2002 Eurovan 01P automatic transmission fluid source, type?
Abscate
Abscate is offline
PostPosted: Thu Aug 31, 2017 4:25 am    Post subject: 2002 Eurovan 01P automatic transmission fluid source, type? Reply with quote
Alldata calls for the part
G052162a2
This runs about $21 a liter at FCP
Is there a good aftermarket anyone has tried?
I'm guessing the FEBI......F2 fluid is different stuff, at $9.99 a liter
markcm2
markcm2 is offline
PostPosted: Thu Aug 31, 2017 7:50 am    Post subject: Re: 2002 Eurovan 01P automatic transmission fluid source, type? Reply with quote
It looks like the Febi 14738 is the equivalent for G052162a2, I have not used the Febi but also wouldn't hesitate to use it.
I have found some good deals on Pentosin ATF-1 on Amazon.com. That's what I use in our B5,B6 Audi A4s, B5 passat, and our 01 Eurovan. Be sure you don't get the ATF-1-LV (Low viscosity).
Redline D4 would be an equivalent as well.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Thu Aug 31, 2017 8:04 am    Post subject: Re: 2002 Eurovan 01P automatic transmission fluid source, type? Reply with quote
I use the Febi or the Pentosin 1058209 (20 liter) (1058206 for the 5 liter) & go through about 80 liters of it a month. I have quite a few customers cars with well over 250,000 miles on their transmissions.
markcm2
markcm2 is offline
PostPosted: Thu Aug 31, 2017 8:30 am    Post subject: Re: 2002 Eurovan 01P automatic transmission fluid source, type? Reply with quote
TDCTDI wrote:
I use the Febi or the Pentosin 105829 (20 liter) (105206 for the 5 liter) & go through about 80 liters of it a month. I have quite a few customers cars with well over 250,000 miles on their transmissions.
Google doesn't turn up any product based on those pentosin part numbers. Can you clarify if this is Pentosin ATF-1 to avoid confusion.
I suspect your are referencing AFT1 and the part number for the 5-liter on Amazon.com would be 1058206. It is currently available in 5-liter for $66 shipped.
TDCTDI
TDCTDI is offline
PostPosted: Thu Aug 31, 2017 9:39 am    Post subject: Re: 2002 Eurovan 01P automatic transmission fluid source, type? Reply with quote
You are correct, I accidently omitted numbers out of each, thanks.
Abscate
Abscate is offline
PostPosted: Thu Aug 31, 2017 12:00 pm    Post subject: Re: 2002 Eurovan 01P automatic transmission fluid source, type? Reply with quote
Pentosin 1 liter size of ATF-1 (non LV) is 1058107
Got it at Amazon price at FLAPS
