Breather disassembly?
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Thu Apr 13, 2017 7:01 am    Post subject: Breather disassembly? Reply with quote
Cleaning up engine tin. How to disassemble breather? Is there a special tool/socket?
Everything known to man has been written.
Readers are Leaders!
Donnie strickland
Donnie strickland is offline
PostPosted: Thu Apr 13, 2017 7:26 am    Post subject: Re: Breather disassembly? Reply with quote
You can use an internal pipe wrench:
https://www.amazon.com/General-Tools-139-Internal-Wrenchs/dp/B00004T82B
71 Elm Green FI A/T Squareback
W1K1
W1K1 is offline
PostPosted: Thu Apr 13, 2017 7:45 am    Post subject: Re: Breather disassembly? Reply with quote
pull out the sleeve, you'll see it's a big flat blade , but the wrench I have like this sucks, I bought the plumbing wrench to get mine off
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
Nate M.
Nate M. is offline
PostPosted: Thu Apr 13, 2017 8:49 pm    Post subject: Re: Breather disassembly? Reply with quote
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D5102
This is the only tool worth using IMHO. . .
Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!!
Air-Cooled Head
PostPosted: Sun Apr 30, 2017 12:22 pm    Post subject: Re: Breather disassembly? Reply with quote
Nate, I bought this tool, and I agree; it is THE TOOL to use.
Unfortunately, mine was so tite, the cast stand itself cracked before letting go. Shattered the nut too. Mad
W1K1
W1K1 is offline
PostPosted: Mon May 01, 2017 11:57 am    Post subject: Re: Breather disassembly? Reply with quote
steel and aluminum/magnesium like to weld themselves together over time.
heat is one thing that can help them come apart. a "farmer fix" I learned from a customer for getting stubborn bearing races out, was to mig weld a bead around the race to shrink the bearing in the bore and they pop, and fall right out. works great on my Porsche 944 trailing arms.
1973 super 2110cc
