oceanair Samba Member
Joined: June 09, 2013 Posts: 724 Location: Victoria, BC
Posted: Mon Jul 22, 2019 7:59 pm Post subject: Auto Trans hard drop in from kickdown |
Hey folks -- when at 40MPH and going uphill, I kick down to 2nd gear and it drops in with a bang. Otherwise it shifts under normal driving conditions smoothly.
Are there some adjustment to make -- I don't want it banging into gear... it only does this at high RPMs on the kickdown to 2nd.
Thanks - _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Tue Jul 23, 2019 6:36 am Post subject: Re: Auto Trans hard drop in from kickdown |
Check the adjustments of the throttle and transmission..exactly as described in the Bentley. Any errors in adjustment will cause harsh shifting or no shifting issues. It helps to have someone in the cockpit working the throttle.
Check the ATF level as per the book too. |
Posted: Tue Jul 23, 2019 4:58 pm Post subject: Re: Auto Trans hard drop in from kickdown |
Will do -- thanks -- _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
