soissisc Samba Member
Joined: April 04, 2007 Posts: 638 Location: Western Pennsylvania
Posted: Thu Aug 17, 2017 9:51 am Post subject: Re: Summer engine into 68 Westy - questions |
Sorry for the absence, I had some crazy amount of work that had to get finished up (real life adult type pay bills kind of work haha).
Anyhow, per Tom Wilson first thing I did with the pistons is measure them for skirt collapse. And although the pistons "look" nice the skirts measure out otherwise. The best is a measurement below the oil ring that is .0003" smaller than the skirt (#1 Piston). The worst is a measurement at the skirt that is .0014" smaller than the measurement below the oil ring (#4 piston). Tom Wilson says throw these pistons out.
Knowing that I would like to run this engine for the rest of the summer (quickly turning to FALL), are these totally junk at this point? Would you continue on and clean them all up, and measure the ring lands to see if the pistons are beyond even new rings? (I do not have Bentley right in front of me right now).
I am not past buying new P/C at this point and if I do that maybe I should just throw new rods on it too, but from what I see an engine tear down and rebuild should occur this winter with this engine for sure.
If the ring lands are still in spec could I still put new rings on and run it as is for the rest of the nice weather driving season then tear it all down come winter and rebuild then? I mean if I put new rods and P/C could they be reused when I rebuild this winter?
I value your opinions.
Thanks _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51172 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 17, 2017 9:59 am Post subject: Re: Summer engine into 68 Westy - questions |
It depends on how much work you want to do later, you can slap it back together and have something that will run but be clattery and use some oil, if that's OK with you carry on and do it right this winter. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 17, 2017 10:41 am Post subject: Re: Summer engine into 68 Westy - questions |
That is about what I was thinking Busdaddy.
If I put money into new P/C and rods now, with limited miles and barring a mechanical catastrophe, those could be reused come tear down time this winter? _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Thu Aug 17, 2017 10:54 am Post subject: Re: Summer engine into 68 Westy - questions |
Sure they could, unless you have excessive endplay on the crank, that will wear the pistons in all sorts of odd ways. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jul 29, 2018 2:44 pm Post subject: Re: Summer engine into 68 Westy - questions |
OK, getting back into this again, (I know a year has gone by.... but what are you going to do?)
I pulled a rod to check it out. What am I seeing here?
My thought was to maybe mic the crank and maybe get new rods and pistons / cylinders and put it back together. Is this a total waste of time? I can pull the rest and see what I find. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Sat Aug 11, 2018 10:44 am Post subject: Re: Summer engine into 68 Westy - questions |
New part frustrations
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Sat Aug 11, 2018 10:52 am Post subject: Re: Summer engine into 68 Westy - questions |
Removed duplicate post _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Sat Sep 15, 2018 5:07 pm Post subject: Re: Summer engine into 68 Westy - questions |
Ok, so I ended up rebuilding. The further I got the more it seemed like throwing good money to bad.
Anyway... What are your opinions on the oil cooler? Right now it is stock. Should I convert to doghouse? I have a shroud etc. This is a camper as well....
Let me know what you think.
I am collecting parts to go back to stock air cleaner as well and may have some questions on the pre-heat ducting.
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Sat Sep 15, 2018 8:33 pm Post subject: Re: Summer engine into 68 Westy - questions |
Yes, you should concert to a doghouse cooler. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Sat Sep 15, 2018 9:24 pm Post subject: Re: Summer engine into 68 Westy - questions |
What is your case serial number? (Or gallery size if you know it!) I don’t think you’ll want to stick a 10mm doghouse cooler into an 8mm gallery case without other oiling system modifications.
What are your intentions for this bus engine? Life span? Cruising speed? Longest possible road trip?
There’s no way I could answer your doghouse conversion question without knowing way more details.
www.airschooled.com |
Posted: Mon Sep 17, 2018 5:35 pm Post subject: Re: Summer engine into 68 Westy - questions |
Case number is B6316159.
As far as expectations for the engine? Light cruising, 60-65 for extended periods on trips, camping, 1-2-3-?? hour drives to NYC or the coast? Who knows? I would like it to last as long as possible. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Fri Sep 04, 2020 10:09 am Post subject: Re: Summer engine into 68 Westy - questions |
It is a dual relief case. Not sure of the gallery size, but I will get into it. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Fri Sep 04, 2020 12:48 pm Post subject: Re: Summer engine into 68 Westy - questions |
OK, yes 10mm oil passages. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Thu Sep 10, 2020 1:27 pm Post subject: Re: Summer engine into 68 Westy - questions |
OK I originally posted this in my stock air cleaner thread, but I took it out of there and moved it to this engine related thread, as it seemed more related.
I was doing fitting of the tins etc, and snapped this picture.
Got the pipe and the tin piece, and got those installed.
Once I got the picture onto my computer and studied it a little bit, I noticed this, it looks like the valve guide is cracked and extending beyond the boss much more than all of the other exhaust guides.
Upon further investigation, when the crank is rotated, the tapered area on the new exhaust valve stem does come back and interfere with the valve guide when #2 is on TDC. These heads had new valves installed, I am not 100% sure on if the guides were replaced. It looks like this head needs to come off and that valve guide shortened or see why it protrudes so far out into the port.
I took a look under the valve covers and the offending #2 exhaust looks like this:
And the intake valve guide on this side looks like this (more correct I gather)
So, fallen or sunken valve guide? Definitely looks like pulling the head is in the cards here.
Any comments or suggestions?
Thanks,
Mark _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
SGKent Samba Member
Posted: Sat Sep 12, 2020 9:14 pm Post subject: Re: Summer engine into 68 Westy - questions |
I'd go back to whomever did the heads and talk with them. They may not be willing to fix it if it has been awhile but it is obvious from the photos that the heads don't look used. Did someone paint the valves with black paint? It looks that way in the photo. Don't know why someone would do that if they did. If the guides are replaced, the valve seats will need to be done again because no two guides are perfectly concentric with one another. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22677 Location: NYC/Upstate/ROW
Posted: Sat Sep 12, 2020 11:16 pm Post subject: Re: Summer engine into 68 Westy - questions |
Blech. The shop that reworked those heads has a barrel of monkey tails out back ....horrible work. _________________ .ssS! |
Posted: Sun Sep 13, 2020 9:56 am Post subject: Re: Summer engine into 68 Westy - questions |
Yes guys, bummer for sure. It was an "economy" rebuild, so I guess how far can you throw it?
The valves look brand new to me, maybe the light makes them look black in the photo.
I don't think I am going back to this guy, he sort of screwed me on taking the core engine which he agreed to for reimbursement.
I started a thread on this guide issue in the engine forum so we can jump there for further discussion of this.
https://www.thesamba.com/vw/forum/viewtopic.php?t=743164
Thanks! _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Tue Feb 13, 2024 3:18 pm Post subject: Re: Summer engine into 68 Westy - questions |
Welcome back, slowly getting this bus nearer and nearer to back on the road. I have gotten all of the engine problems settled, hopefully, and I have a question. I am getting all of the accesories attached and I have had the fuel pump refurbished. My question is what type of fuel line works for this fuel pump with the threaded inlet and any ideas on where would I get one?
Mine is like the fuel pump exploded on the left.
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Tue Feb 13, 2024 4:38 pm Post subject: Re: Summer engine into 68 Westy - questions |
Thank you I will check it out. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
