MicBergsma's 67 Bus Restoration Thread
Page: 1, 2, 3 ... 13, 14, 15  Next
MicBergsma
MicBergsma is offline
PostPosted: Fri Jun 10, 2016 8:50 am    Post subject: MicBergsma's 67 Bus Restoration Thread Reply with quote
Hey guys I want to be like Matt's thread ( Longboardluv ) Laughing Razz but it will be more videos than pictures
First video
Second video
Third video
Fourth video is coming soon!
1967 VW Bus walk-thru 21 window deluxe
Restoration series on YouTube right now!
YouTube videos > http://bit.ly/2g0E5b5
Instagram > http://bit.ly/2gHjIOV
Facebook > http://bit.ly/2Q9atMs
MicBergsma
PostPosted: Sat Jun 11, 2016 5:57 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
zozo
zozo is offline
PostPosted: Sat Jun 11, 2016 7:32 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Great videos!
Looks like a great project.
Nubby
Nubby is offline
PostPosted: Sat Jun 11, 2016 6:30 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Looks like a fun project!
Pinetops
Pinetops is offline
PostPosted: Thu Jul 21, 2016 8:04 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
I dig your bus! I hope you'll keep us updated.
"A rolling bus gathers no rust."
MicBergsma
PostPosted: Mon Nov 07, 2016 10:55 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Right now I'm working on front end
Remove wheels, brake, spindles, and torsion arms so I can replace all the seals and got spindles flipped to low bus 3.5" (more videos coming soon)
Videos filmed at 4K on iPhone 6s Smile
Pinetops
Pinetops is offline
PostPosted: Mon Nov 07, 2016 1:32 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
I enjoy the videos, thanks for making them.
I know how it is trying to work without a garage and in the dirt. Thankfully I have a little bit if area (not much!) to work on my stuff now.
I'd be tempted to make a fine gravel pad and get one of those cheapish metal carports if I were you. Sometimes you gotta just go with what you have though!
derRHDmeister
derRHDmeister is offline
PostPosted: Tue Nov 08, 2016 3:31 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Hey Mic- Great videos!
I want to emphasize not to do MUCH bodywork on it. You mentioned the football trick for the nose- it is the ONLY thing you need to do. DO NOT cut out or put on a new nose skin because it is a solid patina ride. It is by far much more desired that way. Even with some dents or wrinkles, that only shows the character of the car. It took this long enough for the character to build to this point. For rust holes or anything of concern, just patch and BLEND in. Dont worry about perfection because you will be too busy having a blast in this iconic VW bus! Look up on how others did that technique- (Blending )
Try not to lower it too much, defeats the purpose of having a bus which can do MORE terrains with the stock height. Depends on how you plan to use the bus....
Looking forward to seeing your progress here!
Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote:
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt.
Check us out on Instagram:
@DeafVolks
@BarndoorBuggy
Pinetops
Pinetops is offline
PostPosted: Tue Nov 08, 2016 4:10 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Just to add another opinion on this:
To some it's more desirable, to others it's not. It is definitely good advice to consider the end result before diving in to body work.
I say repaint it if you want, or leave the patina if you want. It's your bus. There's no need to feel obligated either way on this one in my opinion.
Some of the rust just plain needs to be repaired sooner or later. Then again, like the above poster said, metal repair can be blended convincingly with some care if that's the route you choose.
deadwesty
deadwesty is offline
PostPosted: Tue Nov 08, 2016 4:28 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
I enjoy the videos, its good to see another ASL user. I don't have to read the captions for once! Very Happy
I love your patina bus, I agree with derRhdmeister - I would repair/blend the rust areas and show off that sick patina! You can always repaint it again and again.
Not to mention, you will save thousands in paint job by going with the blending route. I have seen some buses in worse shape than yours come out really good in their original paint on this website.
Either way, enjoy your journey - it can't get better than working on a split bus. I will be watching for your process!
Btw check out deafvolks on instagram and fb!
Instagram- @vwwanderers
1986 westy syncro
1990 tin top syncro
silkvw
silkvw is offline
PostPosted: Tue Nov 08, 2016 8:00 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Keep up the good work as best as you can. There is a bunch of us in the Austin area doing the same kind of thing you are doing.
Once it's up and running, you can enjoy your bus, and even do some body work if you like.
'64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight=
6sixTinBox
6sixTinBox is offline
PostPosted: Tue Nov 08, 2016 8:25 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Always enjoy your videos, very cool. I'm the guy that subscribed to you on youtube when you asked me about lowering a bus. I'm "scasillas"
-Serg
1966 13 Window Deluxe
Comparison is the thief of joy - Theodore Roosevelt
John 14:6
zozo
zozo is offline
PostPosted: Tue Nov 08, 2016 9:00 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Man, I hate to see you working in the dirt with the wet winter coming. If you were closer to San Antonio, I've got an empty bay in my garage you could use. Keep up the good work on that beautiful bus.
Mr. Electric Wizard
Mr. Electric Wizard is offline
PostPosted: Thu Nov 10, 2016 6:30 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Hello, from another AUSTIN SPLIT BUS dude!
"Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper
Mr. Electric Wizard
PostPosted: Thu Nov 10, 2016 6:33 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Did you buy this bus from a guy named Andrew Barnes in Poteau?
~ Cullen Hightower
Pacmanfever
Pacmanfever is offline
PostPosted: Thu Nov 10, 2016 8:07 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
Loved your past videos with the drones, can't wait to see the progression of your bus project.
Rock on!
Malokin Martin
Malokin Martin is offline
PostPosted: Thu Nov 10, 2016 2:23 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
This is all around a great thread. Really looking forward to updates. I appreciate the time it takes to edit this into a video and the fact that you're doing it outside, in the grass, by yourself is commendable.
One bit of advice for you: Now that you aren't using the wheels anymore, stack two of them together and put them under the bus (not touching the vehicle). That way if the bus falls or shifts off the stands, it will still probably hurt you, but it won't kill you.
OG67westy
OG67westy is offline
PostPosted: Thu Nov 10, 2016 3:56 pm    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
^^^This!!
'67 Westy pearl white "Greta"
'67 Westy velvet green "Ken's bus"
'74 Thing blizzard white "Schatze"
'61 Panel dove blue"Rche"
'65 Bug rusty"Tina"
'83 Porsche 944
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Fri Nov 11, 2016 3:40 am    Post subject: Re: MicBergsma's 67 Bus Restoration Thread - Austin, TX Reply with quote
I don't know how I missed this but I'm really excited about your progress. Popcorn
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
MicBergsma
PostPosted: Tue Dec 04, 2018 1:05 pm    Post subject: Episode 1 video Reply with quote
Wow guys sorry I disappeared for two years! haha.. I can't believe that! I finally got time to edit a video of what's been going on with my bus project! So here's episode 1 video! Will be posting more episodes soon and continuing to do so as the project continues!
Page 1 of 15
