Shopping list for Vancouver, BC
epowell
epowell is offline
PostPosted: Thu Sep 05, 2019 8:55 pm    Post subject: Shopping list for Vancouver, BC Reply with quote
Hi Folks
Just got into Vancouver yesterday and tomorrow I begin working on Antonio... out of my element in terms of locating the necessary supplies. So I decided to start a "shopping list" thread. As I need various things I will post here the item, and hopefully those who know will enlighten me as to where in Vancouver I can purchase...
To begin with I am going to be attacking a whole pile of RUST (Vancouver van.... go figure!) >>> I have some rust converter but after that plan to put on some EPOXY PRIMER... or even some POR15. Both of those things I have no idea where to find in Vancouver (West Side if possible).
The other thing I will need very soon is a NEW BATTERY.... any suggestions?
Thanks
Ed
www.edwardpowell.com
sphet
sphet is offline
PostPosted: Thu Sep 05, 2019 10:53 pm    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Love 'em or hate 'em, I got my group 41 battery at Canadian Tire on Cambie street last year.
1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee
RoryGirl
RoryGirl is offline
PostPosted: Thu Sep 05, 2019 11:16 pm    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Can tire also has POR15
https://www.canadiantire.ca/en/pdp/por-15-gloss-946-ml-0475874p.html
Auto body supply for 2 part epoxy in a spray can
https://goo.gl/maps/bMTogjc3tLLc8FpaA
1991 Twin Slider VR6
1985 Audi 4k
BlueTwo
BlueTwo is offline
PostPosted: Fri Sep 06, 2019 1:43 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Napa, the North Vancouver location on Churchill Cr. but any location should sell for the same price.
41-6 Legend: $157.32 all in, with a $15.00 core credit
It's a squeeze and a battery lift strap is a must but it fits.
photogdave
photogdave is offline
PostPosted: Fri Sep 06, 2019 4:26 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Polar Battery is the best:
https://polarbattery.com/
For anything Vanagon specific, Werke1 in Richmond:
http://werke1.com/
For general stuff Canadian Tire often carries the same as any FLAPS but often a bit cheaper.
89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
epowell
epowell is offline
PostPosted: Fri Sep 06, 2019 7:51 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
still trying to locate epoxy primer in YVR... does it HAVE to be LECHLER?
wesitarz
wesitarz is offline
PostPosted: Fri Sep 06, 2019 8:11 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Walmart for battery.
epowell
epowell is offline
PostPosted: Fri Sep 06, 2019 8:31 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
https://www.walmart.ca/en/ip/everstart-maxx-41n/6000195362498
wesitarz
wesitarz is offline
PostPosted: Fri Sep 06, 2019 5:12 pm    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
That's it. You have to check your local stores.Good battery.Lasted longer than rating. On my second one now.
SlowLane
SlowLane is offline
PostPosted: Sun Sep 08, 2019 11:38 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Lordco has always been my goto FLAPS when in BC. They can get pretty much any part you need within a day, and their parts quality is better than Crappy Tire.
Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett
sphet
sphet is offline
PostPosted: Sun Sep 08, 2019 3:07 pm    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
What kind of parts are you getting there? I havehad zero luck getting any vw parts through Lordco and have always had to hit up the vanagon vendors.
S
epowell
epowell is offline
PostPosted: Sun Sep 08, 2019 10:58 pm    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
next item... does anyone know where in Vancouver to buy high heat rubber hose? I need 5 meters to replace one of my engine to rad. coolant pipes.
Thanks!
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Mon Sep 09, 2019 3:03 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Thanks!
1? or 1.25" ? I might be inclined to check with your local marine supplier. You are in a strong marine area. The last roll I purchased was off amazon.
Mike Robinson
Mike Robinson is offline
PostPosted: Mon Sep 09, 2019 7:42 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
My 1982 diesel had a rusted out coolant pipe, which when checked was only the last bit before the engine, the rest was still good.
So if you have the same situation, check a truck supply shop (Peterbilt or Mack type not F150) and get braided 1.25" or 1.5" hose from them.
Mike
epowell
epowell is offline
PostPosted: Mon Sep 09, 2019 7:48 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
THX GUYZ! Exclamation
wesitarz
wesitarz is offline
PostPosted: Mon Sep 09, 2019 7:57 am    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
CdnVWJunkie wrote:
Thanks!
Marine exhaust hose. Also comes in 1 3/8"
epowell
epowell is offline
PostPosted: Sat Sep 14, 2019 1:08 pm    Post subject: Re: Shopping list for Vancouver, BC Reply with quote
Probably a silly question, but where in Vancouver can one purchase just basic NUTS & BOLTS in bulk in many sizes?? I have absolute NONE here in my mom's house. Back in Czech my GF's father had tons everywhere... and they are easily purchased there too...
...I am stuck because I was dropping the spare tire clam shell, which NORMALLY stays "up" via a little hook, even after you remove the bolt... but my little hook doesn't work and it came CRASHING DOWN on my knee... OUCH!!!!!!!!!!!! Twisted Evil
...in the chaos and pain the bolt must have gone flying and not it's gone... so I can't even get the clam shell back up.
Does anyone know how to repair that hook??
