kevlarian Samba Member
Joined: October 16, 2014 Posts: 636 Location: Orange County, CA
Posted: Sat Jul 02, 2016 9:33 pm Post subject: Calling engine experts |
I give up. Let me start with all the BRAND NEW parts I've purchased in the last 30 days:
- Bosch Blue Coil (good one... not the crappy one)
- Bosch (German) Plug Wires
- Bosch Spark Plugs
- Distributor (High Quality) 009
- Points / Condenser
My engine:
- 1914cc
- Kadron Dual Carbs
Now, what I've tested...
- I did a compression test on all four Cylinders, all of them were between 120-125 psi.
- I did a valve adjustment
- Carbs are balanced
*** PROBLEM ***
When I pull plug wires 1 or 3 the engine runs exactly the same at both idle and under acceleration. I can pull BOTH 1 & 3 it still runs... with little to no difference.
Pulling 2 or 4, the engine can barely run...
It would appear that I am running (basically) on 2 cyls, but I can't figure out why. I have compression on all four cylinders... I'm getting a spark to all four...
No oil leaks, at least no more than normal
So... what next!? What do I test. Is it my Heads?... what possibly could it be. |
Brian Samba Moderator
Posted: Sat Jul 02, 2016 9:46 pm Post subject: Re: Calling engine experts |
This happened to me a while back, taking off 1 and 3 made 0 difference. I ended up just doing the basics: valves, static timing and dwell. I have dual FRDs and they were ""tuned"" how are the Jets on the kads?did you do the $1.98 tune up or dump ATF down the carb throats?
You have compression, so all you have left to rule out is fuel and spark.
High quality 009? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Sat Jul 02, 2016 9:59 pm Post subject: Re: Calling engine experts |
I'm no expert, but from what I do understand there is a big difference in how #3 and #1 run compared to #2 and #4 UNLESS you have some sort of intake that treats each cylinder separate (like IDF's or Mexican EFI.)
Whenever you have dual carbs, such as in your case, the engine starts intake on #4 or #2, which starts with no air nor fuel flowing and must get the air and fuel starting to flow through the carb on that side, then that cylinder closes and it goes to #3 or #1, which starts out with air already flowing through the carb and so therefore gets more air and usually a richer AFR.
So because of this #1 and #3 cylinders usually put out more power.
But ya. If it's very noticeable it's probably bad spark on one or both of those cylinders. Or possibly too lean? _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine?
Posted: Sat Jul 02, 2016 10:02 pm Post subject: Re: Calling engine experts |
Oh not to scare you or anything, but 1 and 3 share the same cam lobe. So just something to think about. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Sat Jul 02, 2016 10:06 pm Post subject: Re: Calling engine experts |
| Brian wrote: |
| Oh not to scare you or anything, but 1 and 3 share the same cam lobe. So just something to think about. |
Thanks for bringing that up!
So yes, you'd probably want to check your rocker arm movement. Make sure they all move the same as you turn the engine.
And that brings up one other thing. Usually the most common reason for a poorly running VW AC engine that I've seen is a bad valve adjustment. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Sat Jul 02, 2016 10:10 pm Post subject: Re: Calling engine experts |
When you asked the same thing last week you just complained it idled on 2/4, which is normal for kadrons.
This time, you have also added the word "acceleration", which would seem to mean, you drove it with a spark plug disconnected, and noticed no difference. Is this true? |
Posted: Sat Jul 02, 2016 10:27 pm Post subject: Re: Calling engine experts |
| modok wrote: |
Yup! Been troubleshooting everything I could think of... Even pulled 1&3 at the same time. Pretty sure the aren't actually doing anything.
About the Kads and 1&3. Ho the hell can a carb know which cylinder is firing. |
Posted: Sat Jul 02, 2016 10:29 pm Post subject: Re: Calling engine experts |
| Brian wrote: |
Ya. I was told that when I started this troubleshooting jorrney... I'm hoping it isn't that. That would suck. |
modok Samba Member
Posted: Sat Jul 02, 2016 10:39 pm Post subject: Re: Calling engine experts |
When did the problem start?
How slow is it? |
Posted: Sun Jul 03, 2016 12:29 am Post subject: Re: Calling engine experts |
| modok wrote: |
How slow is it? |
It has been getting progressively harder and harder to start. That is why I have been replacing all these parts... Over the past 6mo or so. |
modok Samba Member
Posted: Sun Jul 03, 2016 2:09 am Post subject: Re: Calling engine experts |
Could be you have a flat lobe.
Check valve lift.
So, summary of problem:
A-it's getting slower
B-it's hard to start
C-both? |
wcfvw69 Samba Purist
Posted: Sun Jul 03, 2016 6:54 am Post subject: Re: Calling engine experts |
Have you checked for a vacuum leak on that side carb? I had dual 44's on an engine. Same symptoms you're experiencing. I found that side carb was bolted tightly to the head. Once I snuged it down, the vacuum leak was gone and it purred.
It's a quick check to insure you have no vacuum leaks. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Jul 03, 2016 7:49 am Post subject: Re: Calling engine experts |
| wcfvw69 wrote: |
It's a quick check to insure you have no vacuum leaks. |
Dual carbs don't usually feed #1 and #3 or #2 and #4. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sun Jul 03, 2016 8:32 am Post subject: Re: Calling engine experts |
| try pinching off the balance tube from manifold to manifold and see what happens. |
Posted: Sun Jul 03, 2016 12:04 pm Post subject: Re: Calling engine experts |
I recently checked the manifolds, and the carbs to make sure there were no air leaks. We're solid there.
Remember 1 & 2 share a carb, and 3 & 4 share a carb. My problem is with 1 & 3... so that really isn't a carb issue. Someone indicated that 1 & 3 don't work right with Kads, but I have never heard that from anyone.
What else can I test? Would a full leak down be the next test? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20902 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jul 03, 2016 12:17 pm Post subject: Re: Calling engine experts |
Look up "recursion" (I think the term is) its where one cylinder (per side of single throat carb on dual port head/manifold) will rob all the fuel function and starve the other cylinder... Pretty common problem with single throat carbs on dual port heads and usually 2&4 will prevail over 1&3 for some reason... Balance tube is supposed to help... But...
Get dual throat carbs (Weber IDF or EMPI HPMX) and it will do away with the problem, but then its a whole new tuning game for you...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 486 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Sun Jul 03, 2016 2:38 pm Post subject: Re: Calling engine experts |
| kevlarian wrote: |
I'm not engine expert but I'll give it the old college try
You didn't mention anything about the engine losing power... It would be almost impossible to run only on two cylinders.
Think about 850cc instead of 1900cc.
I don't like this technique of pulling cables -- at least for the 2x1bbl carbs I have -- because it's hard to come with any meaningful conclusion.
After making sure the resistance of the cable is on specs and there is a nice and blue spark I just install it (after lubricating with dielectric grease) and let it alone. Pulling and reinstalling cables will only stress it's internals.
Look elsewhere if it's hard to start. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Sun Jul 03, 2016 2:47 pm Post subject: Re: Calling engine experts |
did you try swaping 1&3 wires? , or replacing the plugs? check cam? |
Posted: Sun Jul 03, 2016 2:57 pm Post subject: Re: Calling engine experts |
Kads idle on 2 cylinders. VW firing order is 1-4-3-2, or 4-3-2-1. 4 before 3, and 2 before 1. By the time the valve opens for 3 and 1, there's nothing left. Dual 2bbls do not have this problem. So all the idling is driven by 4 and 2. 3 and 1 do nothing until the throttle is opened.
Pull a plug wire on 4 or 2, and it's now idling on ONE cylinder. Pull a wire on 3 or 1, and there's no difference.
This is pretty much the case with all dual 1bbls. It's one of the reasons I don't like dual 1bbls, unless you have no choice (like a single port).
If the VW firing order was alternating each side, instead of 2-1 on one side, then 4-3 on the other, it wouldn't have this characteristic. But it does, and it's shocking that more guys don't know about it. It's not rocket science.
I suspect your hard starting is fouled plugs from jetting which is too rich, and/or plugs which are too cold. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Last edited by [email protected] on Sun Jul 03, 2016 3:03 pm; edited 1 time in total |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Sun Jul 03, 2016 3:02 pm Post subject: Re: Calling engine experts |
Trying to think out loud here.
Kads with a balance tube.....solid like new or cut and held together by a hose slamp.....have seen that with a problem
Have seen where a person had a vac leak there affecting both Carbs.(toss up)
Intake man for a SP or a DP head. (one hole or split man)
I read a vac leak. Try to hold the RPM high while spraying/dripping gas in the Carb throat. If it picks up then there was a vac issue. If it dogs you know nothing wrong there.
Opposing cyls is the key here.
What is there in common to effect opposing cyls? |
