Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1966 Location: Manitowoc, WI
Posted: Tue Oct 08, 2019 3:55 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Sorry, I haven’t updated recently. Work is slow, I got all but two of the heater channel bolts in. I also installed the gas heater and made an intake pipe for it with a “air filter”. I got my link pins reamed finally! Yay! I got the front end put back together and did an alignment job on it. I had to make the locking tabs for the tie rod. The front is so much tighter now. I had the engine running the other day. I got the roof stripped of paint.
_________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5510 Location: 1st Coast
Posted: Wed Oct 16, 2019 1:27 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Looking good Ceckert64, is the portable garage new or did you use it last year? How is it working for you?
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Sun Oct 20, 2019 7:13 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
LAGrunthaner, I’ve had the shed up for at least a year and a half. It has worked out well, currently it’s being used for VW body panel and tire storage, parltly because I’ve been working on Herbie a lot, or there’s been bare metal on the roof, just that it’s not climate controlled as much as the garage. The shed stays pretty dry inside, water runs in by the bottom in the gap. There are no rips in it so far, it’s held up good. It help up good in the snow too.
This weekend I finished blasting the roof section of the car. I made sure to get the drip rail media blasted real well. I got the rust pits cleaned out and filled, most all of the pitting was around the window seal channels. There were 25+ Pin holes I used USC Duraglas on them. I got all the dents and rust repair I did on the roof covered with body filler and then sanded it all. I got one coat of primer down tonight.
Posted: Mon Oct 21, 2019 5:27 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Thanks, looking good! _________________ American Red Cross Safe And Well:
Maui Roadsters
Lind wrote: |
Posted: Thu Oct 24, 2019 4:36 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Nice primer Ceckert64, I know it is starting to get cold up there in MI as my in-laws/family are on the east side of MI and it will soon be too cold to work. Get as much done as possible then get all the small stuff indoors to work on during the cold weather. I think you've got this all planned out very well
Ceckert64 wrote: |
Thanks! I just got the high build primer on the other day. I found one small spot that I missed for body filler but I will fix it. I was impressed how well my body filler job turned out!
Maui Roadsters
Lind wrote: |
Posted: Sun Nov 03, 2019 6:29 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Ceckert64, you are brave with winter around the corner, keep up the good work. What is the temperature in Midland, MI and how cold is too cold for that paint?
Ceckert64 wrote: |
I was busy this weekend so I didn’t get much done. I only got the back interior blasted and painted. I used cheap tractor paint over ppg high build primer. I’m hoping this week to get the rear 1/4 panels stripped and body worked and paint over the weekend.
Maui Roadsters
Lind wrote: |
Posted: Tue Nov 12, 2019 5:18 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Last weekend I got a little sanding done on the rear quarter panel. I also started to replace the rear axle seals. My issue is that the outer race of the bearing can turn by hand in the holder. I also can move the axel shaft in and out easy by a 1/4-1/2 an inch. Are these things a problem? I think the axel shaft movement it caused by the bearing not sitting in well. The shaft doesn’t move when the cover is on. Thanks for the help!
The snow is coming down hard. it’s nice but not fun for working or painting. _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Mon Nov 18, 2019 5:20 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
I got a few miscellaneous things done this weekend. I first got the axel seals done and back together. I also put the oil slingers on. On the right rear wheel, the brake cylinder had been leaking and destroyed the brake shoes, luckily I had two new ones sitting in the attic But, the new cylinder will come in Tuesday then I can put that back together and time to bleed brakes for the 3rd(?) time! Then I decided to adjust the thermostat ring, and broke the thermostat at least I had a spare in the attic along with the correct braket. Then I decided to do the difficult, put in the rear engine seal. It was a royal pain. The engine sits slightly crooked because the tranny mount is off (I have to fix that soon) which made the one side had to get in. The putting in the breast plate and getting the seal over that that was a challenge, but I finally got it together and detailed the engine. I had to replace the air hose, and the one I had was a lighter gray, to make it look like the other one, I used some oil on it it now looks like the other one. Then I got some more filler on the rear 1/4. Here are some pics to go with the work:
The lighter tube is part of the same tube before oil treatment
And the destroyed brake shoe. _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Tue Apr 21, 2020 4:31 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
I just remember, today Herbie is 56! Not much for updates, I did finally find original rear interior panels for the 64 year. I also started body work on the right rear quarter. The reason there are no Herbie updates is I got a little distracted Late this December I Scored a 1970 Squareback barnfind that hadn’t been running in 44 years. All original interior, original paint, and only 36,000 miles I technically bought it from the original owner according to the title. Anyways, I have gotten that running and driving and on the road again and I’m also almost done with all work on it. I still had to do some rust repair on it too. If you want to check it out, I linked it in my signature. The picture is from a drive to a family members house.
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Thu May 07, 2020 8:48 pm Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Hey there, I too decided to look through your build and wanted to compliment you on your great efforts. In fact, you have inspired me to build my own car port tent thing so I can get my show back on the the road that is after all the busyness cools down right now for me. Keep it up, your almost there
Also, is that an after market front clip? How was the fit and finish on that. I’m considering it as an option for my 65.
Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Fri May 08, 2020 4:57 am Post subject: Re: "Herbie"1964 beetle metal sunroof restoration/ replacing metal |
Chickensoup wrote: |
Thanks |
Thanks for looking through! Thank you, good luck with your car port tent. It is nice when you have bare metal exposed it protects it, and when you get kicked out of the garage. Hopefully it will be done in a few months, I’m hoping to start on it again by the end of the month. I have to finish some metal work on my other car so you can’t see the ground.
Yes, it is a after market front clip. It’s not great for fit and finish. The pressing on the edges is very round, making the seal grove not weld on nice and pushes it out. Also, if a little to much gets cut out, it doesn’t line up well and screws up fender alignment.
I’m looking at you thread on your 65, if you cans get it pulled out enough, I would say keep it, or, maybe do a partial quarter panel replacement vs the whole apron, I now try to leave as much original metal as possible since the new stuff is crap.
Hope this helps. _________________ 1964 sunroof Beetle Restoration "Herbie"
