VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10027 Location: Huntington Beach, CA
Posted: Sun Oct 30, 2022 11:56 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
I appreciate the encouragement esde. Your zwitter build is pretty amazing. It's clear you know your stuff. Flush the panel as you go...that's the part I wasn't following. Tack and hammer. That'll be my newest lesson learned. Now on to getting this panel back to where it needs to be. |
Agreed! You should really be backing up your seams. That’s the big one. Copper and Brass both suck up heat very quickly. So much so, that they reduce panel deformation. If you go back through my build, you will see and read about my use of my 2 Copper bars, 1” x 12” x 1/4”. I back up almost all of my welds. That helps to reduce the heat transferring across the panel, grinding on the back side and helps to hold the weld blob in position!!! Super cool (get it)!!!! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 282 Location: Colorado
Posted: Sun Oct 30, 2022 12:07 pm Post subject: Re: The 'Ol 55 |
I've been using copper backers since I started this project and can certainly see how much they help.
I saw in SD's (esde) thread when he was doing his door skin that the panel "sagged" once the rust cut was made. I think this was part of my problem and needed to be addressed as I went along the weld seam. There was a smaller low spot when everything was fitted up and I incorrectly figured I could solve that smaller dip once I was all welded in. This is the learning curve I guess. Ordered me the tool you recommended to get at the back side.
Thanks for the input Jimbo it is always welcome. |
esde Samba Member
Joined: October 20, 2007 Posts: 5993 Location: central rust belt
Posted: Mon Oct 31, 2022 11:22 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
Most of what I know is a result of mistakes, or things that could have been better. If I knew then what I know now..... I'm still improving my methods.
Really the great thing is that you're breathing some new life into this old car, and building some skills along the way. Keep up the good work. _________________ modok wrote:
Posted: Mon Oct 31, 2022 1:22 pm Post subject: Re: The 'Ol 55 |
esde wrote: |
Most of what I know is a result of mistakes, or things that could have been better. If I knew then what I know now..... |
That right there I think is inherently the foundation of my learning style. I wouldn't know a thing with any certainty if it weren't for learning from my mistakes. Not only that but look at the opportunity this has provided to figure out how to fix this problem?
Good to interact with New Joisy too...I was born not to far from Tom's Rivah/Asbury Pahk. |
Posted: Sat Apr 08, 2023 3:16 pm Post subject: Re: The 'Ol 55 |
Winter is just about spent (I'm knocking on wood...April can get deep here) so I'm trying to get some traction back. I've been pecking away at the driver rear quarter panel over the winter but only gaining ground a little at a time. Learning some of these metal shaping processes is a practice in patience.
I decided to step back from that and take a look at some other areas that either need some finishing or planning for the next step so I started looking at the bottom left quarter in front of the A pillar.
Nothing totally rusted through but clearly some cancer needs to be replaced and in looking at it I figured I better get my eyes on the door to be sure everything lines up right once I dive into the repairs.
Well the door, as so many other parts of this car, has it's own surprises. I knew there was a wrinkle on the quarter right behind the upper hinge but the door, as is, fits and operates ok. I also knew that the driver door needed a small weld up on the bottom where the support bracket had rusted off. Pretty minimal compared to what I've watched get repaired here on TS.
On further investigation the door has about 5# of bondo, primer and paint on it especially around the lower hinge area. Dr. Bondo was here big time. I think the door got sprung at some point and this led to the dent in the quarter behind the upper hinge and the cave in at the lower hinge on the door.
I've got some head scratching to do to plot out this process. Seems I oughta get the door squared away first, then tackle the lower quarter in front of the lower hinge area. I'll bang on the LRear quarter in the meantime as I get a plan of attack for the LF quarter areas and door. |
Posted: Sat Apr 08, 2023 9:49 pm Post subject: Re: The 'Ol 55 |
Good to see an update! On the door panel. Get a flap disc fora 4 1/2” angle grinder. Set the door up on saw horses, outside. Then, sand the surface off that door. Might take 10 minutes.
Then decide what is required.
Good luck! _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Apr 09, 2023 6:09 am Post subject: Re: The 'Ol 55 |
Thanks for looking in Jimbo...I'll get to working that door strip today...see what I've got to work with. |
Posted: Sun Apr 09, 2023 9:44 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
Have fun! I use 36 grit flap disc I buy at my welding supply store down the street. Just don’t let the tool sit in one spot too long. I keep the tool moving the entire time. I turn it on while it is sitting on the panel and quickly start moving it. When I power it down, I release the switch, while still moving, until the disc stops spinning.
Lots of extra work can be created from the heat generated by the disc, so be mindful of how hot the steel gets. Might be worth having a bucket of water and a sponge next to you. Just in case you get the heat up too high. Won’t happen if you keep moving, but always better to plan ahead, than be left holding your grinder in your hands!
TDCTDI wrote: |
Posted: Sat Apr 15, 2023 12:46 pm Post subject: Re: The 'Ol 55 |
I've got a few days elbow grease into the Driver's Door and I think I have been able to identify all of the areas that need attention.
Overall the door is in surprisingly good condition for 68 years of swinging from a tin can...
Dr. Bondo seems to have been a pretty good hand at the skim and fill processes. The door appeared pretty flat and the contours were all good...at the surface of the final coat of the black re-paint.... over primer, fill, primer, OG paint/primer. I took the 4.5" grinder to it with an 80grit flappy disc but given all the high spots around the depressions I was getting into metal too quickly/aggressively so I went to stripping to get it down to a point where I can see what needs attention.
The area right behind the front hinge is the point that took the beating from hyper-extension. I think that area can be pounded back to close and then skimmed, primed and sealed.
There are some spots, quarter to half dollar size, that have been leaded. There's a depression from the lower rear-latch side toward the hinge 6 to 8" long up about 4" from the bottom that was probably a crease at some point that got filled. I'm not quite sure how best to address this area. I'll try some hammer/dolly on it but the metal seems pretty fatigued. I'm pretty certain that whatever I try this area is going to get some fill. I'll do my best to minimize how thick/deep to call ok...1/16" seems like a good target...that'll be the next adventure: fill, prime and seal.
None of these areas had rust under the fill or showing on the inner side of the door.
The inner window brace? bracket on the bottom of the door rusted through the spot welds and got yanked out at some point so there's gonna be a patch piece I'll have to fab up there and then refit a new bracket. There's a dent above the window channel toward the front on the inside that'll need attention and the black paint removed from the inner side. It all adds up to a great start to spring shop/classroom time. |
esde Samba Member
Posted: Sat Apr 15, 2023 2:11 pm Post subject: Re: The 'Ol 55 |
The door skins are a tough repair. The curves are so gentle that they lack any strength, and the smallest dent can cause a ripple thats 12" long. After struggling with door skins forever, I bought a shrinking disc. Learning how to use it takes time, but it's definitely the right tool for high spots on a door skin, because if you don't shrink the stretched metal, you'll just push the problem around the door skin and make things worse.
Those doors are very nice BTW.
What are your plans for that spot at the lower A pillar? _________________ modok wrote:
Posted: Sat Apr 15, 2023 3:11 pm Post subject: Re: The 'Ol 55 |
esde wrote: |
What are your plans for that spot at the lower A pillar? |
Thanks for looking in on me SD.
Shrinking disc. I've heard of them but never attempted using one. Do you shrink from the middle of the depression or at the edges where the ridge is formed? Maybe it time to call in the experts. My neighbor owns a high end body shop. Full custom design, fabrication, restoration, paint, mechanical. I'll see if I can get a consult to get me moving in the right direction. I do think I've lucked out with the doors I've got and sure don't want to make things any worse than they are. Good feedback, thanks.
A pillar: I plan on cutting out the heaviest rust, leaving as much og metal as possible. It's not rusted up to the fold at the A pillar so I'll cut out what I can, leaving a bit of meat in front of the fold for a weld seam and fab up a patch with the fender weld nut in it. It's similar to what I did on the left rear fender curve where a fender nut area was rusted about the same amount/size. |
Posted: Sat Apr 15, 2023 10:24 pm Post subject: Re: The 'Ol 55 |
Agreed, doors skins are the hardest repairs, metal wise. You need to exert a lot of patience and hammer a lot. The welding shrinks the steel. The hammering stretches it back out. If you do it slowly, a few tacks at a time, it can be a great experience. But if you go onto 3, 4, 5, 6, 7 tack welds sequentially, well……you will be screwed. That will make for a bad experience, for sure!
I have started utilizing a wet rag to cool the welding area down. Sounds like this. Zzzzzz. Zzzzzz. Psssst. Psssst. Ssssssssssss (air being shot across the area).
TDCTDI wrote: |
Posted: Sun Apr 16, 2023 7:16 am Post subject: Re: The 'Ol 55 |
VW_Jimbo wrote: |
You need to exert a lot of patience...
Good luck! |
Patience...I've raised six kids so I know a little bit about that but this project has reinforced those lessons in some really practical ways. I do a whole lotta standing, looking, head scratching and then approach each step slowly. I never could have done this kind of work on a car when I was younger and impatient.
Luck...I don't know how much of that I have but I'll take all I can get!
Thanks for looking in Jimbo. |
Posted: Sun Apr 16, 2023 11:40 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
VW_Jimbo wrote: |
Good luck! |
Agreed! Kids require a decent amount of patience. Especially girls around 13 - 17 years old. Man, those are wicked hard years for dumb fathers. You definitely learn to bob and weave! Bite your younger till blood is flowing down your throat! That is my introduction to learning patience. Before that, I was a Bull in a China shop!
You are smart to stop and think! That is wisdom taking control! I, myself have just started being able to do that, STOP. Stopping is awesome! It keeps one from making things much worse! I am still a student here, but am hopeful I will graduate in the future. This is why I am still a student!
Keep at it! I will be updating my thread today I hope. I ended up walking away from the Bug, to keep from fucking shit up any further. It eats at my very core to walk away from anything! Let alone a piece of steel, sitting proud in my garage. But I had to.
Luck is a generic term for unclassified skill. Once you can repeat a task, with a anticipated outcome, it changes from “luck” to SKILL! You have to have luck before skill. From one tradesman to another, keep practicing, it gets better! _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Aug 09, 2023 11:37 am Post subject: Re: The 'Ol 55 |
I've been in the hammer and dolly school for the past several months... studying patience and persistence among other things.
There was a pretty good oil canning dent at the latch side of the door
and a crease that runs about half the length of the door.
There's evidence of some previous work with a hatched hammer or slapping file (for shrinking?)on this area. It didn't seem to eliminate the oil cannning or low spots so it was all filled with 1/4" or more of bondo.
I've got the oil can worked out and most of the crease low spot moved back out to a reasonable level.
The lower hinge dent is kind of stumping me as far as how to get this crease pushed back out and flattened.
No way to get in behind it with a hammer to drive the dent out so I've been trying to get it to come out a bit at a time with pressure from the inside, gentle nudging from the outside...
I got a decent rear apron for a future project which is going to require a reposition of the rear rotisserie stand into the engine bay and supported at the rear body mounts.
Another head scratcher project to get done while the warm weather holds.
Once I get the rotisserie back in order I'll work on the front quarter panel cancer.
I've got the patch made so I just need to take the plunge and cut out the rot and weld in the new metal.
One small step at a time... |
markendee Samba Member
Joined: April 30, 2009 Posts: 253 Location: Kyabram, Australia
Posted: Thu Aug 17, 2023 3:05 am Post subject: Re: The 'Ol 55 |
For the life of me tehillah1 I do not know how I haven't come across your build thread until now.
It is fascinating and so very well done.
Will be watching and looking forward to the finished piece of art.
Regards,
Mark. _________________ Member # 145244 |
Posted: Thu Aug 17, 2023 6:15 am Post subject: Re: The 'Ol 55 |
Thanks for looking in on me Mark and the kind words of encouragement. I've certainly enjoyed following your build and hope I can accomplish something approaching your results...I'm just shooting for getting the 'Ol 55 back on the road in drivable fashion with whatever upgrades are logical and easy. Disc brakes, updated fuse block (similar to what you've done), '68 tranny, 1600 motor...those sorts of bits that'll make the experience that much more fun than last time I drove her.
Jim |
Posted: Thu Aug 17, 2023 7:08 am Post subject: Re: The 'Ol 55 |
It is looking great Jim! Keep up the great work. That spot on the door is a BITCH to get to, to make flat. I am dealing with that same issue on my top hinge on one of the doors. My best luck has come from a long segment of steel bent to get in back of that spot. It takes a few hours to make, but worth it. Slide it in there, right under the deformed skin and back it up, tight. Then while holding all that together, small hammer taps, slow and steady. Create no heat. Don’t hit it to hard, either. No stretching. As you strike the steel lightly, slide the hammer, at the same time as the strike, so the hammer strike is across the surface, not just pin pointed in one spot. Like in framing when the nail needs to go a different direction and you hammer it down and to the side. I find this helps to shrink the area, just a little. Might be my hopeful imagination, but I really think it shrinks the steel a bit. I have had great results using this technique. Let me know what you get. _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Aug 17, 2023 8:39 am Post subject: Re: The 'Ol 55 |
Thanks for checking in on me Jimbo...I'm following along just like you've described though I've got a piece of doug fir shaped to the door curvature wedged in there and with lots of little taps things are moving back to something workable that won't have 1/4" of bondo filling the canyon. Baby steps...they'll get me where I'm going. |
Posted: Fri Oct 20, 2023 2:05 pm Post subject: Re: The 'Ol 55 |
I thought I would throw an update out here since I've been stalling around avoiding cutting into the A-pillar.
I've got the left door pretty close, shape-wise. There were a couple of rust holes in the bottom of the door where the inner bracket rusted off from the inside.
I've cut out as little of the og metal as reasonable, put a couple of small patches in
and then set up the window track support bar ( I don't know what else to call this part...)Welded in the base bracket.
The door is in better shape than it has been for 40 years though it still needs a lot of paint prep
I love it when I find date stamps that match the date this car was made...
I've been doing little patches here and there to get my welding mojo in order before I tackle the repair on the lower a-pillar, outer on the driver side.
I dug out the left front fender anticipating some fitment installs prior to the a-pillar repair. It's in pretty amazing condition given it's age.
I don't think this is an original fender and it may be a non-bullet fender, period correct, from a semaphore car, or later (58-60???) non-bullet fender. I don't know all the nuances but the bullet signal on this fender looks to have been added, non-factory. The right fender bullet is much cleaner/tighter fitting
The fender has a few minor rim cracks that I'm gonna work over
and bottom of the headlight bucket could use some repair.
then, with a bit of prep I've got a serviceable fender ... |
