retterath Samba Member
Joined: July 19, 2004 Posts: 661 Location: SW Washington state
Posted: Thu Jul 28, 2016 8:45 pm Post subject: Brake ID help needed |
I'm working on the rear brakes of my baja, but none of this looks familiar to me. I think the PO said he used bus parts. When did buses come with rear discs w/ 4 lug wheels?
Could these be Ghia calipers?
ATE 93 vw?
ATE 52?
Stock wheels will not fit over the calipers.
Thanks. |
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 479 Location: Mohave Valley, AZ.
Posted: Thu Jul 28, 2016 10:41 pm Post subject: Re: Brake ID help needed |
Looks like a brake drum was turned down into a hub, and a brake rotor (hat) fitted on. I have done the same thing with 280Z rear brakes. Very easy to do. No idea what your parts actually are though.
The jack is Harbor Freight. _________________ Go outside and do something. |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4627 Location: Fair Oaks/Orangevale, CA
Posted: Fri Jul 29, 2016 4:56 pm Post subject: Re: Brake ID help needed |
What I see you have, looks like what I first saw in the early 1970s on
buggies.
What was done then was to take the center hub from a type III 4lug rear brake drum (the outer part of drum bolts on to hub), and turn the outer diameter to fit inside a 914 rear disc brake rotor. The calipers that were used at the time were from the front of a type III. Measure pads and you can tell if this is correct.
CB Performance sells a kit that does the same thing. #4272 is one for a IRS setup. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Fri Jul 29, 2016 11:58 pm Post subject: Re: Brake ID help needed |
| Well, look at that! I think we have a winner. |
