Identify rear brakes?
Hebster52
Hebster52 is offline
PostPosted: Sat Jul 29, 2017 7:45 am    Post subject: Identify rear brakes? Reply with quote
I have no idea if these are split or maybe even Barndoor rear brakes?
How can I tell what they are?
~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD
Ovally
Ovally is offline
PostPosted: Sat Jul 29, 2017 10:09 am    Post subject: Re: Identify rear brakes? Reply with quote
Looks like Zwitter and early Oval (1953) rear brakes.
Regards.
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sat Jul 29, 2017 10:17 am    Post subject: Re: Identify rear brakes? Reply with quote
At first glance they look like Jan 52 to Dec 53 Beetle brakes, since there are only two brake shoe return springs.
Is the star wheel leaf spring attached with 2 small screws, or crimped on? Crimping started end of Oct 53.
What is the bore of the 4-bolt wheel cylinder? Rear cylinder bore increased to 17.5 mm, from 15.9 mm, in Oct 52.
- Zeuxius, 400 BC
Hebster52
PostPosted: Sat Jul 29, 2017 10:22 am    Post subject: Re: Identify rear brakes? Reply with quote
Ok. Thanks. It is crimped on. Not measured the cylinders. The brake shoes are 30mm so seem to be 52-53 ish then?
~Kris~
The Hebster52
The 912ST
The KidVRod project
Zwitterkafer
PostPosted: Sat Jul 29, 2017 10:40 am    Post subject: Re: Identify rear brakes? Reply with quote
Well, based on the backing plate design, it has to be Oct '53 to Dec '53. Yes, 30mm wide shoes. If original, the wheel cylinder should be 17.5 mm; there might be a number on the cylinder casting.
- Zeuxius, 400 BC
Ovally
Ovally is offline
PostPosted: Sat Jul 29, 2017 12:09 pm    Post subject: Re: Identify rear brakes? Reply with quote
Zwitterkafer wrote
""At first glance they look like Jan 52 to Dec 53 Beetle brakes, since there are only two brake shoe return springs.""
Jan 52 Beetle brakes had three brake shoe return springs.
https://www.thesamba.com/vw/archives/manuals/1_52bug/21.jpg
From October 52 (Zwitter) two brake shoe return springs.
https://www.thesamba.com/vw/archives/manuals/10_1952beetle_french/44-45.jpg
Regards.
Zwitterkafer
PostPosted: Sat Jul 29, 2017 5:28 pm    Post subject: Re: Identify rear brakes? Reply with quote
Well, my copy of "Progressive Refinements" says otherwise. It says that on 26 Jan 1952, beginning with Type 1 chassis # 1-0318328, the former two springs (at the adjuster block side of the backing plate) were replaced by a single spring, and thus at the same time the angle brackets for the former springs were eliminated.
- Zeuxius, 400 BC
Ovally
Ovally is offline
PostPosted: Sat Jul 29, 2017 6:32 pm    Post subject: Re: Identify rear brakes? Reply with quote
Strange but probably the data from the "Progressive Refinements" are more accurate.
So the version with the 2 brake shoe return springs has entered from chassis number 1-0318328 (26 Jan 1952).
Regards.
52 split
Location: the best island in the world, vancouver island
52 split is offline
PostPosted: Fri Mar 01, 2024 9:38 pm    Post subject: Re: Identify rear brakes? Reply with quote
hello all the photo shop pics are gone, can someone show what the front and rear brake shoes look like for may 52 using only two springs, also are the screw adjusters straight front and back or on a angle.
esde
esde is offline
PostPosted: Sat Mar 02, 2024 6:57 am    Post subject: Re: Identify rear brakes? Reply with quote
Photobucket tanked and all the pics hosted there are gone.. which is why I have thousands of pics hosted here on Samba..
Early rear brakes, you need the angled slot adjusters.
modok wrote:
Hebster52
PostPosted: Sat Mar 02, 2024 12:28 pm    Post subject: Re: Identify rear brakes? Reply with quote
I could not update the original post but I dug up the original photos and uploaded them here in thesamba's gallery.
~Kris~
The Hebster52
The 912ST
The KidVRod project
52 split
52 split is offline
PostPosted: Sun Mar 03, 2024 3:10 pm    Post subject: Re: Identify rear brakes? Reply with quote
thanks 52 hebster, mine are as your photo, two spring setup, can you confirm that the screw adjusters are slotted front and back.
