casadelray Samba Member
Joined: July 26, 2015 Posts: 79 Location: Valdosta, Ga
Posted: Tue May 17, 2016 6:41 pm Post subject: Beetle Gas Heaters - lets see em' |
So maybe they're not the sexiest accessory, but they certainly are unique. Based on the various holes in my truck, I'm certain my 64 was modified to run a gas heater, but I'm not certain which one. Does anyone regularly use one? How many different models where available? Are parts readily available? Pro/Cons to having them? Thanks in advance! |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17551 Location: Left coast, Canada
Posted: Tue May 17, 2016 7:06 pm Post subject: Re: Gas Heaters - lets see em' |
Posted: Wed May 18, 2016 6:11 am Post subject: Re: Gas Heaters - lets see em' |
What model is that? Can it be mounted on the pass side too? Still use it? |
Bruce Samba Member
Posted: Wed May 18, 2016 11:08 pm Post subject: Re: Gas Heaters - lets see em' |
casadelray wrote: |
It is a B2 heater.
You could probably mount it on the roof it you wanted to, but why would you? It fits perfectly where it is designed to fit. It does not fit anywhere else. _________________
panicman Samba Member
Joined: December 18, 2011 Posts: 2600 Location: Canby, OR
Posted: Thu May 19, 2016 11:39 pm Post subject: Re: Gas Heaters - lets see em' |
Here is the eberspacher installed on my '60. I traded it for a few old Sapphire radios. I welded the holes shut.
I also got a replacement gas tank. |
Posted: Sat May 21, 2016 8:19 pm Post subject: Re: Beetle Gas Heaters - lets see em' |
Do you all use your heaters? Pros/Cons? |
rsthj Samba Member
Posted: Sat May 21, 2016 10:44 pm Post subject: Re: Beetle Gas Heaters - lets see em' |
Here are a few pictures of a B2 in my '63:
I drove this bug year round in Fairbanks, AK for about 10 years and the heater made it very doable. The old ones are simple and put out serious heat.
Cons? A furnace directly above your gas tank might cause unpleasant issues in a collision. For me, parts are not a problem as I have a few spares:
Bruce Samba Member
Posted: Sat May 21, 2016 11:40 pm Post subject: Re: Gas Heaters - lets see em' |
This is the only heat this car has. Does fine in the mild climate around here. _________________
