is the wider base bracket for thermostat a 25hp/early 36hp thing
BulliBill
BulliBill is offline
PostPosted: Fri Jul 14, 2023 9:42 am    Post subject: is the wider base bracket for thermostat a 25hp/early 36hp thing Reply with quote
I found one of the "oddball" thermostat brackets...
Notice the stock narrower 30bhp/36hp bracket and then the much wider base bracket. I suspect that maybe this wider base bracket fits 25hp or perhaps the earlier 36hp engines?
Both are the round hole (for the crankcase stud) "non-adjustable" type, and both fit the same on a 36hp crankcase. Can anyone identify and shed light on when/what era the wider base bracket was used?
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
virtanen
virtanen is offline
PostPosted: Fri Jul 14, 2023 10:13 pm    Post subject: Re: is the wider base bracket for thermostat a 25hp/early 36hp thing Reply with quote
As far as I know the wide model was in use from May 1950 to Jan 52.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
drpete
drpete is offline
PostPosted: Sat Aug 10, 2024 4:26 pm    Post subject: Re: is the wider base bracket for thermostat a 25hp/early 36hp thing Reply with quote
A wide one came with the '51 standard sunroof 11e that John Henry sold to me.
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sun Aug 11, 2024 12:25 pm    Post subject: Re: is the wider base bracket for thermostat a 25hp/early 36hp thing Reply with quote
Progressive Refinements says that the simplified (smaller) holder was used in a number of cases beginning on 18 Jan 1952, and it was fully adopted in production on 23 Jan 1952.
- Zeuxius, 400 BC
