Lars B Samba Member
Posted: Mon Mar 19, 2018 12:43 pm Post subject: Stationary engine with Magneto in a car. |
I have a NOS stationary engine, the i want to use in my 56.
But I heard it will self destruct because of the magneto's ignition curve.
Any truth in that? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20835 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Mar 19, 2018 12:47 pm Post subject: Re: Stationary engine with Magneto in a car. |
Replace magneto with distributor... OR have magneto advance recurved to fit you needs...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Lars B Samba Member
Posted: Mon Mar 19, 2018 1:02 pm Post subject: Re: Stationary engine with Magneto in a car. |
Dale M. wrote: |
Dale |
Ok but that was not the question.
Will it self destruct?
And why?
If i have the magneto re-curved, what will the curve be?
I can understand that the ignition can cause bad performance, and if you don't have enough advance it will go hot.
But a Stationary engine Magneto will have 12,5 degrees at 1750 rpm, and that is similar to the 019 distributor, as i understand it.
Posted: Mon Mar 19, 2018 8:32 pm Post subject: Re: Stationary engine with Magneto in a car. |
Why would it "self destruct"... Stationary is a application for engine for most part not a design...
Lars B Samba Member
Posted: Tue Mar 20, 2018 10:39 am Post subject: Re: Stationary engine with Magneto in a car. |
Dale M. wrote: |
Dale |
Ii wondering that myself, but at lot of VW people here in Sweden say's dont use the magneto because i will break the engine,if used in a car. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79746 Location: Sneaking up behind you
Posted: Tue Mar 20, 2018 10:50 am Post subject: Re: Stationary engine with Magneto in a car. |
I'd be more concerned about a engine that sat for 50+ years. Valve springs, cam and rings.
The magneto will not cause it to fail but it will most likely not run well at low rpm and under load. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7870 Location: Videbaek Denmark
Posted: Tue Mar 20, 2018 10:52 am Post subject: Re: Stationary engine with Magneto in a car. |
Dale M. wrote: |
Dale |
X2
Lars B wrote: |
A Magneto is not a problem as such. Think of the 181 things for the military. Many of the earlier ones used,,,,, - Magneto´s.
But yes you should recurve the advance curve to something that resembles a street distributor. 009 or 010 or whatever the engine likes.
Also, remember that the Magneto has a relatively weak coil, so you should regap your plugs to 0,5 mm. Then you should be fine.
T |
