Wolfram Samba Member
Joined: June 23, 2005 Posts: 184 Location: Waiheke Island/On The Road USA
Posted: Tue Aug 01, 2017 7:40 pm Post subject: Front Washer Reservoir Filler Tube Problem |
Went to Jiffy Lube today and they filled the reservoir as usual but said fluid was leaking, you may have a cracked reservoir.
Dropped the reservoir, 3x 10mm bolts, and the filler tube popped out in the floor where it normally resides.
The seal between the filler tube and the reservoir was dodgy, hence leak, so no cracked reservoir, phew.
Now, getting the tube back in place is like putting a baby back. Can't see how to get the tube to go back (from the top) so it meets with the reservoir.
Tips, please? _________________ 88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage. |
E1 Samba Member
Joined: January 21, 2013 Posts: 8354 Location: Westfalia, Earth
Posted: Tue Aug 01, 2017 10:08 pm Post subject: Re: Front Washer Reservoir Filler Tube Problem |
I can't recall the exact choreography, but you just have to rotate it around and finagle it in there. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman
Jonathan Weisheit, Race in Peace:
https://www.youtube.com/watch?v=z3dS7xiFn7I&t=500s |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Aug 02, 2017 7:19 am Post subject: Re: Front Washer Reservoir Filler Tube Problem |
I wouldn't worry about the leak, they made it so it leaks out under the van where the filler neck meets the tank. Better there than overflowing under your carpet.
Put the tube in the hole and line the bucket up with as you put the bucket back in place. |
bajaleo  Samba Member
Joined: March 21, 2009 Posts: 213 Location: San Juan Capistrano, CA
Posted: Wed Aug 02, 2017 12:49 pm Post subject: Re: Front Washer Reservoir Filler Tube Problem |
I just worked on this item a week ago.
If I understand you correctly, you removed the fill tube, and now you're trying to put it back in. I too did this, and had to really "finagle" it , as E1 puts it.
Trust me, it WILL go in.
While you're at it, replace the big grommet that seals the tube to the opening in the top of the reservoir.
http://www.van-cafe.com/page_511_1369/front-wiper-reservoir-grommet _________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
