how to install a crankstart on a 1600 motor
vwuguy Premium Member
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Thu Jun 23, 2016 5:29 am    Post subject: how to install a crankstart on a 1600 motor Reply with quote
Hi,
I am interested in instal;ling a crankstart on my 1600 motor. Does anyone know what kind of crankstart nut i need. Is it he samer as a 36hp?
thanks erb
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
Tcash
Tcash is offline
PostPosted: Thu Jun 23, 2016 9:25 am    Post subject: Hand Crank Reply with quote
url=http://www.thesamba.com/vw/forum/viewtopic.php?p=8125030#8125030]Hand Crank[/url]
Semper_Dad wrote:
Found 1. The crank shown is for a Bus or Beetle. The Thing (181) crank has an additional "tit" on the end of the crank. I don't believe any real rear tin will have the fresh air holes because all the military 181s had gas heaters. I could be wrong.
Bus Boys list the bolt fitting "111-105-263A Bolt, Crank Pulley 1200-1600"
JK list the same nut for all beetles 46-98.
http://www.justkampers.com/111-105-263-a-crankshaf...2-bay.html
If you get a Industrial/181 crank you need the bolt with the hole through the center.
Crank start search
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
Forum searches
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
This is an idea I had. Have not tried it yet.
But use these to crank the generator.
Craftsman 18 in. Speeder Wrench, 1/2 in. Drive
Stanley Proto J5447 1/2-Inch Drive Reversing Ratchet Adapter, 2-21/32-Inch
1/2" Drive 20-Tooth Ratchet Adaptor
Craftsman 13/16 in. Easy Read Spark Plug Socket 1/2 in. drive
Good luck
Tcash
Tom Powell
Tom Powell is offline
PostPosted: Thu Jun 23, 2016 11:48 am    Post subject: Re: how to install a crankstart on a 1600 motor Reply with quote
https://www.youtube.com/watch?v=PI46qVW2WA4
Aloha
tp
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jun 23, 2016 12:13 pm    Post subject: Re: how to install a crankstart on a 1600 motor Reply with quote
haven't touched a car with one of those since one was abandoned at my grandparents motel in 1959. All I remember is that my grand dad said he knew more guys who busted their wrists using a crank starter than in football and boxing combined. He showed me how to avoid ending up with a broken wrist if I ever used one. Kinda the same theory of pulling a prop thru with your open hand and not closed fingers lest you loose them if the blade kicks back.
Photo from www.abarnyard.com. Never push down, do pull up. One hand not two, notice the thumb is tucked under the handle to keep from breaking the thumb or wrist if it kicks back.
George Carlin:
Skills@EuroCarsPlus:
