Aerosport Samba Member
Posted: Sun Apr 17, 2016 3:32 pm Post subject: steering shaft |
I was taking apart my steering column assembly to replace the bearing and plastic bushing and noticed the slotted collar is welded on the shaft in a fixed position. The welding doesn't look like a factory job so I am wondering if anyone knows if this is the way it is supposed to be or is it a half assed fix it job by some one. pictures attached.
_________________ Stan L
'87 Westy GL - "Stanagon", 2wd WBX 4 speed
15" Rhein alloys, GW 1.5" lift springs & Fox shocks |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 944 Location: Calgary, Canada
Posted: Sun Apr 17, 2016 5:05 pm Post subject: Re: steering shaft |
That is a factory welding job - bad as it may look!
That slot is for the locking pin from the ignition switch - steering lock.
Totally factory. Why would you want to remove it? _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Sun Apr 17, 2016 5:15 pm Post subject: Re: steering shaft |
I knows it should be fixed but I didn't know if that was the original method to keep it in place. Thought it may have been held in place b y a drift pin or something that someone lost so they welded it, or something like that. Thanks for the reply and letting me know that is the factory setup _________________ Stan L
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1756 Location: Maine
Posted: Sun Apr 17, 2016 5:17 pm Post subject: Re: steering shaft |
yeah that is a factory weld,nice deep penetration. its not a bad weld at all. its just not chased since its not visible. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
