Transmission Seals
padgett
padgett is offline
PostPosted: Sun Aug 25, 2019 5:20 pm    Post subject: Transmission Seals Reply with quote
Engine is out, gonna use this opportunity to get at some stuff.
Theres a bit of a leak coming from the tranny input shaft. Anyone know where I can get an exploded diagram of the area so I can grab some part numbers of the seals?
Thanks. oh its a 73 square. Manual
padgett
padgett is offline
PostPosted: Sun Aug 25, 2019 5:22 pm    Post subject: Re: Transmission Seals Reply with quote
Can I trust Rockauto for these?
https://www.rockauto.com/en/moreinfo.php?pk=1839122&cc=1370023&jsn=906
https://www.rockauto.com/en/moreinfo.php?pk=1838744&cc=1370023&jsn=911
Erik G
Erik G is offline
PostPosted: Mon Aug 26, 2019 8:03 am    Post subject: Re: Transmission Seals Reply with quote
I would ask in the engine / performance section instead of the type 3 section. There are pro trans builders that frequent there more than here
that said, rock auto just sells parts like everyone else... SKF is a good brand
sjbartnik
sjbartnik is offline
PostPosted: Fri Aug 30, 2019 8:27 am    Post subject: Re: Transmission Seals Reply with quote
Elring (German) is also pretty good.
Input shaft seal is an easy job if you have a decent seal puller and if you are careful in extracting the old seal (don't gouge the bore with your seal puller hook).
The parts book shows the part number as 113 311 113 A from '71 to '73.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
