Franklinstower Samba Member
Posted: Thu May 25, 2023 4:28 pm Post subject: Re: Official Fuel injection questions thread |
damn it...it wasn't a loose wire connection at the TS2 after all, the TS2 spacer corroded the threads to dust in the head.
So, JB Weld? Helicoil? Timesert? I am not sure if JB weld, being an epoxy would be conductive.
What have others done? _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51182 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu May 25, 2023 7:11 pm Post subject: Re: Official Fuel injection questions thread |
Thread repair coil or insert of some sort, JB weld won't do it there.
Have a look at the RH head near #1 cylinder, if they are aftermarket heads there may be another sensor hole there already.
If not you'll have to fix that hole, M10X1.0 is the size and pitch. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 29, 2023 9:24 pm Post subject: Re: Official Fuel injection questions thread |
To finish this up with a happy ending... I found these sleeves: m10x1 - 12x1. Reemed and tapped the head, got the new TS2 installed, and it's running perfect again.
Calipeet Samba Member
Posted: Tue May 30, 2023 5:11 am Post subject: Re: Official Fuel injection questions thread |
Hi everyone! Looking for advice on a 1979 Super Beetle. No power to the fuel pump, after troubleshooting through all steps in my Bentley Manual, we determined the double relay is bad. I have been searching all over the internet for a replacement, but they are all back ordered or out of stock. Is there a known work around? Perhaps two individual relays that fit? Or does anyone know of a reputable place that has them for sale?
Posted: Tue May 30, 2023 9:33 am Post subject: Re: Official Fuel injection questions thread |
Yes, little brown wire is connected to ground. I can’t remember which, but it was either terminal 88y or 88d that didn’t light up on my test light upon cranking. All other terminals seem to function. I followed the Bentley troubleshooting to a tee.
Will the double relay specified for a bay window work the same in the beetle?
Thanks for your help. |
christyxy Samba Member
Posted: Sun Jun 04, 2023 11:04 am Post subject: Re: Official Fuel injection questions thread |
Had my 79 FI cabriolet a year now, running quite well. I realised my double relay has been bypassed for the fuel pump by a previous owner... The rear window seal was leaky so I think the relay got wet or something (I've replaced the seal now) and when a new fuel pump was installed, whoever did it chose not to hook it up to the double relay for some reason.
The wires to my fuel pump are instead hooked up directly to the car battery, with I think a single relay in line so that you hear the fuel pump come on when I turn the key to first position before ignition/starter motor engages. I've been told it's kinda dangerous, as the fuel will keep pumping in the event of a crash/engine fire until the key is turned fully off. Runs and starts great for now though...
I have just acquired a replacement double relay from someone who recently sold their own FI bug, so will see about restoring it to factory spec in future. Just wanted to say that it clearly can be done without the double relay though as mine is like that. Can investigate the wiring set up more if you like, though there may be better advice for how to do it on here already...
Calipeet wrote: |
cfroderman Samba Member
Joined: November 23, 2021 Posts: 29 Location: Avon, IN
Posted: Tue Jun 13, 2023 5:28 pm Post subject: Re: Official Fuel injection questions thread |
Samba Experts - I've asked quite a few questions on here and have never been disappointed. Previous posts will explain the project. '76 SB Convertible. Still FI.
Problem - I've been driving this vehicle most of the summer with only a few hiccups. Primarily battling some faulty TS2 but I think I have that figured out. All of a sudden I'm now having trouble starting it and keeping it running. As of late, I would start it, it would run for a few seconds and then die. If I tried to use the accelerator to keep it running, the engine would sputter, be sluggish and backfire. As soon as I took the foot off the accelerator it would die. As I was working on it today, I did the following:
1. Added fresh fuel - No change. - Wouldn't start
2. inspected the distributor cap (pictures below). Cleaned the rotor cap with contact cleaner.
3. Verified that the fuel pump was working by depressing the AFM flap with the ignition on.
When I depressed the AFM flap, the fuel pump seemed to start at a higher pitch and then gradually go to a lower pitch. Maybe the fuel pressure was reaching equilibrium?
After 2 & 3, the engine started and ran smoothly at idle.
My question - Based on the photos of the distributor cap - Do I replace that or do I investigate fuel pressure , fuel filter, etc?
Posted: Tue Jun 13, 2023 5:49 pm Post subject: Re: Official Fuel injection questions thread |
I see nothing wrong with that cap, it doesn't even really need scraping with a knife to remove the green buildup. How do the points look?, got a spare condenser?, might be worth swapping just in case.
But that fuel pump sound may be something, is it just pressure bleeding off when sitting?, or a restricted tank outlet or filter choking the pump?, a pressure test while re creating that sound would be time well spent to start with. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9978 Location: Huntington Beach, CA
Posted: Tue Jun 13, 2023 6:22 pm Post subject: Re: Official Fuel injection questions thread |
Chase the fuel pump, if that is a possibility. But…..
I chased a poor starting/running issue for several months. Found a few issues during my battle with the car.
First issue was a burned through ignition rotor. If you have a no spark (intermittently) then, remove the rotor, flipped it so you are looking at the shaft input end and look for a very black spec, up inside that cavity! That is where spark is leaking out to the steel distributor shaft!
My next find, a few weeks later was a weak coil. No biggy there. Just a spark checker!
Next up was the morning the new Bosch blue coil died. Got a Pertronix coil and all good!
Next time it was just a no spark issue. Suspect of the old Pertronix distributor, I took a spare old Bosch points distributor out and plugged it into the car. Ground the body of the distributor with a wire clip. Attached the condenser lead to the coil, attached the high tension output to a spark plug (grounded to the engine). I then turned on the key and spun the Bosch distributor by hand. Sparks snapped across the spark plug! Changed out the distributors and it has been running better than it did, 2 years ago! Damn Chinese parts! When will I finally give up on the Chinese parts? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Jun 14, 2023 5:38 pm Post subject: Re: Official Fuel injection questions thread |
busdaddy wrote: |
But that fuel pump sound may be something, is it just pressure bleeding off when sitting?, or a restricted tank outlet or filter choking the pump?, a pressure test while re creating that sound would be time well spent to start with. |
Followup - Fuel pressure when manually manipulating the AFM and while running was 38-39. No drop in pressure after a few minutes. No weird pitch change on the fuel pump either. It is now running without a problem, which would probably rule out a fuel filter. All new fuel lines everywhere and I made sure no kinks in any of the rails. I did notice the fuel cap has gotten a little crispy where a gasket might have been. Wondering if some of that residue got into the fuel tank and is causing problems. Is there a screen on the outlet hose of the fuel tank? Maybe drop the fuel tank and inspect? Any other thoughts. Weird that it seems intermittent. |
Posted: Wed Jun 14, 2023 5:51 pm Post subject: Re: Official Fuel injection questions thread |
No screen in a FI tank, just a 5/16" pipe, but if there's a floatie in there like that little bit of plastic that comes on the top of fuel treatment bottles it could manage to get on the tip of the pipe and restrict flow temporarily. The modern way to find it is rent a snake style inspection camera and probe the tank. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Thu Jun 15, 2023 3:59 am Post subject: Re: Official Fuel injection questions thread |
Check all the above, also pay close attention to the hoses under the tank. Many times a noisy/humming pump is a kinked line, or clogged filter or tank outlet/return. A pressure check is in order, and will also let you know if the pressure regulator is working properly. |
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Tue Jul 25, 2023 4:49 pm Post subject: Re: Official Fuel injection questions thread |
Hello, does the FI intake plenum need to be split to be removed? I think I see a the edge of a nut down there. Thanks. |
Posted: Tue Jul 25, 2023 5:00 pm Post subject: Re: Official Fuel injection questions thread |
PuddleRainbow wrote: |
Yes, it does |
Posted: Tue Jul 25, 2023 5:06 pm Post subject: Re: Official Fuel injection questions thread |
MuzzcoVW wrote: |
Yes, it does |
Thanks much. |
Posted: Thu Jul 27, 2023 7:13 pm Post subject: Re: Official Fuel injection questions thread |
Removed the plenum. Oh boy if you got one don’t look too close. I’ll upload pics of 47 years of accumulated crud soon.
There was a gasket and I can’t find one for sale. I suppose a layer of Dirko should be enough to seal it back up? |
L51C_75 Samba Member
Posted: Thu Jul 27, 2023 8:11 pm Post subject: Re: Official Fuel injection questions thread |
I made a gasket from gasket paper from FLAP, and just sealed with Curil T, seemed to work so far. |
Posted: Mon Jul 31, 2023 6:35 am Post subject: Re: Official Fuel injection questions thread |
L51C_75 wrote: |
Thx will get the x-acto and bandaids set up! |
