Seized Engine
rozek
rozek is offline
PostPosted: Wed Apr 13, 2016 10:41 am    Post subject: Seized Engine Reply with quote
Please help!
My '74 super beetle sat for three years and the engine has now seized. I tried to turn the crankshaft pulley but wont turn. Can someone please help?
Tim Donahoe
Tim Donahoe is offline
PostPosted: Wed Apr 13, 2016 10:52 am    Post subject: Re: Seized Engine Reply with quote
Is it out of gear? The shifter in neutral, that is.
Tim
Let's do the Time Warp again!
Richard O'Brien
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Wed Apr 13, 2016 11:15 am    Post subject: Re: Seized Engine Reply with quote
Additionally, stored under what conditions? Outdoors? Covered?
Did you take the fan belt off?
Remove the spark plugs; It's hard to overcome the compression stroke w/ plugs in.
Was it "running when parked"? Laughing
Everything known to man has been written.
Readers are Leaders!
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Apr 13, 2016 11:29 am    Post subject: Re: Seized Engine Reply with quote
If those don't work use some marvels mystery oil, ATF, PB blaster - something similar in each cylinder, down the intake also - then be patient and keep turning it by hand.
I just had a "sized" engine and had it running in a day.
Volks Wagen
Volks Wagen is offline
PostPosted: Wed Apr 13, 2016 2:44 pm    Post subject: Re: Seized Engine Reply with quote
rozek wrote:
Please help!
Stay calm. It'll be fine unless you abused it.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
volksworld
volksworld is offline
PostPosted: Wed Apr 13, 2016 5:08 pm    Post subject: Re: Seized Engine Reply with quote
just had good luck wit a 50 / 50 mix of acetone and ATF (from a hotrod forum) got the #2 piston out of a 1940 hercules flathead that sat for 10 years with 1/2 gallon of water in the oil.. yes it ran when parked...it laughed at conventional penetrating oils....pour it in the plugholes with a piece of fuel line and a funnel and let it sit at least 2 weeks,top off as needed....dont force anything,you can bend a rod
