long input shaft with a short snout for 091 transmission?
DrElch
DrElch is offline
PostPosted: Tue Mar 12, 2019 2:06 am    Post subject: long input shaft with a short snout for 091 transmission? Reply with quote
I'm basing my question on the following thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8147746#8147746
In this Thread two shafts are mentioned: The long and short one. With the short one being 287mm and the long one 298mm.
Today I have looked at the two shafts I have available and I realized that I have one even shorter than 287mm. This shaft is from an early CA Transmission, while the longer one is from a CU Transmission that was delivered by VW as a strange 002/091 hybrid. Where the Main body is from the 002, while the rest of it is from the 091.
I've tried to mate the alledged 091 clutch casing with my '79 2.0 CU-Engine, but the 287mm shaft seems to be too long and hits the end of the pilot bearing.
I have to look into this more carefully, but I'm at my wits end for the moment as this whole shaft situation is quite confusing.
So let's start with the obvious question. What kind of shaft is that really short one? I assume it belongs to a Type 1. Did they have shorter shafts in the very early days?
And what is the right shaft to be used with a 091 clutch housing and a CU Engine?
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Tue Mar 12, 2019 4:55 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
The differences in the 002 287mm shaft, and the 091 298mm one are in the spline area rearward to the end that engages the pilot bearing. The shorter shaft you have pictured is a Type 1 Beetle shaft. For an 091 trans with a factory 79 engine, it should have the long 298mm shaft. If you’re having issues with the shorter shaft bottoming out in the crank pilot bearing, not allowing the engine to be fully seated in the trans, that’s where I would start looking. I once came across an improperly machined Type 1 gland nut that did not have the bearing seated deep enough, and the spline area of the shaft was bottoming out on it.
Wildthings
Wildthings is offline
PostPosted: Tue Mar 12, 2019 5:22 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
Both an 002 or an 091 with either the early or late bellhousing take the same shaft when used with a Type 4 engine. The bellhousings are shaped a bit differently (to allow for the 228mm clutch on late models) but aren't much different in depth.
Are you sure you don't need to rotate the pilot shaft a bit to get the splines to align? Put the tranny in high gear and either spin one of the wheels as you push the engine into place or while putting forward pressure on the engine turn the crank a bit. If you don't have the engine well aligned with the tranny they will not mate, the space between the engine flange and the bellhousing needs to be the same all the way around for the engine to slide fully home.
sodbuster
sodbuster is offline
PostPosted: Tue Mar 12, 2019 8:33 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
Just going by what you asked and your picture.
the top input shaft is a 002 bus input shaft that and a 002 bell housing is what you need to adapt a 091 to a bus with an upright or type 1 engine.
the bottom input shaft in your picture is from a bug transaxle. it will not fit your transaxle but it makes a good clutch alignment tool.
I do not see a 091 input shaft in this picture. if you are putting your 091 to its proper 091 spec. nothing pictured above will work for you.
DrElch
DrElch is offline
PostPosted: Tue Mar 12, 2019 1:15 pm    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
Okay, maybe there are some pieces missing in my story.
I have scored the transmission in the picture. It has the "CU" code on it but it looks like a 002 transmission.
In fact all parts are 002 APART from the clutch housing.
That one is 091.
Here look at the following two pictures
And the input shaft was the aforementioned long one which is also 002?
The PO said this transmission has never been apart and it definitely looked like it never has been. What did Volkswagen do in the mid 70ies?
Update: According to the specs a CU was mounted on a 1600 engine. Does it still take a SR87 starter? Does this explain this strange configuration?
Wildthings
PostPosted: Tue Mar 12, 2019 1:25 pm    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
Your rig is over 40 years old, so there is very little chance the PO knows its history all the well. The bellhousing fits with your model year but the 002 part number does not.
I can not see your nose cone that well from the picture, but the stock 002 nose cone will cause the shift lever to be out of position towards the front and maybe hitting the dash unless the shift rod has been lengthened by 1/2" (12mm) or so.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Mar 12, 2019 5:26 pm    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
SodBuster built VW transmissions for a long time. I personally would accept his word as fact just because of his experience. I learned this when rebuilding my 091.
BTW if you don't have the proper jigs and tools your rebuild will not be successful. Also, use a finer grade glass bead when you clean things. That looks almost like broken glass was used. If so it embeds in the items being cleaned if that are softer metals like aluminum.
George Carlin:
Skills@EuroCarsPlus:
DrElch
DrElch is offline
PostPosted: Wed Mar 13, 2019 1:45 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
Oh trust me I don't wanna question him. At this stage I just wanna find out what kind of strange kombination of 091 and 002 parts I've got there Smile
So to recap:
091 Clutch Housing in combination with 002 Input shaft, 002 main body, 002 bearing case (dunno the proper english term for that part) and 002 nose cone
however my current setup is a completely different one. So what's currently in bus is the following:
I own a '72 bay window and it has a CU-Engine in it and a 002 CK transmission. The CU engine has a replacement by VW when the PO had it. This actually works fine.
The transmission looks like a stock 002 transmission but it has a strange input shaft, see picture below:
You see that the snout is much longer. It's 4cm instead of 3cm. Is that the 091 version or some other kind of special input shaft?
The input shaft protrudes the clutch house by 2.7cm. whcih in my undertanding is the right value for a CU engine and its pilot bearing.
Okay, so that's what I got at the moment.
So why all the fuzz about this other transmission? I planned a rebuilt with a professional rebuilder, so he would take care of the hard stuff. But now we got this super strange combination of a 091/002 transmission that still looks like it was delivered like that by VW as a CU-transmission and nothing really adds up.
Sorry if all of this is a bit confusing. I hope I haven't forgotten any information this time
SGKent is offline
PostPosted: Wed Mar 13, 2019 8:01 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
does your 1972 bus have a flat horizontal T4 engine or an upright T1 engine? What did the bus the trans came out of have?
George Carlin:
DrElch
DrElch is offline
PostPosted: Wed Mar 13, 2019 8:11 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
It is a late 79 CU Engine 2.0 with the 228 flywheel. I have grinded the clutch housing a bit to give it the required space.
But the CU Engine has all the cooling of the bay window. So it is looks like a CJ engine, but has the square ports on the heads
Wildthings
PostPosted: Wed Mar 13, 2019 8:37 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
The Bus Type 4 engine takes a longer input shaft than the Type 1 when used with the same tranny. I don't have a transmission available to me to measure, but I suspect yours is correct for a Bus Type 4 or even too short, your splines look correct. On a Porsche Type 4 I believe the pilot bearing fits into the flywheel instead of the crank, and I know it is this way on at least some Type 4 industrial engines, so if you have something besides the Bus flywheel that might be your problem, but I really doubt it, AFAIK the 228 clutch assembly is '76 and later Bus only.
I have an 002 Tranny with a 091 bellhousing and a 091 nose cone mated to my Type 4 engine using the standard long 72-83 input shaft and it works just fine. Everything aligns perfectly.
SGKent is offline
PostPosted: Wed Mar 13, 2019 10:14 am    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
buy a used 091 bell housing, hang it properly with the cross member style transmission hanger, put in the correct input shaft, and be done with it. You can get the used parts here: https://weddleindustries.com/products/1000296
George Carlin:
sodbuster
PostPosted: Thu Mar 14, 2019 2:15 pm    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
So to recap:
Ok. If your bus has the type 4 motor the input shaft in the above picture is correct. That style input shaft along with your 091 bell housing installed on your 002 transaxle should get the job done. The thing is the differences in overall gearing between the 091 and 002 trans axles. The 002 had lower gearing than the 091. Mainly in the ring and pinion ratios. 002 has 5.375 to 1 ring and pinion ratio and 091 has 4.57 to 1 ring and pinion ratio.
This is why a 091 is a more desirable upgrade for folks with early bay window buses. Rarely are 002 used in later model baywindow applications. Usually because of no viable 091 replacement option.
jhax
jhax is offline
PostPosted: Mon Aug 16, 2021 3:21 pm    Post subject: Re: long input shaft with a short snout for 091 transmission? Reply with quote
Hello,
I am wondering if it is the 298mm input shaft that will work with the 15* T2C watercooled engine. Is there a part number available for said input shaft? Does anyone know if the input shaft from a German 1.6TD will work with the 15* setup?
Thank you,
Justin
