andersencollectibles Samba Member
Posted: Sun Sep 04, 2016 12:49 pm Post subject: Syncro VIN decoding - need help |
Gang how can i tell by the vin if the car is a Syncro?
Anyone has the combo? and knows the tell tell, without looking at the M options plate?
thanks |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Sun Sep 04, 2016 1:19 pm Post subject: Re: Syncro Vin decoding need help |
andersencollectibles wrote: |
thanks |
You can't. But if the digit for production place is a "G" for Graz, Austria you are pretty sure. Not 100% though as there were a few 2wd vans produced in Graz as well. _________________ 1991 VW Multivan syncro 1,9 TD |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6930 Location: Fort Lauderdale, Fl.
Posted: Sun Sep 04, 2016 6:19 pm Post subject: Re: Syncro Vin decoding need help |
http://www.gowesty.com/tech-article-details.php?id=110
A bit about Vin decoding. This article from GW will tell you.
_________________ This free advice is worth exactly what you paid for it.
Posted: Sun Sep 04, 2016 6:48 pm Post subject: Re: Syncro Vin decoding need help |
Some more notes on it i collected from somewhere.
Notes:
a) The four Z's stamped into your vehicle's chassis are simply filler digits during initial assembly ~ all VWs are built this way. During final assembly, the vehicle receives its official VIN that you see on the dash: For USA/Canada, the Z's are replaced by the required digit information; for all other countries, the Z's remain (countries outside North America do not require the info provided by digits 4, 5, 6 & 9). If the rest of the VIN matches up to the dash and/or door jamb VIN, everything is fine.
b) Chassis number: Chassis number is specifically the year digit + sequential production number digits in the VIN. Many times parts are dependent upon your car's chassis number, which is VIN-dependent, often called a VIN-split. An example of this:
To 25-E-11290
From 25-E-11291
The "25" is not always used. The "To E-11290" would indicate the part is for all Vanagons up to 1984 (E) with VIN sequential production number of 11290.
c) All 1981+ Vanagon VINs are 17-digits and begin with "WV".
VINs outside North America, and the VINs found stamped into the rain tray (or crossmember) of all water-cooled VWs with 17-digit VINs, contain four "Z"s. For North American VWs, these are merely filler digits. The rain tray VINs were standard issue as the cars rolled off the initial phase of the assembly line; the only difference between these standard-issue model-year VINs is the sequential production number. Locations outside of the USA & Canada do not require the same VIN information (many locations, including Europe, still require only a 13-digit VIN) and, therefore, use filler digits during stamping to make the initial assembly process easier and faster.
For example, if 30,000 Cabriolets were built for the 1985 model year, the first Cabriolet built for that year would have WVWZZZ15ZFK000001, while the last 1985 Cabriolet would have a WVWZZZ15ZFK030000 stamped into the rain tray. As the cars went through final assembly, they received their official, individual VINs based on their destination; it was at this time that North American Cabriolets obtained their non-"Z" VINs, while cars destined for sale in Europe received the "Z" VIN on the door plate, the dash plate and on the build sheet. Using the same example, that first 1985 Cabriolet was destined for, let's say, the USA; it's official VIN would be WVWCA0158FK000001 (the internal check code varies and may not actually be an 8 ). The last Cabriolet for 1985 was destined for, let's say, Italy; it's official VIN would be WVWZZZ15Z030000.
The Westmoreland plant followed the same VIN stamping procedures as all other VW factories; therefore, all USA-built VWs will also contain filler Z's in the stamped VIN, regardless of the model. _________________ This free advice is worth exactly what you paid for it.
OddN Samba Member
Posted: Mon Sep 05, 2016 2:17 am Post subject: Re: Syncro VIN decoding - need help |
Another thing, both the model year and assembly plant uses letters, and some of them are the same, so dont get over excited when you see a "G" in the VIN: An -86 2wd produced in Hannover has GH***** in the VIN and an -87 syncro from Graz has HG***** in the same place.
The link in Steves post contains an extended list with all the digit alternatives listed. _________________ 1991 VW Multivan syncro 1,9 TD |
iathon Samba Member
Posted: Wed Nov 28, 2018 12:57 pm Post subject: Re: Syncro VIN decoding - need help |
Okay so the last digits of a van I am looking at is 4GH056073 SO this is a 2wd ???? _________________ Iathon |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10374 Location: Orbiting San Diego
Posted: Wed Nov 28, 2018 1:28 pm Post subject: Re: Syncro VIN decoding - need help |
That Vin# is from a Hanover made vehicle so not for a Syncro.
Don't go by just the dash vin# though, always check the others since the dash or the dash vin plate are easily moved between vehicles.
Also, some very late 2wd were built in Graz so they have a G for Graz but are not Syncro. AFAIK, some 90/91/92
Mark
iathon wrote: |
Okay so the last digits of a van I am looking at is 4GH056073 SO this is a 2wd ???? |
caravelle c Banned
Joined: November 03, 2014 Posts: 153 Location: Bavaria-Germany
Posted: Wed Nov 28, 2018 1:32 pm Post subject: Re: Syncro VIN decoding - need help |
iathon wrote: |
Yes, it's a 2wd from 1986 MY. |
