Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Wed Feb 06, 2019 7:48 am Post subject: Wolfsburg West side window seal issue |
Has anyone had issues with WW side window seals? Specifically the camper (no chrome) passenger's side, rear, no vent window (I know it's the same as the middle).
I'm helping a buddy with new seals and this one is not even close to working. Honestly feels like it's too big. When it's fully around the glass there is still a bunch of slack and the rubber keeps popping off the glass in multiple spots. I've done several of these with no issues. We even did the rear window in 10 minutes and it was a breeze like usual. Fought the side window for over an hour with no luck. Only thing I can think is bad seal. _________________ 1976 Westy
1966 Beetle |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Wed Feb 06, 2019 8:02 am Post subject: Re: Wolfsburg West side window seal issue |
Every seal I've used from WW (including side windows) has been perfect. Are you sure it's the right seal for that window? _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
a1steaksauce Samba Member
Posted: Wed Feb 06, 2019 8:14 am Post subject: Re: Wolfsburg West side window seal issue |
You have the sticker with the part number on it still? I’d double check that first.
I replaced the window seal in the exact same location with a WW seal and it fit fantastic. A couple of months later I deleted the wing window on the drivers rear and installed the larger glass, again with WW seal and had zero issues. |
Bala Samba Member
Posted: Wed Feb 06, 2019 8:19 am Post subject: Re: Wolfsburg West side window seal issue |
We double and triple checked the label and packing list. Those say it's the correct one. I'm not sure what seal it could be swapped with? Every site I've checked sells the same seal for all side (non-vent) windows. I think the hatch window is the closest, but it's quite a bit smaller (relatively).
Anyone know the diameter the seal should be? I know it's tough to measure, and I feel like if it's off even a tiny bit it will effect the fit. _________________ 1976 Westy
1966 Beetle |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Feb 06, 2019 8:47 am Post subject: Re: Wolfsburg West side window seal issue |
Sorry to hear about the window seal difficulty, Bala.
A couple weeks ago, Robbie showed me how to replace one of my rear, side windows using a WW seal. He mentioned it was a little bit loose, (we had to hold it in place around the window while installing it to keep it from falling off), but we were still able to get it in okay. Now that it's in, the fit is great. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Wed Feb 06, 2019 9:29 am Post subject: Re: Wolfsburg West side window seal issue |
The rear and middle windows don’t take the same seal.
Middle windows are 221 845 321A and rear windows are 224 845 341. This is for non-deluxe rubber with no vent windows.
Yes, the last WW rear window seal Kent and I did “felt” too big on the glass, but installed perfectly. This was the 341 part number.
www.airschooled.com
Bala Samba Member
Posted: Wed Feb 06, 2019 9:41 am Post subject: Re: Wolfsburg West side window seal issue |
KentPS wrote: |
A couple weeks ago, Robbie showed me how to replace one of my rear, side windows using a WW seal. He mentioned it was a little bit loose, (we had to hold it in place around the window while installing it to keep it from falling off), but we were still able to get it in okay. Now that it's in, the fit is great. |
Thanks, never had this much trouble with a seal.
We tried that too. Still the seal was way too loose. Popped off the glass all over the place. _________________ 1976 Westy
1966 Beetle |
Bala Samba Member
Posted: Wed Feb 06, 2019 9:57 am Post subject: Re: Wolfsburg West side window seal issue |
asiab3 wrote: |
The rear and middle windows don’t take the same seal!
Robbie |
The invoice shows the 321 as "CENTER OR REAR". Looks like WW shipped the wrong seal and might need to get their descriptions straight. Call in order, so they should have know what part to ship.
Oh well, my buddy ordered the correct "German" seal from another vendor.
Thanks all! _________________ 1976 Westy
1966 Beetle |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1039 Location: Calgary, AB
Posted: Wed Feb 06, 2019 9:59 am Post subject: Re: Wolfsburg West side window seal issue |
asiab3 wrote: |
Robbie |
I see WW offers the 2 different seals for those windows, but West Coast Metric shows the same seal for both. I realize that isn't the brand the OP is using, but the size of the seals must be at least very close to the same if that's the case. It shows different part numbers for the seals that take the deluxe chrome trim, but not for the Cal Look seal like the OP is using. |
Posted: Wed Feb 06, 2019 10:03 am Post subject: Re: Wolfsburg West side window seal issue |
Huh, that’s interesting. Perhaps give them a call and ask? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
elcoqui Samba Member
Joined: November 10, 2018 Posts: 44 Location: kissimmee, Florida
Posted: Mon Feb 11, 2019 6:10 am Post subject: Re: Wolfsburg West side window seal issue |
I had the same issue with mine... and came to find out "or at least" this is what worked for me was to re-grind all the old bondo around the gasket perimeter, and notice all around it had way to thick of a coat... I slimmed it down, and the glass went in...no trouble.... just my 5cents..... _________________ some will love you for who you are, and some not for the same reason,,,,get used to it.
Coquí is the common name for several species of small frogs in the genus Eleutherodactylus native to Puerto Rico. The common name coqui is due to the sound they make at night. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Mon Feb 11, 2019 7:41 am Post subject: Re: Wolfsburg West side window seal issue |
I also noticed the WW says that their seal is for "left or right". The original seals are not symmetrical like that -- they are mirror images of another shape.
How do they think that left and right seals would be the same? Have people actually got the same seal to work on left and right? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Mon Feb 11, 2019 1:18 pm Post subject: Re: Wolfsburg West side window seal issue |
jtauxe wrote: |
How do they think that left and right seals would be the same? Have people actually got the same seal to work on left and right? |
For the two rear most windows on the sides? Yes, I have using WW seals.
And as a matter of fact I got a piece of glass from a donor 73 that came off the passenger rear window and I installed it on the drivers side rear window location on my 69 without issue. I didn’t want that vent wing window so that’s how I deleted it.
Those two rear most side window openings are the same size. |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Wed Feb 13, 2019 7:36 am Post subject: Re: Wolfsburg West side window seal issue |
jtauxe wrote: |
I just re did mine and can honestly say I struggled with one, switched sides with it and it went right in. I always assumed they were exactly the same on both sides. Are they not? _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
stevo Samba Member
Joined: January 22, 2004 Posts: 908 Location: the eugeniverse
Posted: Mon Jan 24, 2022 11:13 pm Post subject: Re: Wolfsburg West side window seal issue |
I'm having some problems with my rear sides. For my 69 deluxe I ordered one rear without vent wing, and one rear with vent wing from WW in November. Reusing my original vent wing since it is in great condition. Reusing my deluxe chrome, also mint original German. I delivered my engine-less bus on a tow dolly to my decades long trusted nearby glass installer. After a few days he called to say he had the whole shop working on the installation only to give up and surrender claiming the seal was too thick. I was able to get into another glass shop, farther away but highly reputable. Rented a tow dolly again and delivered the bus this afternoon. Same result - whole staff on the project.
Each shop phoned WW at my request who really didn't have much to say about the situation. I returned home, returned the dolly, called WW. I discussed the situation with staff. I'm out $100 in seals and $100 in tow dolly rentals. I tried to talk staff into a returned item. Deal is one of the staff is installing a deluxe rear window and will try one of my seals on his deluxe window installation next week. _________________ When you cross an Irishman, they never forget. I mean, never. |
Joined: January 01, 2007 Posts: 16889 Location: sticksville, ct.
Posted: Mon Jan 24, 2022 11:35 pm Post subject: Re: Wolfsburg West side window seal issue |
unless something went bad, i use the WW seals without issue. in fact, i prefer them.
usually you have to stretch the fuck out of them to get them on the glass.
when i did my deluxe it took me almost a week of nights installing the chrome trim. it is an epic pain in the ass to get it fully seated and your thumbs will be just about ready to fall the fuck off when you're done
are they installing the trim into the seal? it's wicked tedious and i honestly couldn't imagine having to pay someone to do it. it's an ez hour or so per window to do.
that said, which window are they having an issue with, all of them or the one with the vent window? if it's the one with the vent window it's a bit of a pain to get in and i leave the vertical part till last when roping it in. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
stevo Samba Member
Posted: Mon Jan 24, 2022 11:50 pm Post subject: Re: Wolfsburg West side window seal issue |
The crew at the first shop placed each seal on the glass panels, then installed the chrome trim before attempting the install on the bus. Or they installed the chrome first then the seal onto the glass. I was not there. But they were not trying to put the chrome on afterwards. The second shop had all that done ahead of time for them. Still no luck. At the second shop I had the chance to watch because they were cool enough to work on the bus while it was still on the dolly. They really slugged it out they way the first shop described. I too am a huge fan of WW products. Their deluxe windshield seal went in easily last week on the bus in question, done by the first shop.
When I cannot get NOS German, I use WW. After that it appears to be a huge drop off which is why I'm writing - to see whether others found difficulty, or heard of complaints that the seal was "too thick". _________________ When you cross an Irishman, they never forget. I mean, never. |
germansupplyscott Samba Member
Posted: Tue Jan 25, 2022 1:01 pm Post subject: Re: Wolfsburg West side window seal issue |
skills@eurocarsplus wrote: |
...which window are they having an issue with ... |
I'd like to know this also. If they are having an issue with the fixed portion of the vent/fixed window combo, that's a lot different than having an issue with the full length fixed window. The fixed glass with the vent is a really tough job, proabably the most challenging job on a Bay Bus when doing glass installation. Adding Deluxe trim only makes the challenge greater. If the Bus has been painted, probably worse again.
I'd also wonder about Stevo's comment about "using the original chrome trims" playing a part in this. What do the original trims of a '69 deluxe look like? Are they anodized aluminum? Is it possible the cross section of the aluminum trims is different (larger?) than the more typical extruded plastic Deluxe rubber trim? A (laborious for sure) way to test this would be to try installing the windows with the same seals but without the trims in the seals.
The hardest part of the vent/fixed combo is getting the vertical part of the fixed glass to move inward enough to get past vertical part of the vent assembly. Another test you might do is install the fixed portion without the vent installed and it might tell you something about why it's proving so difficult, where the hang-up is originating. _________________ SL |
Posted: Tue Jan 25, 2022 1:40 pm Post subject: Re: Wolfsburg West side window seal issue |
germansupplyscott wrote: |
I'd also wonder about Stevo's comment about "using the original chrome trims" playing a part in this. What do the original trims of a '69 deluxe look like? Are they anodized aluminum? |
yes, it would be the aluminum trim. it's a C shaped trim and honestly it's a bitch to get it in. it seats DEEP into the seal.
i don't see how that would have any bearing on fitting the window as it's on the outer lip.
it's hard to describe how i do the fixed glass with the vent window but you have to 100% make sure you shove that vent ALL the way in.
then i pull the rope to the rear and finish at the vertical bar. while doing that, the seal stands proud a bit before it gets sucked in and i have someone shove the window rearward as i do the pull.
honestly, it's not that bad. i will be sad to find out if it is a WW seal issue as they were my go to in the past _________________
Jake Raby wrote: |
Brian wrote: |
