Dressed crank-NOW 1.8L BUILD THREAD
Page: 1, 2, 3, 4, 5  Next
Volswagon
Volswagon is offline
PostPosted: Tue Apr 03, 2018 9:41 pm    Post subject: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
I'll have to ask the pro's - what should I soak this crank assembly in. The pilot bearing is installed too, with red grease, it's ok.
The crank solid bearings won't budge. They are soaking with oil now. The rod journals are gunked up.
It's been wrapped up ~4 years until today. What will soften dried lithium?
I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
Volswagon
PostPosted: Tue Apr 03, 2018 10:34 pm    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Since like dissolves like, and I have a tub of lithium that's still like new even after 20 years, would dobbing some fresh on it do any good?
UK Luke 72
UK Luke 72 is offline
PostPosted: Wed Apr 04, 2018 12:32 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Solvent cleaner... Loctite 7063 would likely work well.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
Vanillagurilla
Vanillagurilla is offline
PostPosted: Wed Apr 04, 2018 1:19 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Brake cleaner or you can soak with auto transmission fluid mixed with a little gas to thin it out, old junk yard trick for stuck bolts.
Volswagon
PostPosted: Wed Apr 04, 2018 2:14 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Brake cleaner it is. Thanks gur. I concur.
I left the front wheel off the S10 to finish routing new plugs and wires and catch the outer front brake pads. 182K on a factory plug #1 under the AC compressor, and 3 oddballs, with #4 loose. Throttle body intake boot cracked. First time I've had it apart, 82K of that is mine since the bus died. Got it from my brother with chunky soup for oil.
I miss my Bus - she completes me!
Cusser
Cusser is offline
PostPosted: Wed Apr 04, 2018 8:32 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
I also think brake cleaner. Guys wash off grease from wheel bearings all the time.
Dale M.
Dale M. is offline
PostPosted: Wed Apr 04, 2018 8:45 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
AT fluid and Acetone...
Dale
Dale M.
Dale M. is offline
PostPosted: Wed Apr 04, 2018 8:47 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Brake clean, petroleum spirits (paint thinner) and PB Blaster, my three main tools...
Dale
Volswagon
PostPosted: Wed Apr 04, 2018 9:28 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
I'll prolly end up taking the crank apart to clean up the bearings. Breakfree is what I've used in the past just because it was on hand, great gun oil.
Thanks for the responses.
Dale M.
Dale M. is offline
PostPosted: Wed Apr 04, 2018 11:39 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Breakfree is good too...
Dale
Volswagon
PostPosted: Wed Apr 04, 2018 1:37 pm    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Plug wires on S10 4-cyl. are a bitch, even the pro's agree.
I have bearings 1 and 2 turning, 4 is still stuck like glue, still soaking.
But every time I sit on these new seat covers, I know she'll be worth the trouble.
Volswagon
PostPosted: Wed Apr 18, 2018 5:20 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
I got her turning by hand with case torqued down. Raby 9550 cam kit, bought in '09, included dual thrust bearing and solid spacer rocker arm upgrade.
Len Hoffman 0825 1.8L heads, after he cut the steps in 2010. They have around 15,000 mi. on them and have been waiting on me.
theKbStockpiler
theKbStockpiler is offline
PostPosted: Wed Apr 18, 2018 8:17 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
Spray oil. Why turn it into a big project.
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
Volswagon
PostPosted: Wed Apr 18, 2018 9:41 am    Post subject: Re: Dressed crank has dried lithium grease from sitting Reply with quote
I've turned it into a build thread. Just got the rusty 210mm flywheel shined up at the shop.
It's a minor miracle I still have all this stuff after the last 8 years.
I'm doing this in the basement with "stone knives and bear skins."
timvw7476
timvw7476 is offline
PostPosted: Wed Apr 18, 2018 4:58 pm    Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
When you own & operate a 43 y/o bus,
you stash your bits & pieces where you can.(like a squirrel with nuts)
Not that I would know, my bus is only 42.
bugguy1967
bugguy1967 is offline
PostPosted: Wed Apr 18, 2018 9:26 pm    Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
What is the 9550 cam? Is that the Camper Special cam?
raygreenwood
raygreenwood is offline
PostPosted: Wed Apr 18, 2018 10:21 pm    Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
No....well it "may" be used as a camper special cam.....I have no idea....I do not work on camper engines Laughing .....but its a Raby version of the Web #73 with a couple of extra degrees of exhaust overlap for better head cooling. I have a 9550 kit I bought in ahout 2009 to 2010 right before Jake got out of the store. Its going into my 1.7L 412 engine.
It was superseded by the 9590....which is tuned to work a little better with fuel that has alcohol.....so I was told.
The 9550 is a great cam for certain applications just a bit hotter than stock. Ray
Volswagon
PostPosted: Fri Apr 20, 2018 6:11 am    Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
Good info Ray, thanks!
I have a broken oil ring on these CIMA pistons. Widths are 2mm top, 1.5mm middle and 3.5mm oils. Am I looking for new pistons? I have a few cracked fins and was apprehensive about that already Sad
I'm checking with Bus Depot, but I'm having land-line issues today and no cell.
Oh, and there's a K6 solar storm today, 4/20, medicate accordingly!
raygreenwood
PostPosted: Fri Apr 20, 2018 7:31 am    Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
Post pictures of where the cracked fins are.
Also....measure the skirts of the pistons. If they are not collapsed and not scored.....and the ring was not broken by a bent or dented ring land......and the ring lands are clean....just get new rings. Ray
Volswagon
PostPosted: Fri Apr 20, 2018 8:27 am    Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD Reply with quote
G'day mate. Fins are next to head. One piece oil ring, broke cable, which scored piston (#2) on the flywheel side. My buddy Ron's Import shows no listing for pistons.
I'd like to score some 90's like yours, thicker walls, but a set of rings will do for now. I doubt Bus Depot has anything but stock size (2, 2, 4) rings. Saw the same dilly with CIMA Bug pistons back in the day Sad Gonna go medicate, Cheers!
Page 1 of 5
