snowback Samba Member
Joined: June 19, 2006 Posts: 4 Location: Calgary, Alberta, Canada eh!
Posted: Mon Jun 10, 2019 9:18 pm Post subject: Type 1 engine and transaxle used for front wheel drive |
Has anyone used a beetle engine and transaxle in a front wheel drive application.
Is it possible to do. The way I see you would have to reverse the pinion like in a spyder application, but move the engine and trans axel to the front.
What axels could you use for the front wheel drive application. I am looking at using it in a Trihawk. A front wheel drive three wheeler. It has a Citroen 1299cc air cooled GSA (boxer) engine with a five speed transmission. Only 60 hp. I Iwould like a bit more power by using the VW set up.
Look forward to the experts feedback.
Thanks
Snowy |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Jun 11, 2019 5:05 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
You should just be able to flip the R&P like in a mid engine rail. What do the current axles look like? You may be able to use modify the existing axles to take a beetle CV joint on the transmission end. |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2677 Location: East Nassau, NY
Posted: Tue Jun 11, 2019 8:51 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
look up VW Hormiga. Beetle engine and transmission in the front driving the front wheels.
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1362 Location: Richmond, VA
Posted: Tue Jun 11, 2019 9:17 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
The Brazilian Volkswagen factory did! It was a model called the Gol (not to be confused with Golf.) It was the predecessor to the VW Fox that we had here in the states, which is why they had longitudinal engines. They originally had a front mounted aircooled flat four, but that was later replaced with the same watercooled inline 4 they used in Golfs and Jettas and such of the era. They kept the same transmission layout though, hence the Fox engine being rotated 90 degrees from where it was in the other watercooled VWs.
_________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
finster Samba Member
Joined: May 26, 2012 Posts: 8033 Location: north o' the border
Posted: Tue Jun 11, 2019 11:53 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
the blackjack zero replaced the 2cv powered avion and used a vw drivetrain as detailed here:-
The Zero is powered by either an 1,100cc V-twin Moto Guzzi motorcycle engine or a 1,600cc flat-four from an air-cooled Volkswagen Beetle. Both are mounted in front of the front-wheel axles and coupled to a four-speed Beetle transmission that drives the front wheels.
“It’s a happy accident,” says Oakes. “The Beetle gearbox works in reverse, but the final drive just bolts in on the other side. The VW Golf halfshafts bolt to them and the Golf front uprights. I had thought the gearbox would need a reversed change gate, but in fact it is the [rear-wheel drive] Beetle that has the reversed gate, with a complicated linkage to turn it into a conventional H-pattern.”
see http://www.blackjackzero.com/mainindex.htm
but not sure if they're still trading _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
EverettB Administrator
Joined: April 11, 2000 Posts: 69884 Location: Phoenix Metro
Posted: Wed Jun 12, 2019 2:23 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
1300cc? check-out the classifieds everett
www.thesamba.com/vw/classifieds/detail.php?id=2285425 _________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Wed Jun 12, 2019 8:43 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
Thanks for all the feedback. I guess I now have to do some more research. I would like a 2110 cc duel Weber setup, now that I know I can use golf hubs and shafts, with a Bergman shroud popping out of the hood it will look pretty sweet !
Thanks Again
Snowy |
Retrovan Samba Member
Joined: July 15, 2011 Posts: 524 Location: Port Elisabeth - RSA
Posted: Mon Jul 15, 2019 9:30 am Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
Busy building a 2lt type 4 motor and gear box front wheel drive, but the engine is still behind the gearbox.
This means you need not change the gearbox at all, and I have used a Opel Monza front McPherson struts and hubs, with Renault Scenic Rear with air bags.
Good luck with your project.
Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1509 Location: Buford GA
Posted: Wed Oct 30, 2019 9:24 pm Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
914 engine and trans or just the trans.
The 69, 70 beetles used an IRS trans that had bolt on side plates on both sides so you could use this trans and flip the ring gear. |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Thu Dec 31, 2020 7:34 pm Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
EverettB wrote: |
Bummer, I was hoping it was some huge stock 2L |
i know this is old. Its a 1600 single port. the intake manifold for the single carb version is a single port manifold on backwards. the dual port intakes have heat riser connections on BOTH sides so connect to both exhaust ports. that little square bump in the shroud to the left of the fan is the oil cooler. its a stock type non doghouse oil cooler but its only half the height. no wonder they are known to over heat! _________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
Posted: Thu Dec 31, 2020 9:42 pm Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
MrBusCo wrote: |
EverettB wrote: |
i know this is old. Its a 1600 single port. the intake manifold for the single carb version is a single port manifold on backwards. the dual port intakes have heat riser connections on BOTH sides so connect to both exhaust ports. that little square bump in the shroud to the left of the fan is the oil cooler. its a stock type non doghouse oil cooler but its only half the height. no wonder they are known to over heat! |
That oil cooler design sounds insane.
I wonder if it's at least wider or something because of the large fan and fan shroud? _________________ How to Post Photos
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1426 Location: Toronto, Ontario. Canada
Posted: Sun Jan 24, 2021 5:03 pm Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
Why not run it as a mid engine? No flipping ring and pinion. Direct air flow into fan. Mid engine shifter setup. CV joint, 1/2 shafts connected to some fwd. spindles. Would be a cool project.. _________________ I think he meant "rare", as in "not well-done" |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77066 Location: Sneaking up behind you
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15149 Location: Syracuse, NY
Posted: Fri Feb 19, 2021 7:33 pm Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
you do know a VW type one is ~60hp too
for those looking to flip his script, here's a trihawk like the OP has
not really reconfigurable
https://journal.classiccars.com/2019/04/11/trihawk-was-a-carmotorcycle-hybrid/
Abscate wrote: |
Posted: Wed Mar 17, 2021 12:48 pm Post subject: Re: Type 1 engine and transaxle used for front wheel drive |
Here is my Front wheel drive as my 1952 Beetle carrier.
He is called MeFusco
Near ready to do 1st test drive.
Has 2000cc Kombi motor and gearbox with Golf 1 side shafts into Opel wheel hubs and CV's
Have fun
