mdvanderploeg Samba Member
Joined: November 06, 2011 Posts: 126 Location: Raleigh, NC
Posted: Sun May 27, 2018 3:17 pm Post subject: How poorly should a split drive? |
I know it's a subjective question, but I've never driven another one, so have nothing to compare it to. I've been driving my 1950 quite a bit lately (all original with radial tires), & have to say that it's all over the road! In 4th gear, it's pretty tough to keep it between the lines.
The oldest car I've driven up to this point was my 1957 Austin Healey, which didn't exactly ride on rails either. Just trying to figure out if I have a problem or if this is normal. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Sun May 27, 2018 6:03 pm Post subject: Re: How poorly should a split drive? |
Is it stock height, or lowered? Stock rims and tires? Changes often screw with proper alignment.
If stock, check for mechanical issues. Loose wheel bearings, tie rods, king/link pins, steering gear adjustment or wear, tire pressures (18 front, 24 rear for starters), alignment (front AND rear).
Properly maintained and in stock form, they should drive just fine other than (1) crosswinds, (2) undulating roads, or (3) S-turns. |
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Sun May 27, 2018 6:19 pm Post subject: Re: How poorly should a split drive? |
Alignment done properly. |
oldsplitvw Samba Member
Posted: Sun May 27, 2018 8:21 pm Post subject: Re: How poorly should a split drive? |
All over the road? Not that poorly by far. I put 7,000km on my stock 11G, in 4th gear I would have it up to 102-105km/hr and it would track straight, could hold the wheel steady with one finger. I have used Excelsior bias ply tube tires on all my splits.
Will |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24130 Location: Southeast USA
Posted: Sun May 27, 2018 8:34 pm Post subject: Re: How poorly should a split drive? |
It should track as well as any other Volkswagen.
If the alignment has been checked, the link pins and wheel bearings are tight, and the steering box adjusted properly, and the car still appears to "hunt," and has trouble tracking in a straight line, consider adding a set of caster shims. This has solved the issue for many Volkswagens.
https://www.thesamba.com/vw/classifieds/search.php...ton=Search _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Posted: Sun May 27, 2018 10:22 pm Post subject: Re: How poorly should a split drive? |
Agree with above. Invest in getting the front end done right; you can't put a price on safety
Will |
Posted: Mon May 28, 2018 5:07 am Post subject: Re: How poorly should a split drive? |
Thanks, guys, sounds like I have some work to do. Everything is stock, including ride height. All suspension and steering components were replaced or refurbished. It's running stock rims...16 x 3.5.. I'm fairly certain rear end alignment was not performed, so I'll start there.
With all of the work that's been completed, I expected a much more stable ride. I had a '65 in college that I'd drive from St. Pete, Florida to Clemson, SC, no problem. From what everyone's saying, it appears that the 1950 should at least be similar. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Mon May 28, 2018 6:14 am Post subject: Re: How poorly should a split drive? |
Tire pressure should be 20 up front and 30 in the back. Any stock bug will handle much worse with incorrect tire pressures. _________________ .
Wanted:
Posted: Mon May 28, 2018 8:39 am Post subject: Re: How poorly should a split drive? |
Also check the steering box, it is crucial that the tension on the worm gear is adjusted correctly or it will also cause the wandering you describe
Will |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Mon May 28, 2018 8:52 am Post subject: Re: How poorly should a split drive? |
Lind wrote: |
Tire pressure should be 20 up front and 30 in the back. Any stock bug will handle much worse with incorrect tire pressures. |
Fer sure. When I got my '63 it was about 30 all around, like most other cars, and it drove nervously.
An acvw is not most other cars, though.
I dropped the fronts to 20 and the car settled right down. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Mon May 28, 2018 9:20 am Post subject: Re: How poorly should a split drive? |
Tyre pressures quoted in the '46 manual are 17psi front and 23psi rear although I must admit I run my car at 17 - 26. I've always run Type 1 cars at something similar.
The only thing that effects the handling are tracks from heavy vehicles in the roadway when the car will try to follow which ever it fancies at the time. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
Posted: Mon May 28, 2018 10:35 am Post subject: Re: How poorly should a split drive? |
I have the tire pressures set per the 1950 manual, which was a big improvement over where the tire shop had them set (33 psi all around....yikes!).
Can rear alignment be performed on these early cars? I thought the slotted end plates came out later. I was under the car earlier & didn't see where an adjustment could be made, but maybe I missed it.
Will mess with steering box adjustment some more & see what that does for me.
Thanks again. |
Ovally Samba Member
Posted: Mon May 28, 2018 1:10 pm Post subject: Re: How poorly should a split drive? |
""Can rear alignment be performed on these early cars?""
Normally not necessary, but in case of a large deviation this can be done.
See page 59 "Einstellung der Hinterräder" https://www.volkswagen-classic-parts.de/repair_man...itel_H.pdf
The slotted end plates came later.
Have you renewed the spring plate bushings, inner and outer?
These will make a lot of difference the way your car handles.
Regards.
KoKane Samba Member
Joined: January 14, 2013 Posts: 38 Location: Finleyville, PA
Posted: Mon May 28, 2018 5:06 pm Post subject: Re: How poorly should a split drive? |
Check front end and align it. My 52 rides just as straight as my 59 and 65. Shouldn't be all over the road. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon May 28, 2018 5:45 pm Post subject: Re: How poorly should a split drive? |
Any dry or worn out front end parts? Have you greased your king pins with the tires off the ground? |
Ivan Fuller Samba Member
Joined: September 21, 2005 Posts: 149 Location: New Zealand
Posted: Mon May 28, 2018 7:53 pm Post subject: Re: How poorly should a split drive? |
Its been a long time since I did this but I thought rear toe in can be adjusted with shims at the front of the transmission - isnt there something in the factory maunual? |
Ovally Samba Member
Posted: Mon May 28, 2018 10:55 pm Post subject: Re: How poorly should a split drive? |
Ivan Fuller wrote: |
In case of a deviation, the factory manual says to enlarge the 3 round holes of the spring plate to slotted holes.
"Einstellung der Hinterräder" see page 59
Regards. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed May 30, 2018 6:08 pm Post subject: Re: How poorly should a split drive? |
... you have a lot of checking to do...
I sure enjoyed driving my two 1950s and early 1952 splits with 325 x 16 nylons and tubes, sometimes double or even triple clutching the non syncro trans, when changing gears, the musical, whining transaxle... were features that made it just about as primitive as a car could get... really was a great 35 to 40 mph car.,.. 165 x 15 XAS Michelins were better, back in the early 80s, but I liked the stock skinnys best... just take it slower and enjoy...
... just be thankful for the experience... you lucky-duck...
... you might be expecting too much.
Our '55 was all-over-the-road... needed a steering box and tie rod ends, probably from the silly fat tires and wide mags on the car... now with stock smoothies... _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Fri Jun 01, 2018 2:06 pm Post subject: Re: How poorly should a split drive? |
Another very important point is to center the steering box, this is probably the most cruicial part before doing any front end alignment.
If there are no marks on the box input shaft you will have to turn lock to lock and as accurately as possible mark the center position.
from there adjust the steering box play and then install your steering wheel in the straight ahead position, with this reference point now you can align the front end. _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
Posted: Fri Jun 01, 2018 10:21 pm Post subject: Re: How poorly should a split drive? |
I hate to sound like a broken record, but caster shims was what the factory used to fix just this problem. It adds more caster to the front end, meaning the car returns to a straight line more easily, like the front wheels on a shopping cart. I put them in a '63 that used to "hunt" (stock height), and now it goes dead straight down the road. They're cheap and easy to install between the bottom axle tube and the frame head.
I also agree with the suggestion by nlorntson to be sure the front end is well greased, because the link pins and kingpins can bind up. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
