _________________ My Build: '69 Baja - Dark Earth Version
