fishgo Samba Member
Joined: June 21, 2018 Posts: 153 Location: Madison, WI
Posted: Thu May 09, 2019 11:42 am Post subject: Brake light gremlin: lights stay on / e brake light goes off |
I just had an interesting experience with my brake lights / parking brake dash light. During a short drive, I noticed my parking brake warning light was lit. But, the parking handle was released. Moving the lever up/down (while I was driving) didn't turn the warning lamp off. When I would brake (foot pedal), the warning lamp would turn off. Later, after I parked and walked around the back of the van, the rear brake lights were lit (ON) - both the tail lights and the additional 3rd LED lamp I installed in the window.
Returning home and just beginning to check things, functions started working normally. I took the boot off the parking brake to look at the switch (looked / worked normal). Checked the brake fluid level (good). By this time the braking system lights, warning light, etc. were all functioning normally.
Brakes are good and recently adjusted.
Brake feel is solid.
Brake fluid was changed less than 30 days and 300 miles ago, system bleed out properly.
Parking brake works normally.
Something electrical just went weird. What should I check? |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Thu May 09, 2019 1:32 pm Post subject: Re: Brake light gremlin: lights stay on / e brake light goes off |
| 90 % of all gremlins are bad groundy |
fishgo Samba Member
Posted: Thu May 09, 2019 3:45 pm Post subject: Re: Brake light gremlin: lights stay on / e brake light goes off |
| thummmper wrote: |
Lots of rain here lately. Maybe some water intrusion somewhere perhaps? |
fxr Samba Member
Joined: December 07, 2014 Posts: 2710 Location: Bay area CA
Posted: Thu May 09, 2019 6:12 pm Post subject: Re: Brake light gremlin: lights stay on / e brake light goes off |
I predict:
You have a van with two SPDT brake light switches (pre-'85), and one of them is faulty.
The brake warning light comes on to let you know this, deliberate design apparently, though there's nothing in any manual I've seen to suggest this.
Here's how I found this out:
https://www.thesamba.com/vw/forum/viewtopic.php?t=660358 _________________ Jim Crowther
Vespa GTS 300 |
fishgo Samba Member
Posted: Thu May 09, 2019 7:03 pm Post subject: Re: Brake light gremlin: lights stay on / e brake light goes off |
| fxr wrote: |
I predict:
https://www.thesamba.com/vw/forum/viewtopic.php?t=660358 |
Van is an '83 AC, so a 3 prong might be a good suggestion. And since there was lots of brake fluid flush/fill activity this may make some sense that either the switch(es) or wiring may have been disturbed causing the problem. I'll stick my head under the dash to verify.
It looks like this isn't an expensive part to replace so I might consider ordering both for precaution's sake, and keep an eye on the rear brake lights / e brake dash light in the meantime. |
fxr Samba Member
Posted: Fri May 10, 2019 10:48 am Post subject: Re: Brake light gremlin: lights stay on / e brake light goes off |
Yes, good idea to buy two. Replace both, but keep the good old switch as a spare for 'next time' - which now won't happen because you've got the spare.  _________________ Jim Crowther
Vespa GTS 300 |
