2003 Eurovan stalling on highway in heat.
Page: 1, 2, 3, 4  Next
Habbyshaw
Habbyshaw is offline
PostPosted: Sun Jul 22, 2018 8:57 am    Post subject: 2003 Eurovan stalling on highway in heat. Reply with quote
2003 Eurovan currently in Dallas (Driving cross country from Boston)
The issue is heat related. The motor is shutting down during the heat of the day. Starts back up after stall. Sometimes you need to wait a few minutes and pump the gas pedal. When the sun is out you can only drive a mile or 2 before it shuts down. When the sun goes down you can drive 100+ miles with no stalls.
Parts replaced
rebuilt transmission
External trans cooler (leaking)
Fuel pump (replaced twice in 2 months)
cam shaft position sensors (2)
crank shaft position sensor
New fuel pump relay
Last shop that worked on it diagnosed "loss of fuel pressure" and replaced the fuel pump. Claiming the one that was installed a month earlier could have been faulty. Drove it out of the shop and 100 miles later it did the same thing.
The engine has thrown 2 codes but they seem to be unrelated. One is a TCM code and the other is a Crank Shaft Position sensor code. these codes appear when the van is coasting to a stop and the motor restarts and the transmission is moving at a different speed then the motor causing it to clunk and throw a code.
I know this is totally insane but the last time we drove the van with the sun in the sky the van broke down every mile until the sunset. once the sunset the van drove with no problems for 100+ miles.
Can the sun cause electrical issues?
If anyone has any suggestions as to what this issues could be related to it would be greatly appreciated.
Also looking for shops in the Dallas area that might be able to help.
Thank You!
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Sun Jul 22, 2018 2:30 pm    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
A crank position sensor code is a crucial one and shouldn't be ignored. I would suggest replacement. This is likely your issue.
On initial read I was thinking fuel vapor lock but with CPS code I'd start there.
Habbyshaw
PostPosted: Mon Jul 23, 2018 6:27 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
CdnVW- thanks for your reply, I’ve checked for vaper lock - no evidence at the fuel cap. - I’m going to have a mechanic in Dallas check the Crank Shaft Position sensor today and report back.
PostPosted: Mon Jul 23, 2018 10:54 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
If the CPS has triggered a code there's something amiss. Either wiring chewed/frayed, corrosion or the sensor is failing.
EuroTec
EuroTec is offline
PostPosted: Wed Feb 09, 2022 5:11 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Old thread but I'm just going to throw this out there.
I have 2003 T4 that stalls when it's hot outside and the AC is on. I have seen at least three other owners have the exact same issue, especially with the AC on.
I think I know what the issue is. Overheated ECU. It has all of the classic symptoms of an overheated power transistor. They simply fail to operate when they reach a critical high temperature. After waiting a few minutes, they cool down and work again.
The relationship to operating the AC was a clue. Since VW decided it would be a good idea (NOT) to mount the ECU in the battery compartment, it is subject to a lot of heat from the engine, radiator and the AC condenser which can get very hot. With the AC on the air coming into the engine bay gets very hot as it passes through the hot AC condenser coil and overheats the ECU causing it to go into thermal shut down.
Yesterday, I pulled my ECU, removed the cover and was amazed to see that NONE of the power transistors have heat sinks! Adding heat sinks is usually common practice with these electrical components.
So, what to do? Relocating the ECU would involve splicing MANY wires to extend the harness. Yes it could be done but it's a daunting task. My solution is going to be reducing the amount of engine bay heat that reaches the ECU. While it does have a plastic barrier near the battery, it's evidently not enough. There are many places that hot air forces it's way in.
I plan on adding some insulation to the barrier and sealing off the battery compartment better. I also will look into installing a small muffin fan (like you would find in a computer power supply) behind the headlight assembly to bring in fresh air and help keep the ECU cooler. An alternate solution may be to add a vent to the hood to allow air to enter the battery compartment.
I've seen similar overheat issues with other Motronic ECUs in European cars. They stall, then run again after a few minutes cooling time. I once diagnosed this on a 1985 Porsche 911. The ECU is under driver's seat. After some drive time on a hot day it would run rough then stall and every time the ECU was so hot you could barely touch it! I removed it from it's mounting so that I had access to it, drove it to a failure point where it was barely running and stumbling at idle, pulled over and put a bag of ice on it. It immediately started running perfect again. That ECU did have heat sinks but the problem was aged out transistors. It got sent off for a rebuild.
I'll post results of my efforts with some pics in another thread which I will link here later. Hopefully I find a solution and solve others from going down many rabbit holes replacing sensors and guessing with no success in an effort to solve this very common problem.
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
MrPulldown
MrPulldown is offline
PostPosted: Wed Feb 09, 2022 10:39 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Have you looked at the running voltage with the AC on and hot outside. MY EVC will get down to 11.8 volts if the outside temp is over 100 with the AC on and idling. I swapped out a voltage regulator and it got a little better and have not been able to test in hot conditions yet.
2002 EVC
OB Bus
OB Bus is offline
PostPosted: Wed Feb 09, 2022 12:29 pm    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Same with ours. The cooling fans draw a lot of juice. Idling on a hot day with the A/C on high freeze gives us 11.9 volts.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
EuroTec
EuroTec is offline
PostPosted: Sun Feb 13, 2022 8:20 pm    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
If that were the case, why then would it start after several minutes and continue to run with those same items turned on?
TheOneTrueQuux
TheOneTrueQuux is offline
PostPosted: Mon Feb 14, 2022 7:50 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Hypothesis:
Sometimes this can happen with a failing connection or relay. As it heats up, the resistance increases and the voltage drop also increases. Let it cool down and the situation temporarily improves.
EuroTec
EuroTec is offline
PostPosted: Tue Feb 22, 2022 5:24 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Yesterday after driving for 3.5 hours in the Eurovan, it stalled at highway speed. I had my Autel scanner with me so I connected it up and pulled up the live data window. Monitored voltage at ECU. Of course it started up after a few minutes and I was on my way again. 3 miles later, stalled with ECU voltage at 13.5. That rules out a voltage drop as the issue. I then jumper wired the fuel pump relay, waited a few minutes for the cooling off period and started on my way again. A few miles later, stall. That ruled out the fuel pump relay. Immediately pulled up crank speed sensor live data and engaged the starter. It registered RPMs so that ruled out the crank sensor.
I then checked injector timing live data while cranking and it showed 0. That means there was no injector pulse which comes from the ECU as switched ground. The positive feed for the injectors comes from circuit G1/8 which is the V+ output from the fuel pump relay, same one that runs the fuel pump. It goes through fuse #18 20amp. For some reason, the ECU was not sending an injector pulse from pins 88, 89, 96, 97, 112, 113.
It got worse from there stalling every few miles. Fortunately it was only several miles from home. The gremlins were kind to me. It sits in my driveway now. Smile
I have ordered a used ECU from Ebay that has the immobilizer deleted. The only key I have to the van is a plain cut key. The original must have been lost years ago. The PO had the ECU replaced once with a used unit, probably in a
"guess" attempt to solve the stalling when hot issue. It must have had the immobilizer disabled/deleted as well. I still think the problem lies in a component thermally failing in the ECU. I'm going to remove mine and trace the injector pins for the injectors and see if I can find anything.
The saga continues. I WILL find what this common issue is and post all details in a separate thread when I do but for now I'll keep it updated here.
If it ain't broke, don't fix it!
TheOneTrueQuux
PostPosted: Tue Feb 22, 2022 8:02 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
I think this might point to something else. Most of these ECU output channels output what they "THINK" the channel is doing, not what it actually is. I.e. the ECU thinks it is or isn't providing injector pulses, failed hardware on the output stage would not influence this.
Doesn't this vehicle have both a crank position and a cam sensor? Losing cam data could possibly cause the ECU to know that the engine is turning, but not know enough to run, resulting in the symptoms you've seen.
EuroTec
EuroTec is offline
PostPosted: Tue Feb 22, 2022 10:53 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Both cam position sensors are brand new. I had them hooked up backwards when I first did this transmission swap and they threw codes so I know they are working. When I checked the injector pulse on the scan tool, I cranked it for a full 20 seconds. That should have been plenty of time for it to output something. I still suspect the ecu.
I ordered a new VDO fuel pump today. Previous owner had it replaced but I'm suspicious of its quality. Installing a VDO pump will at least assure me that there's a quality pump in that tank.
TheOneTrueQuux
PostPosted: Tue Feb 22, 2022 1:15 pm    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Did this problem exist before the cam sensors were replaced? There's some shady aftermarket stuff out there for sensors too.
Do you have access to an Oscilloscope? You could probe these signals and see if they are doing what they're supposed to.
EuroTec
EuroTec is offline
PostPosted: Tue Feb 22, 2022 1:34 pm    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Yes this problem was there when I bought the van. PO had the crank and cam sensors replaced, no difference. It still "stalled on hot days with the AC on".
I have a good hand held scope but it was at the shop yesterday when the problem was happening at home in my driveway.
That's the issue with this common problem. It's intermittent. That makes it very hard to diagnose because it needs to be in fail mode when diagnosing it!
I'm going to put the scope in the van, get some leads connected up and drive it until it fails then check waveforms. Problem is, it has to be driven a long, long, long time to make it fail.
Here's the ECU circuit board. I've labeled the two Bosch 30344 fuel injector driver chips. They also serve to drive relays in other devices off from the same chip. They are a very vulnerable chip but there are two of them so it would be uncommon for them to both fail at the same time. They do both get voltage from the same supply so it could be that somewhere on the board a component is failing when hot that does not allow voltage to get to those chips. Voltage regulators are common failure points on anything with switched power.
EuroTec
EuroTec is offline
PostPosted: Tue Feb 22, 2022 2:34 pm    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
This is the Bosch 30381 ECU driver chip. It's job is to supply regulated power out of four outputs to feed power to the board.
If it gets very hot due to age and fails, that would pretty much kill everything.
In my 30 plus years of working on cars in ecu's I've seen this thermal failure scenario manifest itself in lots of different chips and transistors.. It's always about a drive cycle up until the chip gets hot and just will not physically work anymore. The only way to troubleshoot it is to get it to fail and either quickly cool it with some liquid CO2 (can of compressed air keyboard duster tipped upside down) and see if it comes back on or just swap out an ECU real quick and see if the car starts.
I did this once on a Toyota MR2. It would start run for about 10 or 15 minutes and then fail. If you waited about another 10 or 15 minutes it would restart. So, we opened up the ECU, had a can of CO2 ready, let the car run 15 minutes, sprayed and cooled down the two injector driver chips, tried to start it, bingo! Needed an ECU.
The beauty of the CO2 method is it's handheld, and you can pinpoint one chip at a time spray it, and try to start. If it starts right up after cooling one off that's your problem. You need an ecu or a repair/rebuild.
TheOneTrueQuux
PostPosted: Wed Feb 23, 2022 9:58 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Have you thought about artificially heating suspected components to force a failure? I.e. hot air gun directed at the suspect power supply and driver ICs?
You'd need to be careful not to overdo it, but I'd think a stream of 160 degree air wouldn't permanently kill anything.
EuroTec
EuroTec is offline
PostPosted: Fri Feb 25, 2022 4:19 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Yes I have. I have a reflow solder heat gun that I could use with a pinpoint tip about 5mm diameter. Reflow solder melts around 220C/428F. 70-85C is where most semiconductors will stop working so with a bit of heat applied I could indeed make a component fail.
I currently have the cover off my ECU. The plan is to put in back in the van with no cover, start the engine and preheat the entire board with the heat gun. Once that's done, I'll run it at 2500-3000 RPM for a time then measure the temps of various components with an infrared thermometer. The goal is to find the ones that run hottest and see if I can engineer some kind of heat sink to help them stay below the failure temperature. I'll use my existing ECU as a test device. The second one I bought on Ebay has arrived but I'll keep it as a spare for now.
BUT, before I do anything with heat sinking I'll install the original ECU and take a trip with it. If and when it fails it will usually restart after a few minutes but it will shut down minutes later, repeatedly, until it sits unpowered for 20-30 minutes. If I can get it to fail out on the road, I'll give the hottest components a blast of liquid CO2 one at a time to cool them until it starts back up, then try driving it and see how long it functions. Alternately, I could swap in the newer ECU and see how it performs.
Either way, if it motors on down the road with no incident I'll then know the problem lies in the ECU overheating and I'll get to work on those heat sink mods.
TheOneTrueQuux
PostPosted: Fri Feb 25, 2022 8:03 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
You could also have a bond wire failure within the package, or the die might not be attached well enough to the package anymore, leading to high thermal resistance. Neither of these will be really fixed by adding a heat sink once they're failed.
wannabecamper
wannabecamper is offline
PostPosted: Fri Feb 25, 2022 8:16 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
Did you ever check the coil pack to see if it is failing at higher temp?
EuroTec
EuroTec is offline
PostPosted: Fri Feb 25, 2022 8:50 am    Post subject: Re: 2003 Eurovan stalling on highway in heat. Reply with quote
It's a VR6 24V with coil over plug.
Page 1 of 4
