Derickpete Samba Member
Joined: October 01, 2013 Posts: 33 Location: Gardnerville Nv
Posted: Wed Feb 12, 2025 5:24 pm Post subject: Angle of front windshield |
| What degree of angle is standard for a dune buggy. Right now mine is almost 40 degrees but I am making new mounts and can change it. I am also making a new full cage and want to match the windshield angle. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1054 Location: South Florida
Posted: Thu Feb 13, 2025 4:37 am Post subject: Re: Angle of front windshield |
| Derickpete wrote: |
| ... mine is almost 40 degrees ... |
Guessing you mean 40° from vertical? Mine's more like 40° from horizontal (but it's a different kinda buggy).
Posted: Thu Feb 13, 2025 7:52 am Post subject: Re: Angle of front windshield |
| Mine is 40 degrees vertically. The top of the windshield is laid back more than the bottom. 90 degrees would be straight up and down. I’m leaning toward a 30 degree angle but wanted feedback of what other dune buggy’s are. |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1116 Location: Portland, OR
Posted: Thu Feb 13, 2025 10:55 am Post subject: Re: Angle of front windshield |
I'm not sure if there is a standard angle. I read somewhere that the windshield frame should be parallel to the seam at the hood and dash, but that would probably only apply to some 'glass bodies. I'm sure original Manxes had a recommended angle, or the angle was already built into the dash frame, but I think many people just eyeball it.
25 years ago (!), I used the original hood holes from the original '70s builder - didn't know the angle.
17 years later, I chopped the windshield 1.5" and tried it laid back a little more, parallel with the hood / dash seam, but I didn't like it:
This was a little too upright:
I ended up here, an eyeballed angle in between the pics above:
I chopped the windshield again in 2020, and kept the same angle:
| Derickpete wrote: |
_________________ 1963 Manx copy
1968 Bus |
NJ John Samba Member
Joined: September 21, 2007 Posts: 3012 Location: HdG, MD & NJ
Posted: Thu Feb 13, 2025 3:17 pm Post subject: Re: Angle of front windshield |
I don’t remember if I asked you before. Is your buggy 90’s mustang yellow? Mine was it and it looks so similar. When I painted it, that yellow was pretty radical factory color. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Thu Feb 13, 2025 4:21 pm Post subject: Re: Angle of front windshield |
Hey NJ John! It's 90's Jeep Malibu yellow, painted by the local Maaco. I know the 90's Mustang yellow you're talking about, it's similar!
| NJ John wrote: |
| I don’t remember if I asked you before. Is your buggy 90’s mustang yellow? Mine was it and it looks so similar. When I painted it, that yellow was pretty radical factory color. |
1968 Bus |
Posted: Fri Feb 14, 2025 1:12 pm Post subject: Re: Angle of front windshield |
Thanks, mine was painted outside on a 90 degree day. Mine photographed like yours, sometimes looking a different shade in some pics. Enjoy you buggy, I miss mine. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
