Anyone know why the 72 calipers do not work on the 73?
database00
database00 is offline
PostPosted: Fri Jun 01, 2018 1:38 pm    Post subject: Anyone know why the 72 calipers do not work on the 73? Reply with quote
does it go the other way?
73 work on 72?
I know there is a difference between the disc brake setup for the front on a bay window just not sure what the differences are.
Thanks in advance.
CarlosZ
CarlosZ is offline
PostPosted: Fri Jun 01, 2018 2:17 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
I think the '73 uses a thicker brake pad so the distance between the brake pistons is a bit longer than the '72. Not sure if it'll bolt up though.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Jun 01, 2018 2:21 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
71 and 72 are one size and 73 on are another. Then in 1980 the size was the same as 73 on but the brake fluid inlet location changed.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
pioneer1
pioneer1 is offline
PostPosted: Fri Jun 01, 2018 2:33 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
You need to change the spindles with the year change
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
Tcash
Tcash is offline
PostPosted: Fri Jun 01, 2018 2:59 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
Brake Caliper ID T2
Disc Brake Conversions
database00
PostPosted: Fri Jun 01, 2018 3:34 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
Thanks guys.
Does anyone know if the spindles should have a part number on them and where it would be located?
database00
PostPosted: Fri Jun 01, 2018 3:41 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
Did i read that right if i measure the hole diamater I could also determin which one i need?
1971 Small calipers & rotors 12mm mounting bolts. Two versions, one bleeder valve early and two bleeder valves late.
1972 Small calipers & rotors 12mm mounting bolts.
1973-79 Spindles the same. Large calipers & rotors 14mm mounting bolts.
Tcash
Tcash is offline
PostPosted: Fri Jun 01, 2018 4:24 pm    Post subject: Re: Anyone know why the 72 calipers do not work on the 73? Reply with quote
That's correct.
If there is enough flang. U could drill and tap the holes to 14mm. Where only talking 2mm's
