Clinton Samba Member
Posted: Tue Mar 06, 2018 10:27 am Post subject: Installing a Vent Wing Rivet in a 66' Beetle |
I was looking to replace the vent wing rivet in a 66' Beetle without using a pop rivet or a screw. I ordered the vent wing rivet from Wolfsburg West part# N136612 $.60ea. Then I ordered RAM PRO Snap Kit Tool Kit $29.99.
Remove #1 & #13 from their plastic clips.
Use the back of 13 (flat non-dished side) on flat side of rivet.
Spray #1 with WD40 and place stack up in bench vise and compress.
This is the old rivet.
This is the new rivet.
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Tue Mar 06, 2018 4:51 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
That's the best job I`ve seen yet. _________________ If you`re going to do something, do it right. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Thu Mar 08, 2018 10:32 am Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
| Bryan67 wrote: |
| That's the best job I`ve seen yet. |
I concur-
Thank you for the great photos, descriptions and exact tool references! This puts it among the best threads here! _________________
| EverettB wrote: |
FU#5 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16820 Location: State College, PA
Posted: Thu Mar 08, 2018 5:53 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
Thanks....probably gonna order one myself. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
oe_tuner Samba Member
Joined: January 01, 2008 Posts: 55 Location: Central Ohio
Posted: Thu Mar 08, 2018 9:06 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
| YES! I am actually excited to rebuild my vent windows now. Excellent write up. Thanks! |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71930 Location: Phoenix 602
Posted: Fri Mar 09, 2018 8:54 am Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
I remember years ago someone had glued or welded a metal ball....like a big b-b to the jaw of a vicegrip or pliers... _________________ D-Dubya Manx clone 1914. Ex wifes car.
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Fri Mar 09, 2018 8:14 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
I've a similar style rivet made from an appropriate size flat-head iron nail. A small hole was drilled in the end of the short shaft, and then it was spread open using a hammer and a rounded-over center-punch. A little finicky and picky to do, but it worked for the one wing rivet that needed repairing. The iron nail tends to rust, though. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 956 Location: Moreno Valley
Posted: Fri Sep 30, 2022 8:54 am Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
i put in a few vent wing rivets , i forget exactly how , pliers n a ball bearing to flare the one end something like that .......Then i saw these on the bay , i offered the seller half of what he was asking and got em .... the tool is marked VW
corro23 Samba Member
Posted: Sun Oct 02, 2022 12:37 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
Nice post! Bookmarked!  _________________
64 - Next project
66 - Maintaining
73 Super (sold)
63, 66, 73 Super (history)
far rider  Samba Member
Joined: August 30, 2005 Posts: 1013 Location: Rutland, VT
Posted: Wed Jun 26, 2024 3:50 am Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
Nice work! The Ram Pro tool seems to be no longer available. Anyone find a suitable replacement? TIA _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 390 Location: Noblesville, IN
Posted: Wed Jun 26, 2024 8:20 am Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
Search Amazon or eBay for a rivet setter. There are a number of options available in punch, plier or press configuration. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
rokemester Samba Member
Posted: Mon Mar 10, 2025 12:51 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
This was an extremely useful post. I found a used rivet set on EBay. Missing no 13 but I improvised.
Posted: Mon Mar 10, 2025 12:52 pm Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
wdfifteen Samba Member
Posted: Wed Mar 12, 2025 6:11 am Post subject: Re: Installing a Vent Wing Rivet in a 66' Beetle |
Ha! I used EXACTLY the same rivet setting tool a couple of years ago when I did the vents on my '65.
