donovjim Samba Member
Joined: June 27, 2014 Posts: 102 Location: NovaScotia
Posted: Wed Aug 17, 2016 2:25 pm Post subject: squareback rear suspension damper post/ nub missing. repair? |
Missing this post on left side. ( for suspension damper)
Right side looks like this
Left side complete is this
I was hoping someone could suggest a repair or know of a source for a used piece that I could weld in place to get the required connection. Thx for any help. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13546 Location: Tejas!
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23105 Location: Oklahoma City
Posted: Thu Aug 18, 2016 8:01 am Post subject: Re: squareback rear suspension damper post/ nub missing. repair? |
Erik G wrote: |
http://www.thesamba.com/vw/classifieds/detail.php?id=1956450
that will get you what holds on to the snubber, but I don't think that would be a very easy thing to weld in. Maybe from the bottom?
best of luck. maybe need a whole trailing arm? It's unfortunate it's not bolt in like early cars |
See those two holes next to the nub?....why can't you just weld the nub onto a piece of 1/8" plate and thread those holes and bolt it on?
Ray |
Posted: Thu Aug 18, 2016 8:10 am Post subject: Re: squareback rear suspension damper post/ nub missing. repair? |
Erik, thanks. I don't know how you found that classified but it's perfect if not too expensive. thanks v. much.
Ray... I don't have the nub, it's disappeared...likely pounded off. Even if I did it would have to be welded "into" the tray so as not to modify the height of the connection. That's said, you're correct. If Im unable to access a part I will have to build a nub (likely of a rounded, ground down bolt), weld it to a plate and then inside the depression in the carrier. I'd much prefer to have the correct size nub and plate to weld to the existing piece. Thx. J |
Erik G Samba Member
Posted: Thu Aug 18, 2016 9:13 am Post subject: Re: squareback rear suspension damper post/ nub missing. repair? |
Fantastic. I emailed him (no reply yet) - appreciate the help from you folks here as always. J |
