Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Mon Mar 08, 2010 1:01 pm Post subject: Battery hold-down |
My battery hold-down bracket is long gone. PO trashed it I am sure. I have been using bits of cork (cross country ski waxing cork blocks) and folded cardboard to jam my battery in place so that it does not vibrate. Bouncing batteries are not good I understand. I am curious as to what strategies others have employed to keep their batteries in place. I would really like to come up with a better solution than the one I am presently using. _________________ -- 1987 Westfalia automatic (Captain Vino) |
r39o Samba Polizei
Posted: Mon Mar 08, 2010 1:35 pm Post subject: |
Get the factory clamp......
Just saying. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Mar 08, 2010 1:41 pm Post subject: |
r39o wrote: |
I assume you mean the original part. Are they still available? _________________ -- 1987 Westfalia automatic (Captain Vino) |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Mon Mar 08, 2010 1:46 pm Post subject: |
Had no idea such a part existed until a couple of years ago, what I did was to cut up one of those FLAPS fatigue mats they sell in a kit. I think about four or five come in the package.They are made from a real firm closed cell foam rubber about 1/4 inch in thickness and measure about two feet by two feet.
I cut up one of them into four pieces to encompass the battery and with what I had leftover I cut up a seperate one to sit on top of the battery.
With the three leftover pads I made a nice mat to sit on top of the engine hatch.
Had I known about the battery hold down clamp I probably would have gotten one but the mats seem to be working just fine. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Mar 08, 2010 1:50 pm Post subject: |
I did see one of the vendors selling them but now I can't find it. A call might be worthwhile. It comes in most auxilliary kits. I don't have one either. _________________ 89 Westy 2.1 Auto |
RCB Samba Member
Posted: Mon Mar 08, 2010 1:56 pm Post subject: |
Perales wrote: |
r39o wrote: |
I assume you mean the original part. Are they still available? |
Greetings Perales...I think sleepyjoe has one up for sale, check out the used parts section for Vanagons.
If not listed online, give him a call....he's got lots of items up for sale at good prices and fast shipping. Ive been able to find some fuel injection parts that havent been available for eons. |
Posted: Mon Mar 08, 2010 4:22 pm Post subject: |
The part seems ridiculously simple to make. Does anyone have the dimensions on hand of a battery hold-down bracket? It seems like it is just a bent piece of steel at some specific angle with a hole drilled in the shorter leg. _________________ -- 1987 Westfalia automatic (Captain Vino) |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Mon Mar 08, 2010 5:54 pm Post subject: |
Perales,
Thanks for asking this, as I have the same issue for my aux battery. I'm curious about the solution options.
RCB, thanks for the mat tip.
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Posted: Mon Mar 08, 2010 5:57 pm Post subject: |
The stock bracket only works with a Group 41 battery. If you have something different you will need to come up with a custom solution. _________________ 89 Westy 2.1 Auto |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12338 Location: Santa Cruz, CA
zonxs7 Samba Member
Joined: June 16, 2012 Posts: 14 Location: Emeryville, CA
Posted: Sat Jun 01, 2019 4:08 am Post subject: Re: Battery hold-down |
Bumping this thread:
Anyone have any idea where to get one of these these days? Looking specifically for one for a swivel seat, '84 Westy.
Thanks,
Chris |
erdonline Samba Member
Posted: Sat Jun 01, 2019 5:57 am Post subject: Re: Battery hold-down |
zonxs7 wrote: |
Thanks,
Chris |
Here's one from the classifieds:
https://www.thesamba.com/vw/classifieds/detail.php?id=2270546
Ed _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
zonxs7 Samba Member
Posted: Sat Jun 01, 2019 11:10 am Post subject: Re: Battery hold-down |
Thanks!
Waiting to hear back from the seller.
Do you happen to know if these are the correct hold downs? I'm assuming that weekenders also have rotating seats? |
riceye Samba Member
Joined: March 09, 2006 Posts: 1705 Location: Caledonia, WI
Posted: Sat Jun 01, 2019 1:07 pm Post subject: Re: Battery hold-down |
zonxs7 wrote: |
Thanks!
My '87 Westfalia half camper (Weekender?) did not have swivels from the factory. The passenger does, now. This is the battery hold down that came from the factory.
Edit - Here you go. http://www.busdepot.com/251915313 _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10389 Location: Orbiting San Diego
Posted: Sat Jun 01, 2019 1:49 pm Post subject: Re: Battery hold-down |
Even 85 and 86 base campers without swivel seats could have sealed battery boxes and need the longer flatter type of battery hold down bracket. You should go by photos of the bracket, not by what van someone says the bracket came from or fits.
Mark
zonxs7 wrote: |
Thanks!
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Jun 01, 2019 2:56 pm Post subject: Re: Battery hold-down |
Honestly, I wouldn't want the following to occur, but if Godzilla himself were to grab up my van, turn it upside down and shake it for all he's worth, the only thing NOT to come out of its assigned location would be the battery.
That thing takes more finesse getting out o' the box than any reasonable engineer would have demanded. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
VWeGoBeachNow Samba Member
Joined: May 12, 2010 Posts: 197 Location: CRUISING DOWN PCH IN THE OC
Posted: Sun Jun 02, 2019 5:35 am Post subject: Re: Battery hold-down |
zonxs7 wrote: |
Thanks!
I just know that the long one eye reference this the one used in my Westfalia. In my passenger van I have the one that looks like a simple l bracket.
Posted: Sun Jun 02, 2019 6:51 am Post subject: Re: Battery hold-down |
It would be useful if someone who actually has one could trace out the profile and give accurate dimensions. These should be easy enough to make with minimal skills. I am still using cork blocks to jam the battery in place. Inelegant perhaps, but it works. _________________ -- 1987 Westfalia automatic (Captain Vino) |
Paulbeard Samba Member
Posted: Sun Jun 02, 2019 9:45 am Post subject: Re: Battery hold-down |
given how tight mine fits and how it has to be finessed just so to get it out, and the cables with approximately zero to give, I'm wondering how yours is different. I wouldn't want it to come down to the cables holding it in place if I invert the van, but I think that would be the least of my worries. Why not just get a strap from your FLAPS or elsewhere and attach it to the battery box? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
