caseydenise Samba Member
Joined: April 25, 2004 Posts: 1639 Location: The Great Swamp, NJ
Posted: Sat May 08, 2004 10:23 am Post subject: HYDRAULIC CLUTCH ?!?! |
I've seen this mounted on a few sandrails. I meet a guy who was building a VW Trike and he had it mounted on there. It looked like it had a pressurized hose( like a brake line), going into it, then conected to the clutch lever, where the cable would normally pull. It was just a small actuator looking thing. My clutch is hard (uncomfortable) for my wife to drive. Would this mode make it easier? Thanks
--Casey  |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4196 Location: Boston, MA
Posted: Sun May 09, 2004 8:13 pm Post subject: |
| Hydraulic clutches are much easier on the leg. I've got 'em on my Vanagon and VR6 Passat wagon. My wife has no problems driving the Passat. I'm not sure about the particular set-up you are talking about, but in general they make it easier to operate the clutch. |
Posted: Thu May 13, 2004 8:18 pm Post subject: |
Still want to know what the heck this thing is. If anyone has a picture that would be sweet. Thanks
-Casey |
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2862 Location: Northeast Florida
Posted: Fri May 21, 2004 8:28 am Post subject: |
Uh, It's a hydraulic clutch. Lots of guys run them in sandrails, but they would be a pain to mount in a 'glass buggy, due to the pedal and reservoir size. If you take a look at your stock pedals, then compare them to the hydraulic pedal sets (BP200X and BP1A) in the link below, you'll see where fitment will be a challenge. Especially making room for the reservoirs in your buggies front 'firewall'.
http://www.jamarperformance.com/products/pedals.htm
What pressure plate are you running in your buggy? A feeble old lady ought to be able to collapse a stock pressure plate with the clutch pedal. _________________ OG JHC
don't worry, the ciggaret is fake. |
Ragman The Sambinator
Posted: Fri May 21, 2004 10:52 am Post subject: |
I could see where she might have a hard time working a 1700 or 2300 Kennedy clutch. Stock one should fine though. Of course, there's always a AUTOSUCK!  |
