Tcash Samba Member
WithTheFlow Samba Member
Joined: March 04, 2016 Posts: 197 Location: Wisconsin
Posted: Tue Jul 03, 2018 7:14 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I spent so many hours getting everything to fit. I’m going to weld the whole piece as one. (A pillar; dog leg, b pillar)
Tack it in and then fit the door. With this in I’ll have a frame of reference to complete the rest of the passenger side! Sprayed the panels in epoxy now while they are easy to reach. I ended up sand blasting everything to bare metal, even klassic fabs funky green panels. Epoxy adheres best to a sand blasted bare metal surface SPI epoxy and wax and grease remover.
_________________ The fastest thing you can do is slow down.
“The secret is here in the present. If you pay attention to the present, you can improve upon it. And, if you improve on the present, what comes later will also be better."
-- The Alchemist” |
Posted: Fri Jul 13, 2018 11:53 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I put the door on to check my gaps before welding in the dog leg.
With the dogleg in place I have a frame of reference for the curve needed to repair the b-pillar which was completely rotten on the drivers side.
-- The Alchemist” |
Tcash Samba Member
Posted: Fri Jul 13, 2018 4:22 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Thanks for updating!
Tcash |
Posted: Thu Jul 26, 2018 2:46 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
rear outer rocker went in after repair was made to the c pillar. I spent so much time fabricating it, only to cover it up!! The bare metal is where I used 3m epoxy panel bond.
fitting the long rocker took some grinding away at the flanges because it didn’t fit so well. It came in two pieces from klassic fab. I stitched the two rather than plug welding them because it was the only way I can get it to fit. The lower one was extremely warped and I’m not sure why. I didn’t get everything to line up like factory. I did my best. It’s my first restoration and a majority of this bus is replaced!!
-- The Alchemist”
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Thu Jul 26, 2018 6:39 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Super clean panel fitting and welding. Well done. |
Posted: Thu Jul 26, 2018 7:02 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
orwell84 wrote: |
There are imperfections but then again most panels are aftermarket. I’m very pleased to have new metal though! It’s so easy to get lost in the details, only to cover up all your long hours and hard work! _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Posted: Tue Jul 31, 2018 7:33 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Welded in a patch in the wheel arch on the drivers side.
Next order of business is the font nose!
I highly doubt that wolfsburg west put in the strengthener on the inner valence. I also didn't see threaded holes for attaching the bumper.
[/quote] _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
busterbow Samba Member
Posted: Wed Aug 01, 2018 1:25 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I love your work.
Would it be a good idea to take out the windshield. You could have bad rust under the seal and could be easier to change the nose skin |
Posted: Wed Aug 01, 2018 3:35 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
busterbow wrote: |
I love your work.
Thank you!! I have the replacement piece for under the windshield. I’m not replacing the whole nose skin. Just what I have cut out so far. I want to keep as much original metal as possible. I am keeping the windshield in as I go after some of the frane. If i take it out now, it might move a bit and then be a pain to fit a new one. _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Posted: Wed Aug 01, 2018 4:32 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
the inner valence took quite some time to remove!
Here is a little trick
Make a cut every few spot welds
Then use clamps to pull back the flange
This makes it much easier to break away the spot welds
Im going to need to do some fabricating between the A-pillar and the inner valence.
-- The Alchemist” |
Posted: Wed Aug 01, 2018 4:38 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
The Y frame on the passenger side is completely Swiss Cheese. I have a replacement from Just Campers UK
The one on the drivers side is rotted where it meets the valence and has a few pin holes in one spot. The inside has a bunch of surface rust. I am debating if i should patch those spots and then blast the rest and epoxy. Im thinking of later using eastwoods internal frame spray on the whole thing.
-- The Alchemist” |
THall Samba Member
Joined: August 25, 2010 Posts: 324 Location: Verona, WI
Posted: Thu Aug 02, 2018 4:39 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Thanks for sharing your project.
Whereabouts in Wisco are you? _________________ '78 Westy - 2.0 FI |
Posted: Thu Aug 02, 2018 6:05 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
THall wrote: |
Whereabouts in Wisco are you? |
I live in Baraboo!! _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Posted: Fri Sep 07, 2018 8:07 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I needed to take a break from the grind and go recharge in the mountains. Absolutely beautiful backpacking trip in Colorado !
-- The Alchemist” |
Posted: Fri Sep 07, 2018 8:16 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
The Y-arm Frame piece did not cover the extent of the rust and it not incorporate VW’s strengthener. I had to rebuild the inner piece using 12 gauge metal. I brought out the 220v miller welder with .35 wire to handle the thick metal and ensure proper penetration.
Here is the piece I got after I epoxied and welded it together.
Much better than
-- The Alchemist” |
Posted: Wed Sep 19, 2018 7:34 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
I took the opportunity to Sand Blast while I had open access to the internal frameI
The Force is Strong with R2D2 _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22673 Location: NYC/Upstate/ROW
Posted: Thu Sep 20, 2018 3:25 am Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
The day your Bus found you was the best day in it’s life, now it’s third and fourth life!
You have a natural incredible attention to detail that mean s you can do anything you need to this Bus. I don’t think I’ve seen anyone spin up welding so fast. I don’t do enough and have to relearn it each time to get a weld of your quality...maybe.
To be honest, the first post looked like “ Death of a Bay”, a short story that is often told here.
It’s refreshing to read “Bay Genesis “ by real people.
I wish we could sticky this thread and label it
"If you aren't willing to go the distance she did, you will be much happier meeting nice people in a Honda....." _________________ .ssS! |
Posted: Thu Sep 20, 2018 12:51 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Abscate wrote: |
"If you aren't willing to go the distance she did, you will be much happier meeting nice people in a Honda....." |
Thank you so much for those kind words. Its really nice to hear from someone. I got goose bumps thinking back to my first posts. I knew nothing about Body work, Vw's, cars, welding or anything. The purpose of this was to completely submerge myself outside my comfort zone and the bus and I have been growing together for quite some time. Im starting to familiarize myself with the every body panel on this thing. It really is fun studying and revisiting every detail the factory put in. Next week I'm diving in on the passenger dog leg. With that removed I can fabricate the remainder of the A pillar and bridge it the inner valence!! Thats when everything will start coming together!! Right now Ive been taking advantage of having it out so I can spray inside the frame. _________________ The fastest thing you can do is slow down.
-- The Alchemist” |
Posted: Thu Sep 20, 2018 3:30 pm Post subject: Re: My First Bus / 1970 / Non Walk Through / Bench Seats |
Quote: |
I knew nothing about Body work, Vw's, cars, welding or anything. |
your two year progress is amazing - not just your results, but the learning curve you have conquered.
I meet people like this - about 1 out of 1000, maybe 10,000 _________________ .ssS! |
