nij_tp Samba Member
Joined: March 30, 2010 Posts: 140 Location: Amherst NH
Posted: Fri Aug 08, 2014 8:47 pm Post subject: rear hatch lock |
I did a search and came up blank. My question is I have a rear hatch lock and no key, there is a number stamped on the little piece at the end of the lock. The problem is the number is all 8's and 6's or maybe 9's. So which way up do I read it as it mskes a large difference to the actual number.
I do not have the other locks so please no helpful take the door look out and look at that please.
Thanks in advance. _________________ 1990 Vanagon GL _ Brunhilda (marked up as a Caravelle from new!) Just over 1/4 million miles, custom exhaust
1985 Vanagon GL - Josepha 140,000, Has a 2006 Forester 2.5 VVT custom exhaust
1989 Wolfsburg (Bluestar) - Walpurga
1989 Vanagon GL a parts bus
1984 Westralia
2006 Audi A4 2.0T with a unitronic tune
2007 Toyota Sequoia
1976 Mercury Capri 2.3l
1986 Honda Shadow VT700
2000 Suzuki Intruder VS800
1988 Kawasaki Voyager XII
2018 Chonda Hawk 250cc
1995 Subaru SVX (possible 3.3. swap) |
goffoz Samba Member
Posted: Fri Aug 08, 2014 9:23 pm Post subject: Re: rear hatch lock |
| nij_p wrote: |
Thanks in advance. |
Maybe I'm missing something, but....You have all of this
| nij_p wrote: |
1985 Vanagon GL - Josepha 140,000, Has a blueprinted balanced 1.9 WBX and custom exhaust
1980 Aircooled - Glasmalerei-Bus, going to use as a tow-behind trailer (one day!!!) Still Might BUT>>>>
1984 Westfalia cut down to tow behind Westralia
2002 TDi Beetle |
...and you've never done a cylinder to match you ignition key
here's a few links to get you started.
More results from www.thesamba.com
rekey door lock cylinder? 20 posts Apr 29, 2013
Ignition key won't turn... 15 posts Mar 19, 2013
Lock cylinder tumblers 8 posts Jan 5, 2013
82 Vanagon back door won't lock 12 posts Mar 16, 2011
VW Vanagon REkey ignition 1 of 3 - YouTube
Video for rekey vanagon lock cylinder► 0:19► 0:19
www.youtube.com/watch?v=MpoLrbNFSl4
Dec 24, 2009 - Uploaded by davideric9
Part 1 - Drilling the release access hole: How to remove the lock cylinder from your VW Vanagon -
VW Vanagon REkey ignition 2 of 3 - YouTube
Video for rekey vanagon lock cylinder► 0:53► 0:53
www.youtube.com/watch?v=APAn9s1CdSM
Part 2 - Removing the Lock Cylinder Housing: How to remove the lock cylinder from your VW Vanagon:
In case you didn't realise it the hatch cylinder is the same procedure
Have fun |
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1473 Location: Courtenay, BC, CANADA
Posted: Fri Aug 08, 2014 9:27 pm Post subject: |
Take it to a locksmith he should be able to figure it out and cut you a key. You might be surprised...the hatch lock might be the same key as he rest, it just won't open with a worn key. That's what happened to mine! I guess because the hatch is the least used and is isn't worn so it is the first to stop reponding to a worn out key. I had a key cut to code and all of a sudden the hatch started working. _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2408 Location: Adobe Jungle USA
jmranger Samba Member
Posted: Sat Aug 09, 2014 8:14 am Post subject: |
Depending on the model you have...
In the above picture, the top of the key code is on the right of the picture. Said otherwise, if you were to rotate the picture 90 degrees counterclockwise, you could read it normally.
In this picture, the top of the key code is on the left of the picture. Rotate clockwise to read.
Jean-Marc |
nij_tp Samba Member
Posted: Tue Jun 12, 2018 12:55 pm Post subject: Re: rear hatch lock |
@jmranger I never did thank you for this concise explanation
Thank you very much _________________ 1990 Vanagon GL _ Brunhilda (marked up as a Caravelle from new!) Just over 1/4 million miles, custom exhaust
1984 Westralia
2007 Toyota Sequoia
