How to install a speedometer cable in your 1968-1979 bay bus
vwuguy
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Sun May 15, 2016 7:47 pm    Post subject: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
Here is how to install a speedometer cable into a baywindow bus
any comments or suggestions appreciated
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
PostPosted: Mon Dec 25, 2023 8:33 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
You have the video marked private.
Abscate Premium Member
Abscate is offline
PostPosted: Mon Dec 25, 2023 8:52 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
You have to get the snow off the Bus , first.
Merry Christmas, Erb!
my59
my59 is offline
PostPosted: Mon Dec 25, 2023 9:04 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
Not being able to see the video, is this a single cable install or a two piece with the EGR box?
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
vwuguy
vwuguy is offline
PostPosted: Mon Dec 25, 2023 9:31 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
merry christmas ! its single cable. Is this correct according to the book? I have to disconnect it behind dash , run it through the floor to the wheel push it put the rubber thing on the cable push cable through the wheel, put pin on cable to hold it in place, push rubber thing to back of wheel to keep dust out, and zip tie the cable to the chassis and thats it ..follow instrictions at own risk I think thats what it says in the idiot guide and follow instructions at own risk.. and if you want to see the video you can join my patreon page and make cash donation to see it..
SGKent Premium Member
SGKent is offline
PostPosted: Mon Dec 25, 2023 12:17 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
sounds about right but mine are E-clips not pins that hold it from falling out of the wheel bearing cover. FWIW on late bays with the EGR box, the EGR box can go bad and cause issues for the speedo. Of the ones I opened to clean, hoping to find a good one to do the RAtwell hack for an oil change reminder, most were damaged beyond use from water. A one piece early cable can be used to replace the two piece EGR / CAT box, getting rid of the clicking and clanking that box can do when they go bad.
timvw7476
timvw7476 is offline
PostPosted: Mon Dec 25, 2023 1:34 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
If you think you may be immersing your left front tire/wheel in axle-deep water it is a good idea to smear a little RTV on the E-clip. If you do not reseal it, water intrusion may get to your two-piece front wheel bearing assembly & time to buy instead of repack. I believe VW used a wax to do it back in the day but RTV seems to be the modern answer. YMMV.
Xevin Premium Member
Xevin is offline
PostPosted: Mon Dec 25, 2023 1:58 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
vwuguy wrote:
merry christmas and if you want to see the video you can join my patreon page and make cash donation to see it..
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
mikedjames
mikedjames is offline
PostPosted: Tue Dec 26, 2023 8:27 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
Thankyou for explaining why my US driver's side front wheel bearing has failed twice because of water ingress.
On one occasion the water was washing along the bottom of the bus in a river flood where I was taking a route around a flooded closed road and ended up driving gently downhill across the river flood plain on a minor road, in ever deeper water until I turned back.
..and the wheel bearing failed a few weeks later..
Ancient vehicles and vessels
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Dec 26, 2023 12:27 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
I pack a lot of wheel bearings. The cars with wheel bearings like this are all missing their speedometer cable sealing goop.
Most of them have surface corrosion on the spindle axle too.
Robbie
www.airschooled.com
SGKent is offline
PostPosted: Tue Dec 26, 2023 2:25 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
you should see the inside of the front axle beam and the rear torsion tubes if you like to ford streams etc.. Been there. Its ugly if you don't get to it quickly. There isn't enough heat to drive any moisture out.
And for those of you who haven't owned boat trailers, the way it works is the air and grease in a wheel bearing heats up. When cold water hits the axle, the air and grease cool, which creates a small vacuum inside the hubs. That draws in water. You can't avoid it unless you have pressurized hubs, like Buddy bearings. There are special marine wheel bearing greases that are designed to help protect the bearings. Use it if you plan on offroad etc crossing streams or parking in river beds during flood season.
Rusted out beams and torsion tubes are not something a bus owner wants to confront.
SK
vwuguy
vwuguy is offline
PostPosted: Tue Dec 26, 2023 2:59 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
Smile
Xevin is offline
PostPosted: Tue Dec 26, 2023 3:56 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
vwuguy wrote:
like struthers said paypal donate cash i'll make more vids help a poor hippy out
https://www.paypal.com/donate/?business=KXABXKUNRZ...y_code=USD
It’s Boxing Day in Canada. Go out to Juggle Mart and get that BOGO faux bowling pin. Maybe stock up on 10 glow sticks for a loonie.
Keep on Busin'
SGKent wrote:
vwuguy
vwuguy is offline
PostPosted: Tue Dec 26, 2023 8:45 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
I think it states in one of the manuals ratwell or idiot manual to pack the speedo cover, that thing you tap onto the drum in the front and the cable goes through with grease, grease repels water. Would that solve the problem of the wheel bearing going bad?
NASkeet
NASkeet is offline
PostPosted: Wed Dec 27, 2023 8:55 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
I thought Boxing Day - 26th December was a purely British holiday; corresponding to the day when servants received a "Christmas Box" (i.e. gift or monetary bonus) from the family which employed them.
https://www.bbc.co.uk/newsround/46454700
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
Wildthings
Wildthings is offline
PostPosted: Wed Dec 27, 2023 9:11 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
Robbie
I learned years ago to always smear some grease on the spindle.
If the cable sheathing is old and cracked that can let water get to the bearings as well.
vwuguy
vwuguy is offline
PostPosted: Wed Dec 27, 2023 9:15 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
I think the stereotype may be In Canada we have Boxing Day it is a holiday. The day after christmas. Although some stores are open and they have massive sales example a big chain electronics has a some tv or computer or laptop or phone that goes on sale for 50%off. On that day there are huge line ups for stores that day and a lot of folks go out shopping for a major deal.. on stuff.. It can be fun if you like shopping eh! oh yeah and cip1 has a sale this week
Xevin is offline
PostPosted: Wed Dec 27, 2023 9:22 am    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
Yes Nigel and Christmas is a Christian festival that celebrates the birth of Jesus Christ. Somehow people find a way to capitalize on materialism. Kind of like the OP in his post asking for cash. He still wants money for his shaky video so we can offer help for free. Wink I think Erb lost the spirit of vintage VW ownership and the spirit of The Samba.
Keep on Busin'
SGKent wrote:
W1K1
W1K1 is offline
PostPosted: Wed Dec 27, 2023 3:30 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
reminds me of Randy on southpark trying to make some cash from his onlyfans Laughing Laughing
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
my59
my59 is offline
PostPosted: Wed Dec 27, 2023 8:38 pm    Post subject: Re: How to install a speedometer cable in your 1968-1979 bay bus Reply with quote
W1K1 wrote:
reminds me of Randy on southpark trying to make some cash from his onlyfans :lol: :lol:
Kinda like trolling for content:
https://www.thesamba.com/vw/forum/viewtopic.php?t=787245
For your podcast.
