b15605 Samba Member
Joined: February 24, 2009 Posts: 407 Location: Central GA
Posted: Mon Sep 29, 2025 6:06 am Post subject: Oil Leak - left side but not push rod tubes or oil cooler |
Dear All,
1973 Super Beetle with Stock 1600 DP: I have had a decent oil leak for a while. It is on the left side of the engine about mid way; therefore, I bought an oil cooler and seals, thinking this is my issue.
Yesterday, I went in to begin the work. I typically remove the decklid and doghouse with the engine in the car (find this easier, just an opinion). Anyway, once I got the doghouse off, I realized that there was not a drop of oil coming from the oil cooler area - it was clean. I looked underneath and confirmed there was an oil leak from simply moving the car in to the garage for this work. I decided wipe the engine down and then hook up the carb again and run the engine without the doghouse for ~30 secs (avoiding any overheating situation).
Indeed, the oil started running in a reasonable stream, but upon looking from the top, there was none from the oil cooler. Looking underneath, the stream begins above all pushrod tubes. The stream is essentially dead center of the #3 and #4 pushrod tubes (or between #3 and #4 piston). Because of the engine tin I cannot see well up in there nor is it visible from above.
I am in the process of pulling the engine (ran out of time yesterday), but once I get it down, what are my possible culprits???? Would appreciate your experience and guidance as this leak is too fast to continue driving the car on a regular basis and simply needs to be taken care of so I can daily drive my beetle again! |
vamram  Samba Member
Posted: Mon Sep 29, 2025 6:35 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Cracked case...? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
b15605 Samba Member
Posted: Mon Sep 29, 2025 7:13 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
| I was afraid someone may say that - hoping for something less significant... |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33367 Location: Hot Arizona
Posted: Mon Sep 29, 2025 8:10 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Remember that a stock 1973 DP engine will have 4 oil cooler seals, 2 are under the little adapter. If mine, I would focus on those (replace all four) because you say the oil "pumps" out, not drips. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
b15605 Samba Member
Posted: Mon Sep 29, 2025 8:47 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
| I will definitely take a look once I get it out of the car; however, maybe a little more history is in order. I changed all of the oil cooler seals back in May, immediately after reassembly, started the engine and it leaked on the first go. Life got in the way, so it has been sitting since May until yesterday; with not seeing any oil from the oil cooler deck down to the barrels, I am reticent to believe this is my issue. Again, I will definitely look, but not thinking this is it. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36219 Location: Conejo Valley, CA
Posted: Mon Sep 29, 2025 9:01 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Is there a galley plug in the area that might be leaking or even came out? This will become obvious when pulled and stripped. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4208 Location: Georgia
Posted: Mon Sep 29, 2025 3:50 pm Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
There’s a plug but it’s above #4 towards the pulley end.
Pull the cylinder tins on that side and try the test again. _________________ Volkswagen!
(Compression 8.7:1) |
viiking Samba Member
Joined: May 10, 2013 Posts: 3375 Location: Sydney Australia
Posted: Mon Sep 29, 2025 3:59 pm Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
| vamram wrote: |
| Cracked case...? |
I've had this happen too. Hopefully yours will not but you need to check it if your gross leak is not found.
My crack was not obvious. It looked like a casting mark.
To check you need to run a propane torch over the area and watch for oil seeping out of the crack. It is not until you get the area hot that the embedded oil will start coming out.
Of course having the engine out will be easier and of course be careful about flammable material being around you when doing so. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
b15605 Samba Member
Posted: Sat Oct 04, 2025 8:10 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Got the left side torn down, but stumped as to the source of the leak. Here are a few pics.
I will try the propane torch but dont see anything indicating a crack in the block. What is that tab with the little silver looking plug - could this be an oil gallery route and the plug is leaking? How would one address that? Or is it possible to leak out of the threaded rods where they thread into the base? Suggestions welcomed. Remember, the source of the leak is below the oil cooler so I dont believe that is the problem.
I may be forced to reassemble without engine tin and put back in car so I can turnover the engine to pulp oil and see if I can see the source but hoping not to do this. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11437 Location: Oregon
Posted: Sat Oct 04, 2025 9:05 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
That little silver bit is, an oil gallery plug. Yours does not appear to be leaking.
Depending on the case. Some of the head stud case savers can be open to the inside of the engine case and cause a leak through the inserts.
After seeing these pics, I suspect that the cylinder bases were not sealed and leaked from there. BTDT.
When installing cylinders, a fine bead of RTV around the cylinder base will seal the cylinder bases to the case cylinder spigots/registers.
What did you seal your cylinder bases with? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11397 Location: Huntington Beach, CA
Posted: Sat Oct 04, 2025 9:22 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Rusty, there is evidence of Red RTV on the case and
studs. Blow up the picture just a bit. Took my eyes a few seconds to see it.
You might have oil wicking out of the case savers. Chased that once or twice. I always appt blue loctite to those studs before installing. I have also seen the case savers them selves leech oil. Again, I use red loctite on them when assembling.
Those are 2 spots that are hard to figure out and make no sense, because they have no pressurized oil directly against them. But that crankshaft real can fling stuff around! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Sat Oct 04, 2025 9:35 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
I'm not totally disagreeing with you Jimbo.
If you look closely at the pic again and focus on the case savers. There is no evidence of RTV between the case register and the savers.
It's either a really good clean up before the pic was taken or, the red RTV on the head studs is left over from a previous build.
I'm just throwing my dumb ass observations out there as a possibility to why the oil is leaking in that area. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Oct 04, 2025 9:42 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
I'm just throwing my dumb ass observations out there as a possibility to why the oil is leaking in that area. |
Agree fully! I do the same. I did not even consider that the silicon was for the case savers! I just assumed it was for the barrel to case seal. Maybe the silicon was not used on the barrels and only on the case savers. That would be odd but it is a VW! Or maybe the silicon is just remnants from the mechanic installing the fan shroud!  _________________ Jimbo
| TDCTDI wrote: |
b15605 Samba Member
Posted: Sat Oct 04, 2025 9:51 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
The rtv was put in on the base of the cylinders when I rebuilt this engine about 5 years back. When I pulled the cylinders this morning, most of the rtv stuck to the cylinders. What is on the studs is just oozing upon install.
I am leaning case savers/studs here. I can pull all the studs and put blue locktite in, but I am not sure I should screw with the case savers themselves? Not even sure how to remove them without damaging the case? |
Posted: Sat Oct 04, 2025 9:58 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Don't screw with the savers, just seal the stud threads.
But, since it's apart. Do look for any case cracks, just in case. _________________ I have learned over the years.
Buy Once, Cry Once!
b15605 Samba Member
Posted: Sat Oct 04, 2025 10:21 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
| Got the propane torch to light. Dont see any evidence of a cracked case. Off to town to buy some fresh blue threadlocker as I cant find mine and it is probably dried up if I did find it |
b15605 Samba Member
Posted: Sat Oct 04, 2025 1:59 pm Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Threadlocker applied. New rtv applied at base of cylinders. Heads all torqued on. I am thinking of putting the engine back in the car as a bare long block so I can roll the engine over with the starter for a minute or so to move oil around. Will this be fast enough to be able to check for a recurrence of the leak? Wont be hard to do and I think worth it. If it passes this test I will then pull engine and install tin etc so I can finally get back on the road
Thoughts? |
Posted: Sat Oct 04, 2025 4:04 pm Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
| b15605 wrote: |
Thoughts? |
No. Not if the crankshaft is spinning madly. It's amazing how much oil is getting thrashed around inside. That's why VW installed the louvred plate at the oil filler. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
vamram  Samba Member
Posted: Sun Oct 05, 2025 6:21 am Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
Blowing up the one picture my eyes immediately go to this section on the rim of where the cylinder sits on the case. Is this this a deformity/damage or an optical illusion? If the former, it seems to me this is a potential spot for a leak.
Click to view image
Save the Supers!! |
b15605 Samba Member
Posted: Sat Oct 25, 2025 1:37 pm Post subject: Re: Oil Leak - left side but not push rod tubes or oil cooler |
First, thanks for all the input so far.
After getting everything back together - fired it up and to my dismay same oil leak appeared. I cannot think of any other source now than a crack in the case so beginning to think about that parh now.
Question: i have an old case given to me. It appears fine. Should I send it off for inspection and line bore? Or should I just buy a new case? Aluminum or new magnesium? Would just be a stock build
Opinions and options welcomed |
