Ball joint on 72 Super Beetle...no come out!
72VWSB
72VWSB is offline
PostPosted: Mon Oct 12, 2020 3:16 pm    Post subject: Ball joint on 72 Super Beetle...no come out! Reply with quote
Replacing front end parts on my 72 SB. I am replacing struts and ball joints. The left ball joint came out very easily but the right one isn't! Do you use a ball joint removal fork or is there a better tool for the lower ball joint?
72 VW Super Beetle
Hatracks
Hatracks is offline
PostPosted: Mon Oct 12, 2020 3:22 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
I have one of these and its never failed me:
https://www.amazon.com/GEARWRENCH-3916D-Universal-Joint-Separator/dp/B003YVWHOE
73 Super Build
70 Westy Build
rayjay
rayjay is offline
PostPosted: Mon Oct 12, 2020 4:38 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Harbor Freight has the same tool if the op has one close by. I bought one last week and it works great on a std beetle ball joints and tierod ends.
72VWSB
72VWSB is offline
PostPosted: Mon Oct 12, 2020 5:12 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Thanks guys...we have a harbor freight in town, get one tomorrow...thanks again!
72 VW Super Beetle
infiniteLoop
infiniteLoop is offline
PostPosted: Mon Oct 12, 2020 5:55 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
A two arm puller should do the same thing. You could try putting the nut on until it is flush with the stud and smack it with a hammer.
rayjay
rayjay is offline
PostPosted: Mon Oct 12, 2020 5:59 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Don't just keep cranking on the bolt until you break the tool. If it doesn't pop loose with a good amount of torque applied to the bolt then start tapping on the control arm boss with a hammer so you induce some vibration which will help the taper pop out.
72VWSB
72VWSB is offline
PostPosted: Mon Oct 12, 2020 6:45 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Thanks for all the advise...
72 VW Super Beetle
72VWSB
72VWSB is offline
PostPosted: Wed Oct 14, 2020 2:31 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
I am happy to say, I was able to get the ball joint out with a ball joint removal tool I borrowed at Autobone...all the struts are installed including my steering damper. The car drives much nicer now. I used to have a bit of a wheel shake when hitting bumps, now everything is nice and smooth!
72 VW Super Beetle
halfassleatherworks
PostPosted: Wed Oct 14, 2020 4:44 pm    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
now get a alinement done
72VWSB
72VWSB is offline
PostPosted: Fri Oct 16, 2020 5:59 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Curious...why would I need to do another alignment after changing the front struts?
72 VW Super Beetle
72VWSB
72VWSB is offline
PostPosted: Fri Oct 16, 2020 6:01 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
And while I'm at it...it appears my front end is a bit higher than it was before the front strut replacement...and I have never changed the rear shocks. If I replace the rear shocks, would that bump up my rear end a little bit to even it out??
72 VW Super Beetle
infiniteLoop
PostPosted: Fri Oct 16, 2020 6:20 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Replacement struts are gas charged or old struts were binding?
1302s have the camber adjustment on the inside of the control arm.
72VWSB
72VWSB is offline
PostPosted: Fri Oct 16, 2020 6:48 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Not sure what you mean...the original struts were leaking...the new ones I got as a kit from Jbugs...doesn't say if they are gas filled or not...
72 VW Super Beetle
infiniteLoop
PostPosted: Fri Oct 16, 2020 6:57 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Struts can get worn so severely that they will actually bind in their travel. Maybe you could compare the strut mounts for height if they were replaced. Ball joints could actually bind and limit travel but if the car steers fine that would be ruled out.
Cusser
Cusser is offline
PostPosted: Fri Oct 16, 2020 8:45 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
I had a sagging rear end too (on my '71 Super Convertible, not my own pristine rear end !!!) and I have used Gabriel Hi-Jacker rear shocks for about 15 years now; I can add air to raise rear end, or remove air to lower the rear.
Moderators would object if I posted a photo of my own rear end....
72VWSB
72VWSB is offline
PostPosted: Fri Oct 16, 2020 9:39 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
I was amused that you had to be specific which rear end you were talking about! Very Happy I read some comments on Jbugs where the coil overs are a little rough...but you like the Gabriel Hi-Jackers? They're not too rough? Where do you put your air inlet? Not sure where to look for a set that will fit!?
72 VW Super Beetle
Hatracks
Hatracks is offline
PostPosted: Fri Oct 16, 2020 10:26 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
check the rear bushings if see if C is crushed:
73 Super Build
70 Westy Build
72VWSB
72VWSB is offline
PostPosted: Fri Oct 16, 2020 11:35 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Sooo...one needs to have front end realigned after replacing front struts and lower ball joints?
72 VW Super Beetle
Hatracks
Hatracks is offline
PostPosted: Fri Oct 16, 2020 11:38 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
I do anytime i mess with the front end especially after changing ride height. It is cheap insurance.
73 Super Build
70 Westy Build
72VWSB
72VWSB is offline
PostPosted: Mon Oct 19, 2020 8:01 am    Post subject: Re: Ball joint on 72 Super Beetle...no come out! Reply with quote
Thought I'd post an update. After my ball joint/front struts/steering damper replacement, I noticed a slight steering wheel shake at about 40mph. It smooths out past this speed. I have an appointment to get the front end re-aligned and a friend of mine told me to check the front bearings. I had replaced the front disc brakes with disc brakes a few months ago using all new bearings. Well, the left front was ok but the right one was loose! I had to tighten the locknut about 1/4 turn. It did not however fix the slight steering wheel shake but hopefully after I have it aligned and the front wheels checked for balance, I should be good to go... It did not have this shake at all before the strut replacement...
72 VW Super Beetle
