Dan22 Samba Member
Joined: August 30, 2019 Posts: 711 Location: Battle Ground, WA
Posted: Mon Jan 13, 2020 8:33 pm Post subject: 40 HP flywheel ring gear? |
Has anyone put a ring gear off a 40 horse flywheel on a 36hp flywheel? I pressed one off pretty easily.
I am thinking about it since the 36hp teeth get hammered by the starter.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26248 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jan 14, 2020 5:51 pm Post subject: Re: 40 HP ring gear? |
| Dan22 wrote: |
I am thinking about it since the 36hp teeth get hammered by the starter. |
No, but the replacement starter ring gear should be the same. Would be good if you updated the title to include "Flywheel". That way it is easier to do a search for volks in the future. Thought you were referring to a ring and pinion.
Why is your starter hammering the flywheel ring gear? Are you running 6 volt starter on 12 volt?? _________________ In Stereo, Where Available! |
Bub Samba Member
Joined: June 10, 2004 Posts: 1331 Location: Central Washington
Posted: Tue Jan 14, 2020 8:26 pm Post subject: Re: 40 HP ring gear? |
[quote="Eric&Barb"]
| Dan22 wrote: |
Why is your starter hammering the flywheel ring gear? Are you running 6 volt starter on 12 volt?? |
If it's the 12v / 6V spinning starter problem you can press a 12V ring gear onto a 6V flywheel. Same amount of work as 6v/6v.
I'm sure you can still buy new 12V ring gears too. _________________
| hitest wrote: |
| Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
jason Samba Member
Posted: Wed Jan 15, 2020 11:05 am Post subject: Re: 40 HP flywheel ring gear? |
| I purchased and had one installed at rimco. |
Dan22 Samba Member
Posted: Wed Jan 15, 2020 4:41 pm Post subject: Re: 40 HP ring gear? |
| Eric&Barb wrote: |
| Dan22 wrote: |
Not running 12V on the starter. Just noticed old used flywheels have a lot of tooth damage due to softer metal gear teeth. I would either put a ring gear on, or at least dress the old flywheel teeth with a small grinder.
Glad to know others have done this upgrade.  |
Posted: Wed Jan 15, 2020 6:02 pm Post subject: Re: 40 HP flywheel ring gear? |
If you dress the teeth with each two angles (using a hand file or small power grinder) so the starter gear is shunted into between the teeth of the flywheel, that should stop the tooth damage. _________________ In Stereo, Where Available! |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1924 Location: Fontana
Posted: Wed Nov 27, 2024 9:44 pm Post subject: Re: 40 HP ring gear? |
[quote="Bub"]
| Eric&Barb wrote: |
| Dan22 wrote: |
I'm sure you can still buy new 12V ring gears too. |
since Rimco closed I called Brothers they said they're not doing it yet . anybody else can press a 12v ring gear onto a 6v. flywheel --- I have a 36hp that s 6v I want to go 12volt . I also need to change the generator to 12v and keep it small _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Posted: Thu Nov 28, 2024 11:12 am Post subject: Re: 40 HP flywheel ring gear? |
One can use the 6 volt starter on 12 volts since that motor is only used for short "starting" bursts. Best though to replace the 6 volt starter solenoid with 12 volt version to skip the starter gear from bashing the flywheel gear teeth too hard. _________________ In Stereo, Where Available! |
